TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Coolant leaking RAPIDLY! Reservoir empties after every drive. HELP!!!
      11-22-2014, 10:32 PM   #1
Debacle of Mass Eruption.
Debacle of Mass Eruption.'s Avatar
14
Drives: 2007 BMW 335i e90
Exclamation Coolant leaking RAPIDLY! Reservoir empties after every drive. HELP!!!
I've had my 335i for a year and I have been dealing with problem for 8 months, recently it's gotten worse. I have to go out and buy a gallon of distilled water and Pentefrost NF every 2 days because it leaking will not cease. There's also a bubbling/boiling sound coming from there that's making me kinda uneasy...
It started little by little, once a month I needed to add coolant. That turned in to once a week, and eventually every other DAY. Dinan told me it was a leak by the rear turbo, Alekshop in Fremont told me it might be that, but the subframe needed to be dropped to look and be sure. I was hoping to go to another shop to get a 3rd opinion, but I don't know of many in the area besides the two.
If this has ever happened to anyone, I would appreciate any advice on the subject. I look forward to your replies.
Thanks
2007 BMW 335i, My commuter car
2016 Jeep Cherokee Trailhawk, the other car
Driving Fast and Unsafe Around The Bay Area.
Last edited by Debacle of Mass Eruption.; 11-22-2014 at 11:57 PM.. Reason: addition
      11-22-2014, 10:45 PM   #2
888Concept
56
Drives: e92 n54 FBO COBB'd
At the rate of having to refill coolant so often, you obviously have a bad leak somewhere. It should be easy for a mechanic to figure out where the leak is and fix the problem at its root. You should've fixed it the moment the leakage problem started. Good luck!
      11-22-2014, 11:15 PM   #3
Spacecpe
44
Drives: E90 335i Msport
How many miles on the car ? it might your water pump .. mine had a hairline crack which got bigger with time and i had to fill coolant everyday lol.
      11-22-2014, 11:55 PM   #4
14
Thumbs up
I would have fixed it then, but they were basically charging two months rent for a maybe solution, not really a sure thing.
      11-23-2014, 12:04 AM   #5
cwarren
cwarren's Avatar
82
Drives: 08 e92
pump and t stat is right below the rear turbo i would pull under tray and drop the sway bar fill with water and look to see whats going on . has it thrown pump codes/over heated ?
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
      11-23-2014, 12:12 AM   #6
14
It has about 115k, i bought it a 109k
The leak is coming from the right, near the firewall
      11-23-2014, 12:20 AM   #7
14
No codes yet, only from a POS SSTT i bought on eBay that game me a limp light, it was quickly removed
It hasn't overheated from my knowledge, although it used to emit ALOT vapor from under the hood a couple months back after driving home from work. it hasn't done that in a while
I own a muscle car and i know vapor means a bad water pump or a cracked radiator, but i don't know enough about these BMWs to make an expert opinion.
      11-23-2014, 12:28 AM   #8
NiVeDh
NiVeDh's Avatar
Drives: '08 E90 335i, '99 E36 M3
Here's what I'd try:
1. Pull the undertray.
2. Top up the reservoir with distilled water and run the coolant bleed cycle.
3. Get under the car during the cycle and look for leaks.
      11-23-2014, 02:23 AM   #9
blackturbo
blackturbo's Avatar
59
Drives: 335i
Check for a crack in the radiator
check for a crack in the water pump
check for a crack in tubes or reservoir
Your loosing alot of coolant and its costing you money buying more.
For me i had a cracked waterpump with your leaky symptoms.
Good luck and update us
      11-23-2014, 03:42 AM   #10
14
Talking
i'm gonna try to go to FFTECH in Hayward, Cal to see if they can check it out. Any know of any other shops in the Bay Area?
(Shout out to my Canadian homies for the help too )
      11-23-2014, 09:43 AM   #11
Cloud9blue
Cloud9blue's Avatar
Drives: around the potholes
Any decent mechanics can do a pressure test on the coolant system to figure where irbid peaking.
      11-23-2014, 10:24 AM   #12
Jklad
Jklad's Avatar
Drives: 2007 335i Coupe
If your pissing that much coolant it shouldn't be hard to find. If you can't locate it yourself any decent tech should be able to do so quickly.
2007 E92 335i MT
      11-23-2014, 05:01 PM   #13
chepy24
chepy24's Avatar
30
Drives: 2009 alpine white 335i xdrive
Like everyone said find the leak (should be easy) and then go from there
      11-24-2014, 03:13 PM   #14
Peebody85
Drives: 07 335i E92
I had that problem Friday night. Just a little vapor coming from the hood at the . It was a small leak in the expansion tank coolant line. Fixed it Saturday. Luckily it was right on top, but sounds like yours is coming from the rear.
I'd lift it up, start the car and wait till it warms up and water pump kicks on. See where it is dripping from and trace it back to the source. That way your not buying parts you don't need.
      11-24-2014, 05:08 PM   #15
soursamo
soursamo's Avatar
163
Drives: 2008 E92 M3
Had the same issue, melted the resevoir hose in the wheel well
      11-25-2014, 02:57 PM   #16
Laurus_CEO
Drives: E92 335i
Bring it over to me, I will find the leak and we will fix what's needed. Just last week I did radiator and hoses on an E90 to fix leaks as well as water pump on thermostat that died on my buddies E88. I'm in San Leandro and do a ton of work on N54 cars out of my garage.
335i, bay area, coolant, leak, n54
