07-19-2015, 06:03 AM | #89 | |
Rep 1,409
I made a few posts with pics here ---> http://www.1addicts.com/forums/showp...0&postcount=57 http://www.1addicts.com/forums/showp...9&postcount=38 http://www.1addicts.com/forums/showp...4&postcount=36
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
02-13-2018, 05:03 PM | #90 |
Rep 704
Sorry to bring back an old thread, but i am picking up my new to me 125i tomorrow and getting the brakes done (front and back) and wanted to do this while i am in there.
The part number(s) you submitted are no longer available, and my local dealer mentioned it is for the F20 1 series as well as the F30 3 series, which both have the following part number(s): F20: 34106873417 34106873418 F30: 34116872081 34116872082 So now i am confused on which is the correct part for the 125i, they both appear to have that "bend" to allow air to come in (yes the 125i i am picking up has the M-Sport package with the front bumper). |
02-17-2018, 03:59 PM | #91 |
Rep 704
Just an update,
I was browsing around Babybmw forums and found an old thread regarding the back plates. Basically, the updated parts are: 34116872081 & 82 I will be checking with my local dealer, since they have them in stock and report back, |
02-17-2018, 05:39 PM | #92 |
Rep 1,600
Even if you order the old part number you will get whatever they have of that item.
Ie if there is a new part number and you order that, you will get whatever your local warehouse has because they will need to get rid of stock of the old part number first. Conversely, if you order using the old part number and they only have the new part number in stock you will get that. That's how supersessions work. |
05-12-2018, 08:56 PM | #93 | |
Rep 1,001
09-12-2018, 10:51 PM | #94 | |
20
Rep 126
Sorry to bump an old post but are you saying essentially you needed ducting to solve the problem? Do you have issues with the steering rack? |
02-28-2023, 09:44 PM | #95 | |
380
Rep 301
Drives: 2010 128i ZSP 6MT
Thanks. |
