JBL MS-8 Processor Integration Thread
06-23-2010, 10:23 PM | #23 |
Rep 3,969
First listening impressions:
Absolutely fantastic! I'm not one of those people who can tell you exactly why, but I just know it when I hear it! I put in a Focal demo disc and everything just sounded great. The stage now stretches from mirror to mirror and in between, each instrument has its own unique location on the windshield. Voices are coming from dead center, head high, and there certainly is more depth as well. The sound is crisp and clear, without any hint of distortion even at very high volume levels. Pretty impressive for 18W per channel! (well, technically the L7 component speakers are 2ohm, so they are getting 30W). The underseat woofers also kept up surprisingly well, with that little power, but I definitely felt like they will need some additional juice. Overall, I believe that most people will be more than satisfied with the MS-8 powering the entire system, and for those who need more bass, they can add an amp for the L7 woofers or even a sub in the trunk. As far a negatives go, I did get a few loud pops, but I have not yet been able to determine the likely cause. The unit does get very hot, so adequate ventilation will be required [edit: I later found out that the unit actually never ran hot again - I originally had the trunk open so the sun made it hot!]. I will install it above the L7 amp and I am thinking about adding a fan to vent the hot air out of the panel. Very impressed! Last edited by kaigoss69; 03-18-2011 at 09:16 PM.. |
06-23-2010, 10:33 PM | #24 |
Rep 3,201
So do you have L7 turned off in the HU?
So you are not running the R speaker out into the MS-8? OEM fader inop? Different Hus have different numbers of clicks. If you watch the MS-8 screen, it tells you where to set it. But I know that some BMW head units are clipping at 47, so I wonder if clipping the inputs is your popping problem. How many seats did you tunr for? Listem from? How would you describe Dr and Pass imaging when set to "Front"? Did you use the R or R effects speakers, or both sets? Did you defeat the EQ in the HU? |
06-23-2010, 10:36 PM | #25 |
Rep 3,969
I followed your advice and set-up as a two-way front. After calibration, virtually no sound was coming from under the seats. Also, the high pass for the door mids could not be set higher than 150 Hz, which of course is not feasible unless you are running Morels (or you listen to music at elevator volume). Then I set it up where the under seats are subs, and that did the trick!
06-23-2010, 10:50 PM | #26 |
Rep 3,201
I got no bass out of the subs when I clipped the mike by having the system too loud. I lowered MS-8 volume from the preset -20 to -30 and that solved that.
Perhaps the 150 xo rather than 90 helped you prevent any midrange flapping. Either is a low xo point for 4". |
06-23-2010, 11:11 PM | #28 | |||
Rep 3,969
Yes, of course.
I only used the rear shelf speakers, since they have tweeters, and there aren't enough channels anyway to use them all. Yes. |
06-24-2010, 01:09 AM | #29 |
Rep 3,201
It was a leading question
I know I like stereo midbass, but given how low we run the mids, I've been thinking 2 front, 1 center, 1 mono sub out (Y adapter to the amp), 2 rear, and 2 rear effects? |
06-24-2010, 05:50 PM | #32 |
Rep 3,969
After some more critical listening today I am now considering leaving all the stock mid/hi speakers in place. It sounds so freaking amazing that I absolutely cannot imagine it sounding any better with different equipment, period. I am also very much considering not adding any additional amplification, except for the underseat woofers. The MS-8 will get so loud that it makes my ears bleed, and it's still crystal clear at that level, no distortion. I am sure having rear speakers connected, as well as a center, raises the overall volume level and explains how 30W per channel (into 2ohm) can get that freaking loud. Incredible!
06-24-2010, 06:37 PM | #35 |
Rep 13,019
06-25-2010, 11:23 AM | #36 | |
Rep 3,201
I am gonna paste something in here just to clarify, because I was unclear when I initially read this original post. This is part of the OP's post on another forum, asking questions of the internal champion of this product at JBL/Harman:
I am ordering my center channel trim and adapter today. I have a center channel on hand (thanks, Quality Sound!) But now I may need to rethink amplification...unless I REALLY wanna be a control freak and stack Zapco DSP on TOP of the MS-8 |
06-25-2010, 01:56 PM | #37 | |
Rep 109
06-25-2010, 02:08 PM | #38 | |
Rep 3,969
06-25-2010, 04:58 PM | #39 | |
Rep 3,201
2 and 5... iDrive dash is "double scoop"... |
06-25-2010, 07:05 PM | #40 |
Rep 3,969
I finally figured out how to correctly set-up the underseat 8's. During x-over setup, select "2-way" front. Then the next question is to set a "high-pass" filter. The range is 20 - 100Hz. I had originally thought this was the x-over between the woofers and the door speakers, but it is actually a subsonic filter. So I set it for 35Hz and I was then able to set the correct x-over between woofers and mid/hi's at 150Hz. Now I've got some mid-bass . I corrected post #22 accordingly.
06-25-2010, 08:51 PM | #41 | |
Rep 109
Thanks, JC |
06-25-2010, 09:18 PM | #42 |
Rep 3,969
06-26-2010, 02:43 PM | #43 |
BMWCCA Member
Rep 51
Drives: '11 AW ZCP ZTP E92, '21 X5 M50
Anyone considered using a coaxial for the center speaker?
06-26-2010, 02:51 PM | #44 |
Rep 13,019
