BMW M3 Forum (E90 E92)
BPM
      11-28-2021, 10:02 AM   #45
Vedubin01
Drives: 2013 E92 M3
Originally Posted by tldude876 View Post
Originally Posted by Route 16 View Post
I need clarification
is it x24 or x22 bolts? 11127841217
is it x4 or x2 bolts? 11127841218
24 and 2
Correct. Updating now
      11-28-2021, 11:54 PM   #46
exVtekGuy
115
Drives: none yet
Originally Posted by asma123 View Post
Getting ready for the job. Going to order parts soon. Mine are leaking but not super terribly. Also I’m wondering if it’s ok to go for the cheaper victor reinz gasket along with the Elrin timing cover gasket just to save a few bucks
So parts needed will be
1 Drei Bond 07589062376
1 Engine Valve Cover Gasket BMW-11127838271
1 Engine Valve Cover Gasket BMW-11127838272
8 Spark Plug Tube BMW-11127835170
24 Valve Cover Bolt 11127841217
2 valve cover bolts 11127841218
4 Cam Sensor seal 13627796699
4 Cam Sensor bolt 11417526315 - are these really necessary?
2 each Crank Case Vent Seal 11157838370
2 oil separator seal BMW-11157838369
2 Engine Timing Cover Gasket BMW-11127838162
I searched a couple resellers. Seems FCP Euro would be the way to go since they offer lifetime warranty and their prices are not far off from the competitors
FCP Euro:
11127838271, 11127838272, 11127835170 - $318.30
11127841217 - $8.99x24 $215.75
11127841218 - $9.59x2 $19.18
13627796699 - $3.29x4 $13.16
11157838369 - $6.89x2 $13.78
11157838370 - $5.69x2 $11.38
11127838162 - $18.19x2 $36.38
07589062376 - $25.69
Total: $653.63
Getbmwparts
11127838271 - $47.85
11127838272 - $47.85
11127835170 - $22.47EA x8 $179.76
11127841217 - $7.97EA x 24 $191.28
11127841218 - $8.44EA x 2 $16.88
13627796699 - $2.42EA x4 $9.68
11157838370 - $5.01EA x2 $10.02
11157838369 - $6.15 x2 $12.30
11127838162 - $15.91 x2 $31.82
07589062376 - $23.05
Total $570.49
ECSTuning
11127838271 - $48.42
11127838272 - $51.95
11127835170 - $22.80 x8 $182.40
11127841217 - $9.20 x24 $220.80
11127841218 - $10.18 x2 $20.36
13627796699 - $2.88 x4 $11.52
11157838370 - $5.86 x2 $11.72
11157838369 - $7.45 x2 $14.90
11127838162 - $17.94 x2 $35.88
07589062376 - $24
Total $621.95
FYI, I just bought this whole set via FCPEUro and it came out to be ~$550. Maybe the Black Friday pricing is helping?
DrFerry6728.50
      12-01-2021, 08:02 PM   #47
Formula_Autohaus
Drives: E92 M3 Miley
Thank you for this!
      03-07-2022, 04:57 PM   #48
CamasM3e93
Friends don't let friends ESS
CamasM3e93's Avatar
3163
Drives: '11 Lemans Blue 6mt Harrop e90
Originally Posted by Vedubin01 View Post
I thought I would attempt to do a simple DIY on replacement of valve covers using a used set or your own if you are attempting this on your own. I have seen some information that is incorrect in regards to the installation and figured I would help those trying or attempting this yourself.
Really good stuff and thanks for posting this. Not sure if you're around on the forums. Was wondering if you also replaced the cam shaft sensors on each side.
      03-07-2022, 09:51 PM   #49
Vedubin01
Drives: 2013 E92 M3
Hey, thank you! I did not replace them myself but saw a post where someone did and the car ran better. Can't really remember the issue. I think it was buried in the thread "what did you do to your M3 today"
DrFerry6728.50
      04-25-2022, 08:31 AM   #50
CamasM3e93
CamasM3e93's Avatar
3163
24 Valve Cover Bolt 11127841217, 11127835169
2 each Crank Case Vent Seal 11157838369 11157838370
I think this is complete - if anyone sees something missing tag me and Ill update the list
Thank you.
Appreciate this thread so much. I'm refreshing a 100k mile e90 and thinking I will go ahead and pull the trigger on this job. Was wondering your thoughts on replacing the Cam sensors while you're in there. Seems like a good idea - though I don't hear others doing it and no reports of failures.
      04-25-2022, 09:52 AM   #51
DRLane
DRLane's Avatar
Drives: E92 M3
2008 m3  [6.63]
Thank you.
I did via FCP, but probably unnecessary at my low mileage. I wanted a fresh update of all the components on 14 year old track car. This is a pretty casual DIY given your capabilities with the SC install, uninstall, install… 😂 One of the more enjoyable projects once the heavy ass Harrop plenum is removed.
Not a Doctor, those are just my initials.
      04-25-2022, 08:12 PM   #52
DRLane
DRLane's Avatar
Drives: E92 M3
2008 m3  [6.63]
Part 2:
So after getting your gasket installed into your cover go ahead and press the new Spark Plug Tubes into the cover. Nothing special just push. Now go ahead and fit the cover back over the head and start adding the new bolts with the grommets. This is where I have seen some wrong numbers. TQ numbers for these bolts are 6NM not 10NM as I have seen in many threads. You do not want to over torque these at all. Also start from the middle and work your way to the ends when torqueing the bolts. This way you don't run the risk of an improperly seated cover and would expose you to possible leaks down the line.
