BMW M3 Forum (E90 E92)
BPM
      06-01-2021, 01:58 AM   #45
Angr2387
Angr2387's Avatar
Drives: Bmw M3
Originally Posted by gottsman View Post
Were you successful with the filter housing gasket change? I seem to have more oil leaking now than when I first started....
It appears to be coming from the oil cooler tubes. I did change the o-rings with the part number above.. Oil seems to be coming out and hitting the power steering belt and going everywhere. Guess I will clean it up again and hopefully I can find the problem.
hey did you ever find the problem? im doing this job tomorrow
      06-26-2021, 11:05 AM   #46
s0ldats
54
Drives: 2011 E90 M3 stripper
thank you for this writeup
      07-02-2021, 07:46 PM   #47
blk33
blk33's Avatar
Australia
Drives: 2009 E92 M3
Thanks for the great write up.
I had the oil filter housing leak, but did not have to do plugs etc.
I followed the guide and was able was able to remove the oil filter housing without taking the plenum box off.
Cheers
Rob
      01-30-2022, 08:04 AM   #48
alpine2530
10
Drives: E92 M3
Cheers
Rob
I’m about to do this job soon. How many parts did you have to take off before you could ‘comfortably’ take the bolts off the OFH and also the OFH itself?
Thanks.
      01-31-2022, 08:22 PM   #49
blk33
blk33's Avatar
Australia
Drives: 2009 E92 M3
Thanks.
I would suggest following the guide and miss the directions removing the plenum. Air filter comes off from memory, fan out, belts out and a few bolts to get access. Don't forget to make one of those short TORX spanners.
Good luck.
      02-01-2022, 09:46 AM   #50
Rino924
Rino924's Avatar
Drives: 2009 E90 M3
About to tackle this job. Have 116k on the car.
Probably will do water pump and thermostat. Kit on FCP for $317.30
Oil filter housing gasket: $18.19
Oil cooler O-rings: $6.78
Do we have the part numbers on FCP for both belts? Do I need to do any other pulleys or just the belts should be fine?
Thanks!
      02-01-2022, 10:33 AM   #51
spammysammich
spammysammich's Avatar
1584
Drives: 2009 E92 M3 Dakar Yellow II
2009 BMW M3  [10.00]
Thanks!
Consider doing idler pulleys and tensioners when you've already got belts off. Depending on how deep into the while youre in there rabbit hole.
      02-01-2022, 11:56 AM   #52
Rino924
Rino924's Avatar
Drives: 2009 E90 M3
So a complete kit like this? Just trying to decide if that truly needs replaced or if I should since I am in there. That would add significant cost to the job. So just want to be 100%.
I've never done a belt job on any vehicle so doing as much research now that I can.
https://www.turnermotorsport.com/p-3...e-kit/?pdk=BQQ
      02-01-2022, 12:33 PM   #53
Drifter2090
Drifter2090's Avatar
910
Drives: E90 M3 | E92 335i | E90 335d
Good luck.
Okay so no plenum removal, that should make it quicker. Do I need to drain the oil and coolant as well? or does only a bit come out?
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD
JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD
SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD
AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD
      02-01-2022, 01:18 PM   #54
Rino924
Rino924's Avatar
Drives: 2009 E90 M3
From my understanding, no oil needs to come out. You lose a very small amount changing out the filter, but not enough to cause concern.
My plan is to do thermostat and water pump so may take a turkey baster and suck some out of that before disconnecting radiator hoses. I suppose you'll lose a little bit, but not a ton.
      02-01-2022, 01:30 PM   #55
Drifter2090
910
Oh okay then it should be pretty straight forward. Does the waterpump/tstat have to come out? Mine's fairly new so I was just going to change the o-ring if I had to.
      02-01-2022, 02:07 PM   #56
blk33
blk33's Avatar
Australia
Drives: 2009 E92 M3
Water pump out, I did the O ring, Thermostat can stay, so coolant required.
      02-01-2022, 02:22 PM   #57
Drifter2090
910
Oh okay, so coolant out but oil I'll leave then. Thanks
      02-01-2022, 07:58 PM   #58
alpine2530
10
Drives: E92 M3
Thanks for getting back. Planning to tackle everything all at once.
Also, thank so much to OP for this diy. Very helpful indeed.
      02-03-2022, 06:50 AM   #59
Helmsman
Helmsman's Avatar
Sweden
4467
Drives: 2011 AW E90 M3 ZCP
Nickes comment reg Turners belt guide can be worth checking out mate: https://www.m3post.com/forums/showthread.php?t=1333638&page=36
      02-16-2022, 07:57 AM   #60
Rino924
Rino924's Avatar
Drives: 2009 E90 M3
Going to take some better pics but got a scope camera and only had a few mins to try out. Need to get a few more angles and spend more time but I think this looks like the oil filter housing gasket.
