No Power on Radio: Help
07-14-2012, 01:17 PM | #1 |
18
Rep 88
I turned on my car yesterday and I have no power on my radio. I do get the sound warning for the passenger seatbelt / open doors.. etc so the spearkers work but I have no power on the radio/cd player console. The display on the console also does not work. I tried all other electronics including the AC and AC display, they all work fine.
I read a couple other posts about this problem but could not find a solution. Please help. 2006 E90 330i, no iDrive |
09-15-2012, 11:01 AM | #3 |
Rep 13,103
FYI
http://www.google.com/url?sa=t&rct=j...AV5DNDYaEl0b8Q
Check to see if your battery is OK especially if you have and 06 or 07 Read the article above for info on how the electrical system and ibs works. |
09-17-2012, 03:15 PM | #4 |
18
Rep 88
Problem Fixed
09-18-2012, 02:35 PM | #5 | |
Rep 842
http://www.e90post.com/forums/showthread.php?t=642881 I don't consider disconnecting the battery as a fix. Have you found a permanent solution?
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50 |
09-18-2012, 11:50 PM | #6 | |
18
Rep 88
Have you checked your fuse? One of mine was placed wrong too which I corrected. Maybe that was what initially caused the problem Last edited by 90SLOWE; 09-19-2012 at 12:02 AM.. |
09-19-2012, 12:46 PM | #7 | |
Rep 842
I still see this issue recurring and I somehow doubt it's a fuse since resetting the radio by disconnecting / reconnecting the battery always works for me. My sense is that it is a turn on voltage transient issue and could be either the radio or the battery. I suspect the radio since my car is a 2009 and the battery should have another couple of good years.
iStep 03/2023.50 |
09-19-2012, 01:17 PM | #8 | |
18
Rep 88
02-12-2018, 04:47 AM | #9 |
Rep 10
I have something similar, can any one help
2010 320d Non iDrive, No Radio Display(no power tried holing menu for 10 sec n all), PDC is also off, steering mounted control also not working. AC unit and other functions are working. Tried battery connector removing for a while. Check fuses too but does not seems working. Any body has face similar issue of Radio Display, PDC and steering wheel control not working ?
02-12-2018, 11:17 AM | #10 |
Rep 13,103
Battery's last an average or 6 years in these .
The IBS system can cause all kinds of unrelated problems when the battery is low. Read about the IBS in the first electrical pdf electical e90 pdf http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja http://www.google.com/url?sa=t&rct=j...85464276,d.cGU http://www.google.com/url?sa=t&rct=j...85464276,d.cGU |
02-19-2018, 01:17 PM | #15 |
456
Rep 2,749
you can bus is damaged in some way and so some units cannot communicate
therefore radio is not activating without can bus
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
03-01-2018, 01:13 AM | #16 |
Rep 10
Thank ptpending for your reply. Can you guide me how to check 'can bus'.
I removed Audio system (Alpine Model C73, P/No. 65.12-9 205 962, e24) and on back of sound system there is 10 amp fuse, checked conductivity its fine. Also try to check voltage on sound system connector but no power. kindly guide me further. Thank you.. |
03-01-2018, 06:04 AM | #17 |
456
Rep 2,749
ok then you need to check 14, 15, 18, 19, 27,42,56,63 fuses
03-07-2018, 04:05 AM | #18 |
Rep 10
I have checked fuse. only fuse in 14, 19 and 63. All conductivity okay and even showing voltage aswell. 15,18,27,42,56 are empty. If get it scan will it help to identify issue. pl guide me further. Thanks
03-09-2018, 04:18 AM | #19 |
Rep 10
I went to local shop, they check everything. there was something wrong in power supply in audio system, took almost $100.00 and got it fixed. Finally its working Thank God..
That technician told from side panel of audio, led light will be visible. if thats not working then something wrong with radio system itself. |
08-31-2018, 08:49 PM | #20 |
Rep 1
Help
Hey Christian,
I have the same issue you have described. Can you elaborate on what the mechanic did you get your radio working again? I have no LCD display or power at the radio and no optical lighting at any components i.e. radio, satellite amplifier, etc. |
08-27-2019, 08:45 AM | #21 |
Rep 1
i'm having the same exact problem after i installed my second line out converter for my amp. anyone know what could be going on? my backlit buttons come on but the screen is totally blank
08-27-2019, 11:50 AM | #22 |
Rep 13,103
Step one there is either power to the Radio or not
Radio has a fuse on the back and one in the cabin fuse panel. If you have a low battery the IBS may be turning off power to the Radio. If you have done the above checks and there is power on the Radio connector and it doesn't turn on then its the radio. IBS system can turn accessory's such as the Radio off if it detects a low battery or is defective. Read first pdf electical e90 pdf http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja http://www.google.com/url?sa=t&rct=j...85464276,d.cGU http://www.google.com/url?sa=t&rct=j...85464276,d.cGU |
