BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Brake Light Showing
      11-12-2013, 05:26 AM   #1
LadyBoost
LadyBoost's Avatar
Drives: 07 328i BMW
2007 BMW 328i  [0.00]
Brake Light Showing
I always use my Ebrake when parking.. & one day after starting my car & putting it down the 'BRAKE' indicator wouldn't turn off.
I've tried pulling the Ebrake back up & down to see if it'd turn it off, but no success.
Any ideas on what to do?
LadyBoost
      11-12-2013, 07:32 AM   #2
petelazro
14
Drives: 2008 328xi
your brakes may need to be changed. I know when i went 100km over the indicated change time the handbrake symbol would always be there when i was driving.
did you have a count down every time you started your car indicating your brakes need changing?
      11-12-2013, 07:50 AM   #3
Hokie_BMW
Drives: 2009 335i Sedan
Yeah, this is probably because the preset brake service interval has passed. Mine did this as well.
      11-12-2013, 07:55 AM   #4
Volasko
Volasko's Avatar
705
Drives: 06 330i E90, 18 530xe G30
You probably wore out your pad sensors, meaning it is time for a BJ.... Brake Job.
      11-12-2013, 08:06 AM   #5
LadyBoost
LadyBoost's Avatar
Drives: 07 328i BMW
I didn't, I haven't noticed anything squeaking or jerking in the car at all though. It's really strange.
LadyBoost
      11-12-2013, 08:06 AM   #6
LadyBoost
LadyBoost's Avatar
Drives: 07 328i BMW
Any idea on the cost of that??
LadyBoost
      11-12-2013, 08:43 AM   #7
Rmk392
28
Drives: E92
check the brake pad life through the dash or idrive. If you still have decent pad life on the brakes, you will just have to replace the sensors (about 15 bucks each). There is one for the front and rear. In my experience, i had to replace both to be able to reset the light
      11-12-2013, 08:58 AM   #8
LadyBoost
LadyBoost's Avatar
Drives: 07 328i BMW
Thank you! This was extremely helpful! I appreciate it!
LadyBoost
      11-12-2013, 09:47 AM   #9
Volasko
Volasko's Avatar
705
Your sensors are worn because your pads are gone, that is the point of the sensors. Your car is telling you need to replace the pads and sensors (the sensors get consumed like the pads). Often the back side pad wears faster (at least on my car it did) so even though my pads looked like they had lots of life left, the pads on the other side were close to done.
brake, e90 328i
