BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Upgrade 328I brakes to 335 specs?
      03-09-2015, 06:30 PM   #89
justpete
Drives: '11 328i '19 M6
2019 BMW M6  [10.00]
2011 BMW 328i  [9.00]
Originally Posted by vwetish View Post
the 135 setup is inferior to f30 370mm fronts.
But the real question is do you need them? I'd rather have less unsprung weight with more than enough stopping power. And it's pretty cheap too I think.
Either way, whatever works.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
      03-10-2015, 07:07 AM   #90
vwetish
Drives: e90 335i
Originally Posted by The HACK View Post
The end result, is ANY of the BMWs that uses the same e-LSD design ('07 or later none legacy chassis*) that is tracked regularly will use up the rear brakes faster due to the e-LSD that can't be disabled.
Not to highjack this tread but I still can't figure this out. I drive 4/2008 335i mt which can spin only one of the wheels endlessly My assumption is that is doesn't functions beyond certain speeds.
      03-10-2015, 07:21 AM   #91
vwetish
Drives: e90 335i
335i is heavier and a lot faster than 328i. Not to mention tuned 335i for which if tracked bigger and better brakes are a must. Stock for stock 335i brakes are better and bigger than 135i. So regardless if it is affordable or not I highly doubt that 335i owner will go for 135i brake swap. It would be like downsizing the 335i engine to 328i levels and than modifying it to get the 335i output. Is counter intuitive. You are better off making the stock 335i brakes more hard core upgrading the bushings, rotors, pads, brake lines and brake fluid than investing into any 135i setup. That is why, even for those who are frugal, I recommend the f30 setup.
      03-10-2015, 08:28 AM   #92
justpete
2019 BMW M6  [10.00]
Completely agree. But I wasn't talking about brakes for a 335i. And the thread is about upgrading 328i brakes not 335i brakes which is the subject I was responding to.
      03-10-2015, 09:21 AM   #93
vwetish
Drives: e90 335i
Same difference. if you are already upgrading and spending money might as well go with better product straight out of the box which makss 135i brakes on any e90 redundant in my opinion.
      03-10-2015, 10:04 AM   #94
justpete
2019 BMW M6  [10.00]
No argument. But I'm more concerned with handling so the lighter choice is the better choice, thus the move to investigate RB rotors. The lightest brakes that provide as much torque as the tires can deal with and which won't overheat is then the best solution for tracking, imho. Just passing along this observation. Naturally YMMV.
      07-06-2017, 12:59 PM   #95
NiNeTyOne
Touring cars rock
Drives: e91 330xi / 997 GT3 Cup
Everyone does realize that any of these upgrades being discussed require a coding change in order for the brakes and stability management to function properly, right?
Sportwagon Daily: I've done some stuff.
      07-06-2017, 02:14 PM   #96
Smokey33
72
Drives: 2009 Black 335i DCT FBO
I had F20 340mm fronts fitted to my 335i last week and heard nothing of this. Brakes work great.
Why would it need a coding change?
      07-06-2017, 05:05 PM   #97
NiNeTyOne
Touring cars rock
The hardware bias has changed and the EBD has to know about it. Otherwise you're not going to have the correct ratios for bias in the ABS module.
There is a factory setting for the Performance brake kit, it completely changes the pedal feel and if you were to drive the car in an environment where the EBD and the stability programs come into play (think snow or ice) the difference is night and day.
I've been upgrading brake sstems on cars with EBD and stability management for years and you simply cannot do it correctly without a coding change.
      07-10-2017, 08:50 PM   #98
caldep
caldep's Avatar
97
Drives: 325xi Touring MT X1 x28i
2023 X2 F39  [0.00]
2022 X3 G01  [0.00]
2006 e91  [10.00]
NineTyOne
I'm about to upgrade the brake on my e91 325xi 6mt to the 335 brakes. I picked up a set of fronts and backs used.
1. You mention EBD coding change. What is involved with this (I hope my local BMW performance center can handle this).
2. Trying to decide whether to get remanufactured calipers prior to installing. I'm on the fence as to trying the calipers out or just buying new and using these for core charge.
Any Thoughts?
2006 325xi touring MT! Joy 2 Drive
      07-11-2017, 01:06 AM   #99
david in germany
Drives: 118i, 335i and 328i
Originally Posted by caldep View Post
NineTyOne
Any Thoughts?
hate to say it but you may have wasted the money on the rear brakes. You only need the front set. I don't think the parking brake of the 325 will work with the 335i rotor.
As for your questions.
1. You can use BMW standard tools and update the VO to +SPBR or the actual official coding with ISTA which will reset the steering angle sensor, DSC and the brake bias.
2. if you are worried, order the parts and rebuild them yourself. $27.36 per caliper
https://www.ecstuning.com/b-genuine-...t/34116769090/
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
      07-11-2017, 03:37 AM   #100
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
touring and xi use the same parking brake size as 335i, so he's good.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
feuer4275.50
caldep96.50
      07-11-2017, 05:33 AM   #101
david in germany
Good to go then!
feuer4275.50
caldep96.50
      07-11-2017, 02:08 PM   #102
Ginobass
Drives: 2010 328i Coupe
I have all the 335i brake parts to convert my 328i. Calipers rebuilt, painted, carriers, stainless lines, dust shields, rotors, the whole banana. This coding thing has me dead in my tracks. I researched BMW standard tools - holy freaking hell, what an ordeal to install and get the thing working!!! I'm no computer science major. I'll probably put all the parts up for sale and scrap the project. Crapola.
      07-11-2017, 03:41 PM   #103
maddmatth
New Zealand
555
Drives: F82 M4, E92 335i
There are people that can do it remotely or you, you'll just need the cable and give them a way to remotely access your laptop (Teamviewer, Anydesk or something). Don't give up due to that
      07-11-2017, 07:26 PM   #104
caldep
caldep's Avatar
97
2023 X2 F39  [0.00]
2022 X3 G01  [0.00]
2006 e91  [10.00]
Thanks VTE and David! That's great news.
BTW David, I too name all my cars. My wagon is named 'Maxx' after Maxwell's Demon!!!
      07-12-2017, 12:04 AM   #105
david in germany
Nice!
      07-13-2017, 11:52 AM   #106
Ginobass
Interesting, I will have to look into that. I wonder how I can find someone who can do it remote....
Thank you, there's hope!
      07-15-2017, 05:07 PM   #107
Aus335iguy
Aus335iguy's Avatar
Australia
650
Drives: 2009 e92 335i MSport DCT
2009 BMW 335i  [10.00]
What change would you recommend ? Is it just VO +SPBR?
I'm about to upgrade my 335i to the F30 m performance kit (370 mm) and I am weary about the effect on DSC.
For those of you looking to upgrade to 335i brakes, I'll have the whole set available here in Sydney in a few weeks
When you doppelkaplung you doppel your fun.
      07-15-2017, 05:58 PM   #108
tdavis42
tdavis42's Avatar
181
Drives: 08 E90 328i ZSP AT
2008 328i  [0.00]
Try BimmerGeeks they did remote updating for me and it was quick and painless.
      07-17-2017, 12:47 PM   #109
3002 tii
3002 tii's Avatar
2286
Drives: Z4 M, X5, GX460
I upgraded to 335i brakes all 4 corners and didn't code a single thing and car drives and stops fine.
Follow for latest mods
      07-17-2017, 01:42 PM   #110
feuer
feuer's Avatar
Drives: wife crazy!
Me too as have many others. After over 4 year and probably close to 50 track days I haven't notice any adverse effects.
