TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      03-19-2024, 02:35 PM   #1
StilesE70
Drives: 2011 E70 X5 35i
Climate control panel and tilt wheel stopped working. 2011 e70 x5
Hey guys, I saw one other guy post about this a couple years ago, but didn’t see an answer. All of a sudden my tilt wheel went to the starting setting, and won’t move. and my climate control panel went dark, no buttons working. I checked the fuses and they are connected I believe in the #1 fuse spot, but I checked and even replaced the 20a fuse and it didn’t fix it. Any ideas?
      03-19-2024, 09:30 PM   #2
M57kevin
M57kevin's Avatar
Drives: 2011 BMW E70 Diesel
  [0.00]
My in/out wheel motor stops working when it gets really cold outside, and once it warms up it starts again.
Sometimes, you can tilt the wheel all the way up and then all the way back down, and it will start working again. If yours isn’t going up/down, try doing this but in the other direction. No guarantee but it’s worth a shot 🤷‍♂️
      03-20-2024, 10:42 AM   #3
StilesE70
It’s not the actual tilt function I don’t believe, because the climate control panel won’t work either. Something loose electrical I’m guessing, just don’t know where to look.
      03-20-2024, 12:03 PM   #4
askjeeves
Drives: e92 m3/spece30
Have you checked fuses? If I am looking at the right diagram online, fuse 1 should send power for both steering wheel tilt and ac.
Other fuses listed for these
Steering wheel 1,134
Ac 1, 17, 18, 48, 98, 126
2011 e92 ///m3 zcp - jzb/fr
ED 6/29/10
      03-22-2024, 12:43 PM   #5
StilesE70
Turns out it’s a bad IHKA, which is the climate control panel itself. This also feeds the tilt wheel motor. $1200 new from BMW and needs to be programmed to the car. 🙄
xbimmers
