TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      08-14-2023, 06:56 PM   #67
JellyStyle
Builder of Special Cars
JellyStyle's Avatar
202
Drives: G12 B7,F02 750li,E70 X5M,E46M3
Location: Dallas, TX | Farmington, UT | Gainesville, FL
Originally Posted by 9kracing View Post
I'm in for a S63 kit
and its all similar but ur on your own, because I am doing a custom CCV for my S63 too with Troy, with no cross over junk tubes.. Why are you in such a rush, i think he can get this done in the next week or two.
If you have all the parts, you can do it as well, did you get the catchcans already, and all you need is the adapters for everything?
Joe
      08-15-2023, 09:08 AM   #68
punisher12b
32
Drives: 2011 135i
Originally Posted by Sophisticated Redneck View Post
Now assemble the -6AN to 1/8"NPT adapter that will fit on to the lower Intake CCV tubes on each side of the engine. I recommend purchasing a 1/8" NPT drill and tap kit off amazon as this connection is critical and will be under pressure during boost and you want the 6AN adapter to fit very securely.
So working on this...
Looking for this fitting on an S63 .... just trying to be fully prepared when I get back to it tomorrow. can anyone tell me where this bad boy is It looks like its comes off the intake But when i was digging around yesterday I didnt see it unless I was distracted with other things.
      08-15-2023, 10:51 AM   #69
JellyStyle
JellyStyle's Avatar
202
its all in this thread. Its not simple, because S63 shares the vent across, why i suggested to just wait 2 weeks so Troy can show you how he is doing mine, then you will have diagrams.. Or you can try to read all this and follow it, but its all plastic tubes and junk, you need to go with AN10 lines.
Sophisticated Redneck will come through and even send you just want you are missing to make it work, if you can post what parts you already have.
      08-15-2023, 01:26 PM   #70
punisher12b
32
Drives: 2011 135i
I do appreciate.. your support of Troy, But I am severely limited on TIME, I am using this as a stop gap measure till I get settled after my move ( pretty solid rear main seal leak and valve cover leak)... I have everything purchased... Per troys orginal Post ... I now just need to figure out 2 last things...
1. do the S63 intakes need to be removed..
2. where do I tap the 6an to 1/8th NPT into so I can run the lines... as they are different than N63...
I dont think I need any parts left to make it work I just need to confirm locations before I hack something and am left with the car unable to operate..
      08-15-2023, 01:27 PM   #71
punisher12b
32
Drives: 2011 135i
Originally Posted by JellyStyle View Post
Thanks so much for the help and clarification, I ordered all the parts per your post about the mod.
Could you send me this PM please.?
Sorry the PM where troy send you more information on the S63?
      08-17-2023, 11:59 AM   #72
JellyStyle
JellyStyle's Avatar
202
THis is what we're doing, you can go with plastic but we have nice AN fittings to make it look real. I will send you a PM, but the S63 CC do not work well, because of the shared tube, its all over the web that only the drivers side works, and little oil in the passenger, hence why Troy and I are building isolated CCVs for each side of the motor.
      08-17-2023, 01:08 PM   #73
punisher12b
32
Drives: 2011 135i
very nice looking and I respect that maybe there is something I am not getting.. going to the n63 setup that troy outlined.. Is that not an isolated system? as there is no crossover?
      08-17-2023, 01:35 PM   #74
JellyStyle
JellyStyle's Avatar
202
N63 does not have a crossover system.
S63 does and the passenger side will not catch any vapor, its documented all over the web. You have to convert a S63 system to an isolated system for the CCVs to work correctly and catch on both intakes.
      08-17-2023, 05:34 PM   #75
punisher12b
32
Drives: 2011 135i
No need for the crossover tube when you install the catchcans, I sent ya a PM with more info and will dig up the pics on where to cut the CCV lines on the s63 and send to you and post them in this thread also for reference for anyone else thinking of the mod.
OK so I will rephrase what I asked, If you follow the instructions outlined here.. it removes the crossover.. does it not then isolate the the two banks?
