08-23-2012, 01:42 PM | #23 |
↓↓↓ Ex-Con ↓↓↓
34
Rep 1,874
Been looking at getting this brace as a pre-cursor to get the Ohlins R&T coilovers but I noticed something with your pictures in the OP. The three nuts holding the upper strut plate to the tower only have a few threads engaged. That is not a good thing when lock nuts are used.
Is there a fix for this? |
08-23-2012, 03:23 PM | #24 | |
Supreme Allied Commander
3871
Rep 54,430
Drives: F80 M3
On the tower ring side BMW long reach nuts are used. The nuts are grabbing at least another 5mm of threads below the tower rings. |
08-23-2012, 05:33 PM | #25 |
↓↓↓ Ex-Con ↓↓↓
34
Rep 1,874
Ahh so the cylindrical extension from the bottom of the nut is also threaded?
08-23-2012, 05:49 PM | #26 |
3871
Rep 54,430
Drives: F80 M3
08-23-2012, 06:00 PM | #27 | |
↓↓↓ Ex-Con ↓↓↓
34
Rep 1,874
Thanks for the info. |
08-25-2012, 01:22 AM | #28 | |
3871
Rep 54,430
Drives: F80 M3
https://www.facebook.com/photo.php?f...r¬if_t=like |
10-17-2012, 11:11 AM | #30 |
Rep 614
Drives: BMW 120d e82 M Sportpaket
Is it compatible with the BMW Performance strut brace ?
M Sport package, Stage 1, CDV, BMC airfilter, VMR vb3, ST XTA, BMW Performance stuff, M3 arms, E93 M3 anti-roll bars F and R, ... French community of 1 and 2 Series: One-Two-Bimmers |
11-02-2012, 12:56 PM | #31 |
3871
Rep 54,430
Drives: F80 M3
05-20-2013, 07:37 PM | #33 |
3871
Rep 54,430
Drives: F80 M3
02-10-2014, 05:18 PM | #35 | |
3871
Rep 54,430
Drives: F80 M3
Exact shipping charges can be calculated after you select the item and enter all your info: http://www.hpashop.com/BMW-128i-135i...tbrace-e82.htm |
09-29-2014, 02:48 AM | #36 |
26
Rep 274
Is modification needed for 2010 models? I did see the photos with pre-2011 N54, but was concerned whether or not the 2010 models needed modification to #13 for installation.
Any added benefit, in addition to front control arms and stiffer anti-roll bar, besides added driver control.
09-29-2014, 10:51 PM | #37 | |
3871
Rep 54,430
Drives: F80 M3
You will get a better steering response from the added stiffness of the front-end. Feed back from the tires will also be better. And if you happen to run adjustable dampers, you can get to your adjustments much easier. |
09-30-2014, 12:08 PM | #39 |
3871
Rep 54,430
Drives: F80 M3
