TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Raceland Coilover review
      06-13-2020, 02:51 PM   #23
Silnismo
226
Drives: BMW 325i
Originally Posted by kazbek1 View Post
Originally Posted by Silnismo View Post
Exactly, for DD purposes these are a solid option.
Def pick up a set if your not tracking your car.
Looking back at the installation process, was there anything you replaced that wasn't included in the Raceland kit or wish you had replaced? I'm about to pull the trigger on the Classic kit but not sure if I should replace other components like strut/shock mounts, gaskets, etc. Clean ride btw
@kazbek1
No regrets, I also replaced the front strut top mounts and the rear lower shock mounts when installing the coilovers.
I would recommend you do the same too.
      06-13-2020, 03:00 PM   #24
Silnismo
226
Drives: BMW 325i
Quick update, I have about +10,000 miles on it so far with plenty of trips to NYC and MA.
Still holding up great, still handle like the day I put them on. It did take a good beating on the NYC roads but still no leaks or clunks.
Again for 350$ (Black Friday sale) can't beat the value.
      06-14-2020, 03:52 PM   #25
kazbek1
kazbek1's Avatar
Drives: 2007 335i
@kazbek1
Great! I just got them in and did buy the top and lower mounts. Glad to see you like them. Are you happy with the 10mm spacers? I'm keeping my stock wheels but want to push them out a little purely for aesthetics. I've heard 15mm and 25mm spacers look good but also won't have larger, meatier tires so not sure if I should do it. Any advice?
      06-14-2020, 09:02 PM   #26
Silnismo
226
Drives: BMW 325i
@kazbek1
Yeah happy with the spacers, purely a cosmetic mod.
I have turner 10mm in the fronts and ECS 12.5 in the rear.
      08-06-2020, 03:49 PM   #27
Silnismo
226
Drives: BMW 325i
8 month update to this day and they still ride great.
Still holding up nicely, no weird noises and drives smooth.
      10-18-2020, 12:36 AM   #28
FourWeeks
Drives: 09 E91 328i
Do you know what offset your wheels are?
      12-09-2020, 11:37 AM   #29
Silnismo
226
Drives: BMW 325i
They are stock style 162s, made up of 4 x rear tire setup of 18 x 8.5
      12-09-2020, 11:44 AM   #30
Silnismo
226
Drives: BMW 325i
It's been almost a year and they are still holding up nicely. The shocks still rebound as if the first day I got them, they still perform great around the corners and smooth on the highway.
I drive daily on NYC roads and they take potholes and harsh roads nicely.
Absolutely no complaints at all, very happy i went this route.
      01-27-2021, 11:27 AM   #31
whyzee125
Drives: Dinan stage 2 335i
I had Raceland coilovers on an e46 back in the day and had no issues. Rode very similar to stock and never leaked.
I went for ST on my next e46 and honestly felt that the racelands were more comfortable with similar handling.
      05-23-2021, 11:25 AM   #32
Silnismo
226
Drives: BMW 325i
Putting in m3 rear arms, inspecting the coilovers and they still look like they are holding up. No leaks, still handling great!
      05-23-2021, 04:09 PM   #33
Luis561
95
Drives: 2007 335i e90
Glad they worked out for you, a lot of people talk bad about them because they're cheap. It's been almost a year that I've had them on and they are bouncy sometimes but they're great for the price. I got the últimos because I wanted to go pretty low. Also on 10mm spacers in the front because they will rub on the wheel. 15 mm in the back but no rubbing, only for looks
Silnismo225.50
      05-23-2021, 04:10 PM   #34
Luis561
95
Silnismo225.50
      05-23-2021, 11:36 PM   #35
Silnismo
226
Drives: BMW 325i
Nice ride!
Yeah I'm surprised on how good their durability have been so far.
Great beginner coilover.
      05-24-2021, 05:30 PM   #36
aphael
Drives: E92 328i 6MT
2007 BMW 328i  [0.00]
People will say whatever but it depends on what your usage is. If you are just daily driving and want to look low, these will do fine. Other than a lower CGI I do not think these are actually helping in performance especially if you do any hpde, autocross.
2007 E92 328i 6MT | KW V3 | 3SI | SSR Type-C 18x9.5/10.5 | AA Headers
      05-24-2021, 06:36 PM   #37
Silnismo
226
Drives: BMW 325i
Agreed, I don't plan on doing anything outside of daily so it works perfectly for my needs.
Also value wise it's hard to beat, $400 and a real lifetime warranty. Considering I'm 17 months in with no defects or leaks speaks volume.
      05-25-2021, 03:39 AM   #38
aphael
There were koni yellows which have a usable rebound only adjuster and lifetime warranty as well at around 580 not too long ago. But yeah they are much better value than the 600$ coilovers like megans which ride very bouncy.
      05-25-2021, 06:54 AM   #39
Tambohamilton
Drives: E91 330d
That gaiter is annihilated...
Glad you're happy with them though
Silnismo225.50
      05-26-2021, 04:59 PM   #40
Silnismo
226
Drives: BMW 325i
I actually came from Koni's they rode great for couple months before they blew, they covered the replacements but that's when I went with Racelands instead.
Difference wise not much of a difference, I had the Koni STR. Both pretty soft setups.
      11-16-2021, 12:44 PM   #41
Silnismo
226
Drives: BMW 325i
Update.
So just got my car back from the BMW dealership and that have found that the rear driver side shock is blown and driver side front sway bar link they provided snapped and was dangling freely smh.
Contacting raceland for warranty replacements, keep y'all posted
      11-16-2021, 03:13 PM   #42
Silnismo
226
Drives: BMW 325i
Hassle free replacements on its way! Quick and easy
      09-14-2022, 12:15 PM   #43
Silnismo
226
Drives: BMW 325i
Finally came to installing the replacements and the old ones were definitely toast.
      09-20-2022, 11:36 AM   #44
Maxmax73
15
Drives: 2011 328i
Well, it happened just like we all expected.