      02-19-2022, 10:01 PM   #61
Drifter2090
910
Got it done today, took the plenum off since I was doing injectors as well.
*also forgot to drain the coolant and made a mess lol
-plenum, intake out
-expansion tank loosened
-expansion tank overflow hose removed at hose end (the plastic nipple on the radiator hose can break during fan removal, easy to just remove the overflow hose)
-fan out
-top left coolant hose disconnected from the thermostat
-lower coolant hose going to metal pipe above the alternator disconnected on metal pipe end
-both hoses tucked away
-oil cooler lines loosened at the bracket
-oil filter removed and oil sucked out
-oil cooler lines removed and moved out of the way
-water pump pulley then pump removed
-belts removed
-ac belt tensioner removed
-power steering pulley removed (mine was seized on I had to break it off)
-remove 3 bolts holding the power steering pump
-remove 10mm nut and bolt holding the power steering hoses in place
-move power steering pump out of the way
-cut t30 bit in half and use a wrench to remove the oil filter housing bolt behind the crank pulley
-remove 8 remaining bolts
-change the gasket and clean mating surfaces well
-do it in reverse for reassembly, make sure you do new oil cooler o-rings and water pump o-ring
Thanks for the help!
      09-19-2022, 09:39 AM   #62
x3sm
x3sm's Avatar
282
Drives: M3 E93 Porsche
Bumping this back up as I have a few questions..
1. Best way to drain coolant is through the radiator on the bottom? Would that clear the water-pump from most of the coolant?
2. Are you guys putting back the old oil filter or installing a new one?
3. What are the torque specs for OFH bolts? Are new bolts needed?
4. FCP euro kit has a new sensor, is it necessary?
https://www.fcpeuro.com/products/bmw...-11427838276kt
M3 E93
PORSCHE MACAN S: SOLD
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      12-07-2022, 07:20 PM   #63
spammysammich
1584
2009 BMW M3  [10.00]
ARES 70920 - Fluid Change Syringe - Smooth Suction Action for Easy Fluid Change - Ideal for Power Steering Fluid, Brake Fluid Removal and More - 200cc Max Capacity https://a.co/d/iigKRCc
Maybe the ol Austin Powers pump at the expansion tank to minimize coolant loss? Get multiples for clearing out the filter housing too.
I would NEVER reuse an oil filter. Condom? Maybe.
      04-16-2023, 06:17 PM   #64
jimmtman
Drives: 2008 M3 Convertible
How Long Did it Take?
Thanks everyone for this great write-up on the oil filter housing leak. I'm curious how long it took for you guys to replace it? The book time for a shop to do it is 6 hrs. I might be able to take this on with a more experience friend helping as a shop will charge about $1000 in labor to replace a $20 gasket.
Thanks!
Jim
      05-03-2023, 04:37 AM   #65
betak
Drives: '09 335i, '11 M3
2011 E92 M3  [0.00]
2009 E90 335i  [0.00]
Thanks for this fantastic DIY! Did this job over the weekend and it wasn’t bad at all.
Making the tool is a must. I didn’t drain all the coolant, just sucked out what I could from the reservoir with a cheap $10 pump. I used an XL dog training pad to soak up about a quart which spilled from the water pump. I also thought the OFH could be removed without water pump coming out. It can IF the harmonic balancer comes out. WP removal definitely easier route.
One tip I didn’t see mentioned (if it was, sorry!) grab a cardboard box and place it behind the radiator to prevent tools, hands, elbows from hitting it and bending the fins.
I was rounding the home stretch and bam, dropped water pump bolt which landed on the belly pan. After removing the belly pan, my OCD kicked in, and I’m into a 4 hour steam cleaning detail job. Oil was caked everywhere below! Guess I would have completed much sooner had I not been distracted. At least the engine is clean now.
      07-10-2023, 03:40 AM   #66
Chigurh
31
Drives: '10 E92 M3 & '14 F31 328i
Thanks for the absolutely awesome DIY! Also all of you who chipped in with valuable tips.
This may be a stupid question, but which screws are holding the power steering pump?
Don't want to make an absolute mess. Also, I was planning on not having to remove the whole waterpump, just the wheel but some say it's possible and some not.
EDIT; After closer inspection seems to be the hex-screws just holding it and the torx for the bracket so if I don't disconnect the line I won't have PS-fluid pissing out anyway.
m3post