[IMG]https://i.ibb.co/CHLgvKT/214625089-1...943086-n-1.jpg[/IMG]
[IMG]https://i.ibb.co/Zg4dH7M/111.jpg[/IMG]
Once secure this is s a good time to replace your spark plugs. This also has a Torque figure of 23 inch lbs.
[IMG]https://i.ibb.co/cygSFV0/213878163-1...02687299-n.jpg[/IMG]
[IMG]https://i.ibb.co/WtNyWxv/208892551-1...512904-n-1.jpg[/IMG]
Once you got everything all tightened up you are then ready to start connecting everything back up.
[IMG]https://i.ibb.co/cYb4kXM/209397733-1...602938-n-1.jpg[/IMG]
[IMG]https://i.ibb.co/CnXPGCt/213351676-1...49928256-n.jpg[/IMG]
[IMG]https://i.ibb.co/PhTdYv1/215618545-1...14739043-n.jpg[/IMG]
This was a good time to also replace the fuel breather that sits toward the back under the plenum.
[IMG]https://i.ibb.co/hfdhgh3/212249696-1...66645743-n.jpg[/IMG]
Then you would repeat this same process on the other side. The only difficult thing was working with the coolant reservoir as it seemed it was always in the way.
The total job took about 4 hours and was pretty straight forward. Looks a 1000x better and will be much more durable than the stock finish and will last years to come.
[IMG]https://i.ibb.co/fMjNFsK/214011285-1...00534644-n.jpg[/IMG]
[IMG]https://i.ibb.co/yy0HbKM/213670896-1...16302383-n.jpg[/IMG]
Hope this helps someone out there that is looking to do this job. It is not difficult at all but it is costly when you add up all the parts to do this job.
Ill come back and provide a parts list as best as I can later.
Thank you.
Isn't 6Nm = 53 inch lbs not 23?
      04-26-2022, 08:46 PM   #53
Vedubin01
Drives: 2013 E92 M3
Part 2:
Thank you.
Not quite sure where you are referring to?
      04-26-2022, 10:13 PM   #54
DRLane
DRLane's Avatar
Drives: E92 M3
2008 m3  [6.63]
@Vedubin01
"Once secure this is s a good time to replace your spark plugs. This also has a Torque figure of 23 inch lbs."
That was preceding the 6Nm call out. Figured it was a typo is all.
      04-27-2022, 06:28 AM   #55
Alexei9012
Alexei9012's Avatar
Australia
Drives: BMW M3 E92
Can you reuse the spark plug tubes?
      04-27-2022, 07:19 AM   #56
tldude876
35
Drives: e92 m3, ap2 s2000
You can use but it's probably not a good idea depending on the mileage.
      04-27-2022, 09:48 AM   #57
Vedubin01
Drives: 2013 E92 M3
@Vedubin01
Thank you fixed it.
Spark plugs are 23lbs while the valve cover screws are 6nm.
      04-29-2022, 01:47 AM   #58
aus
Drives: Odysse
Thanks OP.
How much do you charge for to refinish a set of covers?
      04-29-2022, 07:19 AM   #59
Vedubin01
Drives: 2013 E92 M3
Originally Posted by aus View Post
Thanks OP.
Feel free to PM me, it all depends on what you are looking for.
      04-30-2022, 12:13 PM   #60
chenium
31
Drives: Porsche 911, 2010 E90 M3
Should it be 12 x 11417526315? 4 for the cam sensors and 8 for the oil separators?
      04-30-2022, 12:25 PM   #61
chenium
31
Also, 2 oil separator seal BMW-11157838369 is duplicated by 2 each Crank Case Vent Seal 11157838369. Caused some confusion for me when I was adding these items to the cart and wound up with 4 x 11157838369 Crank Case Vent Seal
      04-30-2022, 06:40 PM   #62
Redd
Drives: 2010 BMW E92 M3 Dakar Edition
Yes that is correct. I bought the full lot and wound up with 2 extra 11157838369 o-rings after the job.
      05-03-2022, 08:58 PM   #63
chenium
31
I ordered Drei Bond through FCP Euro but they sent me BMW Loctite 5970 instead. It also seems to be a RTV sealant. What's the difference between this and Drei Bond and can I use this instead?
https://www.fcpeuro.com/products/bmw...ml-83190404517
      05-23-2022, 03:04 PM   #64
lmb.m3
lmb.m3's Avatar
Drives: Le Mans Blue E92 M3
2006 Honda S2000  [0.00]
2017 BMW M240i  [0.00]
2010 BMW M3  [0.00]
I have the same thought here.
I checked realoem and it should be:
x12 11417526315 torx screws (4 for each oil separator = total of 8, 1 for each camshaft position sensor = total of 4)
And only x2 instead of x4 for the bigger oil separator seal 11157838369
Instagram: @lmb_m3
      05-30-2022, 12:48 PM   #65
aus
Drives: Odysse
Question on the bolts in bold. I just need 24 of either one right?
Thanks to everyone who contributed!
The price has gone up a LOT at FCP. It's $665 with 12 Torx screws BMW-11417526315
as recommended above.
If it's ok to re-use the screws, I'd just reuse my old ones. Are they really one and done? We're not talking rod bearings here.
      05-30-2022, 07:09 PM   #66
Redd
BMW-11417526315 is the cam sensor bolt. You only need 4, not 12.
Not recommended to re-use the valve cover bolts. They have a rubber grommet that hardens with age and can leak oil.
m3post
