04-05-2024, 10:25 PM | #1 |
Rep 5
F80 M3 rear subframe brace on F30
Does anyone try to fit the M3/M4 rear subframe brace on the F30?
I found threads about fitting the F32 / F36 rear subframe brace on F30 however, can't find any threads about the M3 ones The M3 one has slightly more attachment points so I think the effect should be better than the F32 / F36 ones here are the parts number M3 ones (1 - on diagram) 33302284645 Dual link, link 33302284646 Dual link, right 4 F36 series ones (1 - on diagram) 51617351583 Pull rod left 51617351584 Pull rod right |
04-06-2024, 04:19 AM | #2 |
Rep 8,524
Surely the rear brace for an F31 would be a no-hassle option ?
Why do you want the brace from an F80 M3 ?
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
danb19792015.00 |
04-06-2024, 01:38 PM | #3 |
208
Rep 306
I looked into doing the F31 rear brace on my pre-lci F32 but my car doesn't have the rear-most attachment point that the Touring & Gran Coupes have.
It's just aft of the rear diff and appears to be attached to the underside of the trunk pan. You can see it in this pic of a touring Ultra Brace. Haven't looked into the M3/4 brace. |
04-07-2024, 08:30 PM | #5 | |
Rep 5
which is number 4 for left and right And the rear is quite bouncy on my F30, so I'm thinking of stiff things up |
04-07-2024, 08:34 PM | #6 |
Rep 5
04-08-2024, 03:23 AM | #7 | |
Rep 8,524
Uprated springs, dampers, and subframe bushes would have a far bigger effect on chassis control.
04-08-2024, 07:20 AM | #8 | |
Rep 1,124
That is one of many braces on the F80 that the F30 does not have, so there's little to be gained from just fitting the rear one without the others. |
04-08-2024, 12:26 PM | #9 |
33
Rep 80
i got one of these:
https://rollsperformance.com/shop/ol...mw-mid-chassis there's a thread on here somewhere about this |
04-09-2024, 11:52 PM | #10 |
Rep 1,372
I have just the M brace that overlaps just the exhaust tunnel and does not connect to the sub-frame. I'd say the difference is slightly noticeable but minimal at best. When I take it to the track in a month I'll know it's full potential.
340i xDrive (F30), 228i (F22), 320 (F30), 325i (E46)
04-10-2024, 07:38 AM | #11 |
Rep 5,460
Drives: F30
Same here, been waiting for someone to say that. Noticeably stiffer and lighter when both parts are held in hand.
chassis, chassis brace, f30 3 series, f80 arm, retrofit, strut brace, subframe, suspension |
