BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > 335i brakes on 328i
      04-26-2015, 12:28 PM   #1
dhoke1
Drives: White 2009 330i
2009 328i  [8.00]
335i brakes on 328i
So I see a few people before me have posted this but with no real definte answer.
So the question was will 335i brakes fit on a 328i.
The answer is absolutely and with no headache at all. The only thing I needed to change was the caliper(w/caliper bracket),rotor, and pads obviously. Some people thought you needed to change the hub or shocks or w.e and that this wouldn't be a cheap upgrade.
I got the calipers with the brackets used on ebay for 175 shipped. and the pads and rotors for $131.
You can use the old wear sensor if it's not melted on to the old pads and you can use the same brake hose.*
* I have SS lines therefor I'm not 100% sure if the OEM will be long enough but they should be honestly.
E90Dom0.00
      04-26-2015, 12:58 PM   #2
dhoke1
2009 328i  [8.00]
I didn't do the rears because I actually just put new rotors and pads on them not to long ago and there's an ebrake issue with the rear I don't want to deal with the front is pretty much plug and play
      04-26-2015, 01:46 PM   #3
avocet
Drives: 2007 328i 2011 X5d
Really???
feuer4275.50
      04-26-2015, 02:05 PM   #4
andrey_gta
andrey_gta's Avatar
298
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
rears require hand brake shoe mods unless you have large hand brake shoes on your Knuckle.
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff
"The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is
      04-26-2015, 04:49 PM   #5
dhoke1
2009 328i  [8.00]
Yes.
      04-26-2015, 08:24 PM   #6
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
Huh? Pretty sure there has been a definite answer for a while.
The front calipers are direct bolt on, there's never been a question about that.
The problem lies in the rear. The 335i uses a larger parking brake so if you swap in the 335i rear brakes on a 328i, you will lose your parking brake. You will either have to modify the shoes by basically making a hybrid between the 328i and 335i parking brake shoes, or swap in the larger 335i parking brake mechanism, which requires changing to the 335i wheel carrier as well.
This is only a problem with RWD E90 325i/328i and RWD E92 328i. The 330i, E91, E93, and all AWD models all use the larger rear parking brake, so you can direct swap the 335i rear brakes on those cars and still have functional parking brakes without modification.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
Appreciate 5
feuer4275.50
Ali-E90378.50
POBEP367.00
E90Dom0.00
      04-26-2015, 08:34 PM   #7
andrey_gta
andrey_gta's Avatar
298
Originally Posted by VTECaddict View Post
...or swap in the larger 335i parking brake mechanism, which requires changing to the 335i wheel carrier as well.
This is correct but there is a hybrid solution too:
335i brake shoes, with a corner welded from a 328i shoes. The shoes sit on 335i backing micro plate that holds the shoe pivot point for the 335i hand brake shoes. this fits over current 328i micro plate mountingn points in the rear, at worst a hole in the 335i plate will be made that does not impact operation
BTW this micro plate rusts and it is why your hand brakes squeak when parked
So the result of this hybrid is - less welding costs, no need for bearing/knuckles/carrier, no hand break squeak until it rusts again
Appreciate 3
      04-27-2015, 01:07 AM   #8
dhoke1
2009 328i  [8.00]
Well I didn't find a definite answer so I figured I'd share. But I don't think it's all that necessary to do the rears what do you all think?
      04-29-2015, 02:54 PM   #9
JRV-F82-M4
Proud Father of a Univ. of Mich. Chemical Engineer
JRV-F82-M4's Avatar
193
Drives: 2016 F82 M4
I have a set of 335i brakes for sale if anyone wants to do this upgrade.
http://www.e90post.com/forums/showthread.php?t=1029588
Current: '16 F82 M4, Avus Blue, DCT, BavSound, Winters-19" 437s, Summers-19” BBS FI-Rs Past: '13 E92 M3-Jet Black, '12 E92 335is-Space Gray, '06 E90 330i-Jet Black, '99 E46-328i-Green, '96 E36 328is-Jet Black
      04-30-2015, 12:20 AM   #10
Route 16
I got lei'd
Route 16's Avatar
Philippines
844
Drives: '10 E90 M3
i did the stud conversion, do they need to come off before removing the rotors?
