BMW M3 Forum (E90 E92)
Mporium BMW
      11-23-2023, 04:09 PM   #1
Mog-10
145
Drives: E93 m3
Diy: stuck cv
I was in a situation that I needed to remove my CV shafts and nothing I did worked.spraying pb blaster, Hammering on it with a sledge ,15ton 3 jaw with an impact and Hammering no luck!
Then I had an idea of finding a way to soak it in pb blaster over night wile it was still on the car. I found the bottom of a 1L pop bottle fit perfect. So I glued it on with some shoe goo cut a hole at the top and filled it up , next day came out with the 3 jaw easily.
I hope this can help others.
Appreciate 3
Nairb167.50
Theodore668.50
Ajolives922.00
      11-24-2023, 01:46 PM   #2
Theodore2
44
Drives: E92 M3
Great idea! I wish I would have seen this before I pulled the axle and hub together off the car and left it soaked with PB blaster under pressure on a 50 ton press overnight to get mine unstuck. This idea probably would have worked just as well.
Mog-10145.00
      11-29-2023, 10:50 PM   #3
exVtekGuy
115
Drives: none yet
What did you fill it with? Oil?
      11-29-2023, 11:00 PM   #4
spammysammich
spammysammich's Avatar
1584
Drives: 2009 E92 M3 Dakar Yellow II
2009 BMW M3  [10.00]
He said PB Blaster.
m3post
