05-06-2022, 02:30 PM | #23 | |
Rep 894
Youll need- radar sensor, replacement lower grill, radar sensor wiring, ICM (maybe), steering wheel buttons, abs pump, new abs sensors collision warning uses the optical camera sensor in the windshield.
05-07-2022, 12:25 AM | #24 | |
Rep 1,117
If (and if is big question) you can find USED radar sensor, ICM, DSC Pump, Grill, Steering Wheel Buttons and NEW Wiring Harness, Custom Wiring and DSC Pulse Generators to all 4 wheels, you are easily looking at $2500+ easily. If you buy all new, might as well double that. |
05-21-2022, 08:17 PM | #26 |
Rep 894
Yeah, i think mini uses the KAFAS camera for ACC and they can do the retrofit for cheap, but not bmw.
05-22-2022, 03:08 AM | #27 |
69
Rep 164
I was able to do it for just over 1000€ (~1100$), but I got all the parts second hand and was a bit lucky with finding the ICM and ABS pump for a very good price! All-in-all very worth it!
05-22-2022, 02:49 PM | #28 |
Rep 894
Agreed it's such a good mod that my next car has to have acc on it, it's not optional lol
06-28-2023, 10:36 AM | #31 |
Aidas
Rep 13
06-28-2023, 04:21 PM | #32 |
68
Rep 57
How much have you fitted already aidas? I've been gathering bits for this over the last few months. Just fitted the MK100 DSC ACC and now sourced an ICM so will start putting that harness together to run to the FRR next.
06-28-2023, 05:39 PM | #33 |
Aidas
Rep 13
For the last few months I have been busy with retrofitting options 415, 5AG, 5AC, 5AD, 610, 8TH, 322. 5DF is my last retrofit this year. The most expensive and hard-to-find parts (ACC, DSC and ICM) have been purchased and should be delivered next week (I hope). The rest like grills, brackets, screws, nuts, connectors and etc. I decided to by new. The plan is to start installation somewhere in September, because now is summer and vacation time . Maybe I'll try to fit the DSC before the vacation. I already put harness from ICM to ACC when retrofitted HEAD-UP
06-29-2023, 09:39 AM | #34 |
68
Rep 57
Some choice retrofits there, you've had a busy year! I think i'll try and put the wiring in for KAFAS2 at the same time as this install, much easier when things are already apart.
07-24-2023, 03:05 PM | #35 |
68
Rep 57
Finally got the ARS3B BE2 radar today so next up I’m making the harness, then fitting that alongside the v5.6 ICM. DSC all in, coded and working perfectly.
If anyone is on the hunt for ACC bits I came across an MK100 ACC in the UK here - https://www.ebay.co.uk/itm/204396604366 |
08-14-2023, 03:15 AM | #36 |
Aidas
Rep 13
Hi everyone. some bad news for 318i owners. I tried to retrofit ACC, but my car cannot have this function at all. It turns out that even when ordering a new car for my model, it was not possible to choose the 5DF option. If you have BMW cars with a B38M engine, it is impossible to do this.
If anyone is interested, I have for sale all the necessary parts that are needed for the retrofit 5DF option: DSC, ICM, radar, braket for M, grill, wheel buttons, cabel and some nuts and bolts. |
11-28-2023, 01:31 PM | #38 |
Rep 496
Does anyone know how picky the car is with regards to the ICM HIGH units? I have a 2012 build F30 so its unclear which parts are exchangeable.
For example, you can fit a post 2012 build DSC on and it will work, its just that the brake lines won't match up so you'll have to fashion an adapter or bend them...see here The ICM units all seem to be exchangeable after around 07/2013 according to realOEM...but for models with pre 07/2013 build date it doesn't seem like there are options, see here. To make matters more confusing, it seems like most of the part numbers on the actual parts don't correspond to realOEM, so searching the parts often comes up with nothing...any insight? Thanks! |
11-28-2023, 06:04 PM | #39 | |
Rep 1,117
Get the proper part. |
11-28-2023, 08:46 PM | #40 |
Rep 496
Well it certainly would be a no brainer if the DSC wasn't so hard to find...I'd probably replace brake lines along with new MK100 DSC, because bending those looks janky as hell...in any case its probably too much money for an experiment.
11-29-2023, 09:15 AM | #41 |
Rep 1,117
If anyone has fitted a MK100 unit in a pre 7/2013 and Coded it to where it’s operating properly for ACC it would be interesting to know. The brake lines can be replaced or dealt with better than the pic in the other thread, but something in the back of my mind from several years ago was the MK100 DSC had different wiring and even more connections than the earlier MK70 DSC. Of course, this was years ago and I’ve looked at so many wiring diagrams since then that I might be thinking of something else and I’m certainly not going diving back into it just for this post.
11-29-2023, 07:33 PM | #42 | ||
Rep 496
https://www.drive2.ru/l/472884559017411012/ Web Translation: Quote:
12-05-2023, 06:41 AM | #43 |
Rep 496
Something I noticed doing a bit more research is that the ICM High is shared with the F25 - https://www.realoem.com/bmw/enUS/par...&q=34526862759
I wonder if F25 DSC is compatible? |
12-05-2023, 06:34 PM | #44 | |
Rep 1,117