I get you say its well documented over the internet.... but could you answer that question.. on the install that I did I removed the crossover, and tapped the line pulling vacuum on the passenger side..
So I ask again. how is my system not isolated?
TTV8M123.50
      08-17-2023, 05:56 PM   #76
punisher12b
32
Drives: 2011 135i
BTW im not trying to be a jerk or stubborn I truly want to understand this.
      08-17-2023, 06:05 PM   #77
JellyStyle
JellyStyle's Avatar
202
this is the isolated setup. just an eyesore for what i would do, hence why we are doing an OEM look style, but you have it right, they are isolated, did you set the vacuum right? next is to see if both sides collect the same amount of oil at each interval of oil change.
      08-17-2023, 06:35 PM   #78
punisher12b
32
Drives: 2011 135i
Well thank you for the backhanded insult,
Yes vacuum is now set to -9
yeah a few rando connections cause I didn't check my amazon order.. and i needed to make adjustments its what the speed shop had... so as opposed to be sitting there without a car I finished it...I will clean it up when I get moved at the end of the month... but it was more important to get it on the road and running so I could get to my divorce attorney who notified me while I was working on it my X finally sent a reasonable separation agreement soooo crazy underhood and cleaning up later is WAYY worth to be divorced asap...
TTV8M123.50
      08-17-2023, 06:41 PM   #79
JellyStyle
JellyStyle's Avatar
202
Well thank you for the backhanded insult.
didnt mean to insult, but i hear you on getting the underhood hoses and their lengths shortened so it looks better. Bummer on the divorce, i think more andmore people are starting to realize the disney channel matrix dream is the biggest con of them all.
Date in chapters, for the rest of your life, happy for life.. Matrix is a powerful machine to sell more rings, dresses and status.
      08-17-2023, 07:22 PM   #80
punisher12b
32
Drives: 2011 135i
Thanks.. sometimes life works out that way..
On to my oil leak guessing game. lol I just dont have the time so I left it a buddys shop.. I have to move from D.C to TN on the 28th... sooo hope what ever it is we can get the parts for.
I started a fun thread lol
      08-17-2023, 07:28 PM   #81
JellyStyle
JellyStyle's Avatar
202
the leak can be either lower or upper oil pan, if you do either, you'll need to and want to tighten the oil pump chain, how troy explains it too. unless you got a turbo oil return leak (from the return cover)
      08-17-2023, 08:37 PM   #82
punisher12b
32
Drives: 2011 135i
I am leaning to return lines..
if i romp on it ill drench the belly pan and the oil gauge will drop 1/4
I know i have a rear main seal and valve cover gasket leak... gonna get my buddy to bore scope it tomorrow.
      08-19-2023, 08:43 AM   #83
punisher12b
32
Drives: 2011 135i
Now connect the braided lines to the lower intake CCV adapters and snap in to the stock lower intake CCV lines. I also have adapters installed that allows for pressure sensors to be connected for dual boost gauges in this picture.
more questions.
the gauges all of them I found seem to use what I am used to vacuum lines to read the +/-
and we need to run 2?
This picture though shows an electrical connection on the barb?
also whats your ebay store I was gonna see if I can grab a vent pod mount
      08-21-2023, 07:50 AM   #84
JellyStyle
JellyStyle's Avatar
202
Another update on the best CCV setup for any BMW Motor.
Master Genius Troy is nearly complete with the project. Anyone interested in a real system, that looks OEM, and has the performance to back it up, post here, Im sure would be great to get his hard work out on the street.
Joe
      08-21-2023, 08:27 PM   #85
REVELDE_89
Drives: X5M
meeeee for a 2018 x5m, TAKE MY MONEY!
      08-22-2023, 08:05 AM   #86
Lilian242
Drives: Bmw X5M E70
  [0.00]
Where i can buy catch can s63 kit ?
      08-23-2023, 12:45 PM   #87
JellyStyle
JellyStyle's Avatar
202
PM Sent, i will help you get in touch with the master
      08-23-2023, 05:02 PM   #88
NoVA_X5M_98M3
Drives: E36 M3, E70 X5M
Please PM me too!
xbimmers
