BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > BMW F30 335i M-Sport Before and After coil-overs
ARMA SPEED
      03-22-2013, 08:58 AM   #111
Maz335i
BMW 4 Life...
Maz335i's Avatar
149
Drives: 2015 SO M3 (on order)
Originally Posted by RC@PSI View Post
That's correct.
Thanks!
I plan on buying the BC Coilovers off a friend of mine who's been driving the car with these coilovers for roughly 6 months or slightly more...I understand these coilovers should be good for about 60,000 miles.
After that, what do I do with the shocks, springs and other stuff. Do I send it to you guys to get it replaced or update the stuff?
Just a little confused on this...He told me not to worry about it but I just want to get your response...
MODS: *** / M Sport + Performance / Meisterschaft / Challenge / MORR / more to come! ***
      03-22-2013, 12:56 PM   #112
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Originally Posted by Route 16 View Post
Before you give up the lease, have you test fitted the Arc-8's or sold them way way back?
Sold them. Would have been cool to see too.
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      03-23-2013, 12:11 AM   #113
Alpine F31
Alpine F31's Avatar
Drives: MB E350 4MATIC Estate
I have a set for Autocross and track days...
      03-23-2013, 12:14 AM   #114
Route 16
I got lei'd
Route 16's Avatar
Philippines
844
Drives: '10 E90 M3
Oh you were the one for the test fit. Nice. I wanted to check with the concave style instead of straight.
      03-23-2013, 12:21 AM   #115
Alpine F31
Alpine F31's Avatar
The concave style is the EC-7
      03-23-2013, 12:36 AM   #116
Route 16
I got lei'd
Route 16's Avatar
Philippines
844
Drives: '10 E90 M3
The Arc-8's as well. A low F30 with concave arc-8's all around.
      05-29-2013, 03:14 AM   #117
AMJAM
AMJAM's Avatar
Australia
33
Drives: 2013 Alpine 328I MSport
Sorry to resurrect an old thread but I thought the BC Coilovers came with adjustable top plates?
So do you use the OEM top plates or do the BC come with the camber adjustable top hats?
2013 Alpine White 328I M Sport ARRIVED
      05-29-2013, 09:07 AM   #118
Sean@PSI
Sean@PSI's Avatar
Drives: 2021 IOMG M3 Sedan
Here's a good write up by M3 Guy.
http://www.f30post.com/forums/showpo...4&postcount=91
      05-29-2013, 07:15 PM   #119
AMJAM
AMJAM's Avatar
Australia
33
Thanks Rc that was the write up I saw. Wow that is so disappointing the reason I wanted these coilovers was because of the camber adjustment plates that all the other BC Racing coilovers come with. Oh well back to the drawing board.
      06-12-2013, 06:14 PM   #120
taichi
taichi's Avatar
52
Drives: F30 & F25
Does these work with xDrive?
some lip, some springs, some brakes, some wheels.
      06-14-2013, 01:25 PM   #121
Sean@PSI
Sean@PSI's Avatar
They do not work with xDrive, unfortunately.
      07-23-2013, 05:28 PM   #122
momo3605
Drives: M340i LCI, 718 GTS 4.0
Originally Posted by tojo_m View Post
So how do these BC coil overs compare (in terms of handing, body roll and comfort) to:
1) F30 Stock suspension ?
2) M- Performance Suspension Kit ?
Is this kit designed to work well with the F30 standard sway bars (not the thicker M-Sport sway bars) ?
Also, I searched the entire thread but could not figure out what is the "minimum" drop for the fronts and the rears. Could someone please provide this info?
+1
      05-08-2014, 11:07 AM   #123
Sean@PSI
Sean@PSI's Avatar
Now available for AWD (X-drive) models - requires a 3-4 week build time!
      07-12-2014, 09:19 AM   #124
jetbill
jetbill's Avatar
198
Drives: G80 M3
Anyone have these that they are using for both daily driving and track duty,specifically the newer version with camber plates?
I have seen some real competitive local guys run these on other platforms with great success.
      08-10-2014, 03:11 PM   #125
amaar_malik
Drives: Slammed F30 330D M Sport
Will this fit all models of f30 or just the 335i?
Will they fit the 330d??
      08-29-2014, 03:46 PM   #126
BMW_Anu
Drives: 2012 F30 335i sport line RWD
PM pls
      09-02-2014, 08:02 AM   #127
Sean@PSI
Sean@PSI's Avatar
All F30 models, even X-drive!
      09-25-2014, 01:49 AM   #128
davegill
23
Drives: 2014 428xi Coupe
do they fit f32 x-drive?
      01-07-2015, 06:29 PM   #129
Stubok
Drives: Melbourne Red F30 328i M Sport
So just looked at http://www.precision-sport.com/bc-ra...r-f30-3-series and it appears there are camber plates?
Am I getting confused? really want that adjustability.
Have a 2104 F30 328i RWD with 20" M624 rims (they came with the car), so the gap is killing me. Need to drop it asap.
@PSI can you PM me your best delivered price to 78703.
Cheers
      01-08-2015, 01:38 PM   #130
zinner
zinner's Avatar
Drives: `17 X5 35d/`15 335i/`18 M550IX
I know this is a bump from the dead but why do companies market struts and shocks and springs as "coilovers". The rears are quite obviously not coilovers since the shock and spring are mounted independently.
      01-08-2015, 05:08 PM   #131
Sean@PSI
Sean@PSI's Avatar
Cheers
Version 2 comes WITH coilovers.
http://f30.bimmerpost.com/forums/sho...d.php?t=982721
      01-08-2015, 05:09 PM   #132
Sean@PSI
Sean@PSI's Avatar
Check your OEM suspension setup...
bc racing coilovers, bc racing na, coil over, f30 335 coilovers, precision sport industries
