► APEX | ARC-8 Light Weight Track Wheels
03-18-2016, 01:19 AM | #67 | |
3532
Rep 6,752
Thank you sir.
- Ryan
06-29-2016, 03:40 PM | #69 |
21
Rep 43
07-05-2016, 01:28 PM | #70 | ||
3532
Rep 6,752
We just launched our new ARC-8 18x9" et30 application, and as mentioned above they are due to arrive soon. This is really the better choice for e9X owners looking to run a concave fitment on all four corners, as it is a direct fit up front (better inner clearance) so that you do not have to mess with spacers. Also, 245 tire's are a more appropriate fit on a 9" wheel. For those looking to maximize traction/grip, 255/35-18 tires can also be used with the 18x9's, and in many cases are a direct fit (light scrubbing inside the fender liners is possible at full lock etc.). Those using track oriented compounds (extreme summer tires & r-comps) will likely need to dial in negative camber up front to prevent rubbing the front fenders. - Ryan
07-05-2016, 07:41 PM | #71 |
9
Rep 31
Looking to pick up the ARC-8's in the following configuration to run on a all stock 2012 E92 335i LCI M-Sport Coupe:
Front - 18" x 9" ET30 Rear - 18" x 9.5" ET35 Can you confirm fitment of the following tires (without fender modification or spacers): Front - 235/40/18 Michelin PSS Rear - 265/35/18 Michelin PSS |
07-07-2016, 11:43 AM | #72 | |
3532
Rep 6,752
- Ryan
08-03-2016, 12:37 PM | #74 |
Rep 65
08-05-2016, 04:10 PM | #75 |
1431
Rep 2,650
The 18x9 ET30 will become a standard wheel going forward. We have more hyper silver currently in production
That E90 is running 17x9" ET30 Hyper Black ARC-8's on 255/40/17 tires all around -Matt
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 08-05-2016 at 06:30 PM.. |
08-06-2016, 03:10 PM | #76 |
Rep 707
Awesome! Thanks for the response. Definitely going to Pick up a set of 9J+30/10j+22 in hypersilver. What would be an estimate on ETA for those to be in stock?
08-08-2016, 05:53 PM | #77 | |
3532
Rep 6,752
-Matt
08-08-2016, 09:41 PM | #78 | |
Rep 707
I want a decently meaty setup for the rears. Will I be able to pull that off with coilovers or should I go down to the 9.5 +22? I have a pre-lci 335i coupe. Last edited by Mr. Tasty; 08-08-2016 at 09:47 PM.. |
08-09-2016, 03:52 PM | #79 | |
3532
Rep 6,752
-Matt
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 08-12-2016 at 03:19 PM.. |
08-09-2016, 04:40 PM | #80 | |
Rep 707
08-10-2016, 01:48 PM | #81 | |
3532
Rep 6,752
-Matt
08-15-2016, 02:54 PM | #83 |
Rep 1,040
Any chance of the new 18x9et30 w/ concave face being produced in 19"?
I drive an e92 335i (non-x) and would love to run: F: 19x9et30 R: 19x9.5et33 Thanks! |
08-17-2016, 06:22 PM | #84 | ||
3532
Rep 6,752
-Matt
08-18-2016, 10:00 AM | #85 | |
Rep 707
What tire selection should I go for? 255/40/18 265/35/18 I really wanted to try and go for a larger than OEM rear size to compensate for the 5% off speedometer. |
08-22-2016, 06:32 PM | #86 | |
3532
Rep 6,752
Front: ARC-8 18x9 ET30 - 235/40-18 Bridgestone RE760 Rear: ARC-8 18x9.5 ET22 - 265/35-18 Bridgestone RE760 This is a direct fit up front, but a fender roll in the rear will be necessary to clear the 265's. -Matt
08-23-2016, 04:32 PM | #87 | |
Rep 1,040
If not, would you recommend just running the 18x9.5et35 with a spacer? My fenders are slightly rolled, but they're not pulled at all. Thanks |
08-24-2016, 03:31 PM | #88 | |
3532
Rep 6,752
F: 18x9" ET30 (Profile 3) - 235/40-18 R: 18x9.5" ET35 (Profile 3) - 265/35-18 (255/35-18 for LCI Sedan) Since you fenders are rolled, you may be able to get away with a small spacer in the rear. With that said, we suggest double checking clearance, as the spacer would increase your risk of rubbing against the fender. -Matt
