BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Some wiring diagrams for the members
      10-06-2010, 12:27 PM   #23
radeohedca
32
Drives: 2013 320i
Radio MUTE wire E90 w/NAVI-iDrive
I am attempting to wire a Parrot Bluetooth adapter into my 328i. It's easy to do if you have the plain Jane stereo using an available ISO cable adapter but the same is not available for the more complex NAVI equipped audio controller. So I need to splice into the system manually. Among other issues, I cannot locate a MUTE wire in the audio controller harness (or anywhere else). Can someone tell me if there is one available somewhere in the front ?
Another issue is that the Parrot relay control box wants to deal with speaker level audio (already amplified) so I would need to work with the wiring coming off the amplifier in the boot which I want to avoid. The Parrot unit *does* have a pair of line level audio outputs. Is there a simple way to integrate them into the line level wires coming out of the NAVI audio controller ?
Any info/guidance appreciated.
Thanks.
      10-09-2010, 11:03 PM   #24
TommyLights
213
Drives: Man
Thanks.
Did you ever get a response to this? I have the same problem.
      10-16-2010, 05:37 PM   #25
TommyLights
213
Drives: Man
No one?
      10-18-2010, 07:14 PM   #26
TommyLights
213
Drives: Man
Thanks.
I have logic 7 with Navi, same as you, on my 07 E92. To get the mute working, I had to solder a lead onto pin 10 on the back of the headunit. I then attached a wire, and ran that to the mute wire on my Parrot.
It worked like a charm. When the Parrot is being used, it auto mutes the headunit for the duration of the call.
So for anyone that has Logic 7, you CAN tap into mute! Almost every response on the forum was a negative, so I am glad I did the work.
As far as the wiring, no way for me to avoid, so I bit the bullet and ran the wiring from the amp. It took about an hour, but it works perfectly. You can only use the line level audio to listen to music, but I guess you could also use for calls if you dont mind switching your source to AUX every time a phone rings.
      12-08-2010, 11:42 AM   #27
glamprecht
glamprecht's Avatar
Drives: 330iE90, F15X5, F25X3, F15X5
I have installed a Logic 7 Amplifier in a car with standard audio. It all works except I dont know where to connect the power to. Can anyone help me?
I measured the current during sleep and it was 270mA which is way too much. So I presume that it is switched through a relay in the JBE. I want to know which fuse, which relay in JBE.
Anyone with info please.
Thanks
Jun 2006 330i Manual, Active Cruise, Comfort Access, Nav prof, Voice, Bluetooth
      12-08-2010, 03:05 PM   #28
Imperator
Imperator's Avatar
Drives: 2010 E92 335i
I'm looking for a RAP (Retained Accessory Power) lead to tap into at the rear of a 2010 E92 with base audio. This will be used as a remote turn-on lead for an aftermarket amplifier, as the car wasn't originally equipped with one.
What modules, harnesses or wire colors should I look for to find a RAP lead, not just linked to ignition?
      01-14-2011, 11:22 PM   #29
FUS550
FUS550's Avatar
Drives: 2013 E92 M3
2010 BMW 550i  [0.00]
2011 BMW M3 E90  [10.00]
Thank you Technic and MuPhud! I was going nuts this past week trying to figure out the new AMP input colors. Now I can finish my install.
I will use an Infinity Kappa4 to replace the factoryAMP and an Rockford Fosgate to power the SUBS.
      04-11-2011, 06:45 PM   #30
shebal
Drives: 2008 BMW 335xi Coupe
Question
Forgive me if this is a stupid question but I was wondering which wire the switched power (accessory) source was? Where do i wire the switched power wire on my aftermarket radio?
I've installed multiple car stereos in japanese and domestic cars but this is the first time I'm attempting to install a double din navi unit in my 2008 bmw 335xi coupe.
Any help would be greatly appreciated. Thanks guys.
      05-02-2011, 09:45 PM   #31
rcanglin
Drives: 2006 330i
http://pdfcast.org/pdf/e90-ent-and-comms
i found lots of useful here on E90 Entertainment and Communication systems. it doesn't get down to wiring diagrams, wire color, etc...but answers many of the general questions asked repeatedly.
      06-12-2011, 05:31 PM   #32
gtaphile
Drives: BMW235i 2014
is it logic7 or not?
I just drove a friends 07 335i coupe with logic 7.
My 07 335i sedan from the US has logic7 on the amp front, what looks to be two harnesses, one fibre optic and the multiwire set-up. Further I have a centre speaker on the dash, sub covers but no sub under the seats.
What system do I have?
Of course my goal is to upgrade to atleast the logic7 system.
Any help would be appreciated.
      07-02-2011, 09:21 PM   #33
FUS550
FUS550's Avatar
Drives: 2013 E92 M3
Here some pictures from my install!
did the speaker upgrade with Bav Sound and 2 Earthquake subs.
Amplifiers I use are Rockford and Infinity Kappa 4.
Sounds really good!
      07-24-2011, 05:26 PM   #34
bmwkev
Drives: 2006 bmw 325i
good job, thanks!
      08-08-2011, 05:10 PM   #35
tuningas
Drives: bmw 335i chipped
hi how i can install an amplifier if i do not have original one?pleasse help me..i have 2007 e92 335i coupe..it has subs under the seats in the front..in the boot it comes just a plug which should be conected to original amp
      08-08-2011, 07:54 PM   #36
1MEAN3
Drives: 2008 3.28i
where exactly did you get this information its really good!!!
      08-10-2011, 04:27 PM   #37
tuningas
can anybody help me with this one?so maybe i need to buy an original amp and then make line out into an non original amp?
      08-10-2011, 04:28 PM   #38
tuningas
Angry non answered question
      09-03-2011, 10:28 AM   #39
DieselDiner
DieselDiner's Avatar
486
Drives: 335d
I don't have the answer, but I suggest you start a new thread in the audio section. Your question will get many more views and most likely a solution as well. Good luck!
      09-04-2011, 03:15 PM   #40
gtrokin330
Drives: TT
Does that hifi diagram apply to my 2011 e90 with stock sound system?
      10-18-2011, 08:09 AM   #41
monal85
Drives: Very good
Hi
This was the froum i was looking for where i get the proper image to see damage wire. How can i avoid it from being damage.
      11-06-2011, 10:00 AM   #42
rhm
Drives: BMW E93
looking for cables for my new amp
Hello guy,
i'm installing an amp with 1 sub in my bmw e93 from 2007
and looking for the right cables.(I need to find the input for my new amp)
Can anyone help me with this?
I dont have a amp in my car, it comes all on the head unit.
thank you!
      11-07-2011, 03:14 PM   #43
rhm
Drives: BMW E93
anybody ?
      01-07-2012, 02:44 PM   #44
Billt335
Billt335's Avatar
Drives: Black 335i coupe FBO JB4/Meth
2008 BMW 335I  [8.50]
So if I am installing a after market amp on my 08 e92 with logic 7 system what wires should I tap into for the hi input?
