TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      01-13-2019, 10:48 PM   #1
LSX5
32
Drives: 2012 X5 35d
2012 x5 35d burning oil
A few weeks back I got a warning light to add more oil so first I check my dip stick and yes the oil was on the low end. I add about half quart of bmw diesel oil and that brought it up to 3/4 full.
My SAV has 111k on it. Is it common for diesel's to burn oil? I never has to add oil before. I had the SAV since 30k going on 5 years.
I do not have any oil on my driveway so I am assuming it is getting used up. I haven't got a chance to check under it just yet for leaks but no
spots on driveway.
      01-14-2019, 01:05 PM   #2
M5_1of400
M5_1of400's Avatar
Drives: 2018 M5 / 2011 X5 35d
spots on driveway.
Yes, you will need to top it off after 6-7K miles after an oil change.. you have to add 1 quart to get it to the max level again. Totally normal.
      01-14-2019, 02:38 PM   #3
spurcap
Drives: 2006 330i 2012 x5 35d
I normally burn about a half quart between oil changes so never have to add oil between them. But using slightly more oil than should not be a significant concern, I wouldn't think.
      01-14-2019, 02:57 PM   #4
0590plazaj
Drives: 2012 X5 XDrive50i M Sport
2012 BMW X5  [0.00]
Very common on all E70 model years
      01-14-2019, 04:00 PM   #5
LSX5
32
Drives: 2012 X5 35d
thank you guys for the info.
I never had any issues before with oil. This just started .
      01-14-2019, 05:09 PM   #6
M5_1of400
M5_1of400's Avatar
It all depends on how old the car is and the maintenance.. older car tend to burn more when your turbos, valve cover gaskets, oil pan or other parts start leaking then you'll find yourself topping off your oil more often
      01-14-2019, 05:11 PM   #7
LSX5
32
Drives: 2012 X5 35d
mine is a 2012. Started a few weeks back
      01-15-2019, 03:13 PM   #8
heatmizr
Drives: E70 X5 50i M-Sport
What, no oil-burner jokes yet??
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e70 X5 50i M-Sport "The Boss" Loaded
e90 328i - sold
e36 M3 - Gone to become a track star
      01-17-2019, 07:55 PM   #9
spurcap
that's funny. I guess we assumed OP was talking about engine oil and not fuel oil!
      03-28-2024, 01:57 PM   #10
hartwa
Drives: 2011 335d
I have a 2013 X5 with a 35d fully deleted...196000K miles.
It and it starts up with a cloud of blue smoke. It was using a qt every 2000 miles, burning and leaking oil....I changed the VCG and got rid of the leaks...now it just uses oil at the 1 qt / 4000 miles.
That is probably not bad considering the miles on it but I feel now blow by in the valve cover when I place my hand over the oil cap.
If it is not below by is it the turbo seals?
      03-29-2024, 01:16 PM   #11
Mika75
Drives: BMW X5 M
burning a lot of oil a quart every 250-300 mi
hi guys, how much time do you think the engine on my X5 has left? I'm adding now a quart every 250-300 miles, I have to travel with a jug in the trunk ;-).
Is there something else I could do to keep it running longer. I'm not going to replace the engine, I'll just drive it till it dies ;-).
      03-29-2024, 01:17 PM   #12
Mika75
Drives: BMW X5 M
oh I didn't mention its 2013, 70, 105.000 miles
      03-30-2024, 10:52 PM   #13
LSX5
32
Drives: 2012 X5 35d
Turbos could be burning oil as well, you could check gaskets around throttle body, you may also have a leak around charge pipe.
xbimmers