      04-30-2015, 03:13 AM   #11
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
You should be fine since the studs screw onto the wheel hub. The holes in the rotors aren't threaded.
      04-30-2015, 07:30 AM   #12
4g63turbo
30
Drives: E91 Bmw 328IT,, Vr6 mk3.5 sc
Hello, so form what I understand on my 2007 e91 328I(mine is NOT AN XI), it should be direct swap in the rear no modifications?
      04-30-2015, 10:17 AM   #13
Route 16
I got lei'd
Route 16's Avatar
Philippines
844
Drives: '10 E90 M3
Cool, I've had 335 front calipers sitting in my garage for the past few months and lazy to rebuild and retrofit.
      04-30-2015, 09:27 PM   #14
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
Yes, since you have an E91, it should have the larger parking brakes that fit in the 335i rear rotors.
Thorin117.50
      04-30-2015, 10:49 PM   #15
EJ_3
EJ_3's Avatar
Drives: e92 335i, e34 525i & e60 530i
2007 BMW 335i  [8.34]
2016 Ram 1500 Sport  [8.00]
1994 BMW 525i  [10.00]
2007 BMW 530i  [8.66]
If anyone needs or want some 335i calipers and stainless steel lines (both front and rear), shoot me a pm. Have a set sitting in my garage.
      05-01-2015, 07:16 AM   #16
4g63turbo
30
Awesome. Thank you
      09-16-2016, 08:50 PM   #17
g2
Drives: E30 24V
Used search and came up with this thread. I have a 2008 e90. Does it matter what year 335 front calipers are used?
      09-20-2016, 11:29 AM   #18
Adieu
73
Drives: 335d
Yes, BUT...WONT FIT UNDER MOST STOCK WHEELS
and most not-335i/d specific wheels will be TOO wide (wheel) or with perfectly good but utterly unuseable too-tall tires (for takeoffs, everyones cheapo goto solution)
As to most M3 wheels and many 19's, might rub without further mods...20s? SOL not on a stock 335 you dont (and afaik a 328 with 335 brakes is for all wheel fitment purposes now a stock 335)
Unless your wheels just happen to be ready for em (most of the 17s and all of the 16s are NOT), those brakes will hurt the average buyers pocketbook... A LOT
New wheels new tires? Ouch ouch ouch... e46 m3 takeoffs? Ouch ouch. Superplain worst of the worst option 335i stock wheels that somebody took off due to frustration with looks and or runflat hatred? 1) ughh, 2) still surprosingly expensive, 3) major pain cause most such sellers dont bother with things like tire iszes, never heard of offsets, etc
PS and if youve never had the pleasure, non-bmw/non-replica wheels simply wont bolt on, so thrifty bmw wheel shoppers are highly limited in options
      09-20-2016, 11:55 AM   #19
david in germany
Drives: 118i, 335i and 328i
Your post is a bit confusing. Most Oem e90 17" wheels will fit over 335i brakes.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
      09-21-2016, 03:27 AM   #20
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
All 17" and bigger non-M OEM E9x wheels are 100% compatible and interchangeable between all body styles and engine options.
Only the 16" OEM E9x wheels will not fit over the 330i or 335i/d brakes.
feuer4275.50
E90Dom0.00
      09-23-2016, 06:26 AM   #21
Adieu
73
Drives: 335d
Thought so too...
In theory not in practice.
Just wasted a LOOOOT of time on a cheap wheel wild goose chase.... ended up with 640i 18"s w/offset 30 and called it close enough, after LOADS of 328i takeoffs turned out to be utterly unsuitable
Measure those things across, and dont forget to CENTER the measurements on the middle of the hub... you need over 16 inches inside diameter, and most BMW 17's do NOT provide that... a lot of the basic designs have 15-15.5" space inside
As to 18s and 19s pretty much all clear, and 20s pretty much all dont fit for other reasons
      10-26-2017, 05:59 PM   #22
Yassssm4
13
Drives: bmw
About to do this mod on my e92 328i. With this mod does it improve braking or is it just cosmetic? Also, just to make sure I just need stock rotors,calipers (do I need to buy 335i caliper bracket or can I use my 328i) and pads to complete this? Please lmk
brake 328i, brake 335i, caliper paint, rotors
