BMW M3 Forum (E90 E92)
BPM
      08-29-2010, 11:28 PM   #67
FruitCake
Taiwan
88
Drives: '10 E92 M3
Originally Posted by MTROIS View Post
Following a very satisfying brake pad job in an hour and a half today, I'd like to add two things:
- first, instead of "suffering" with a regular 7mm allen key, I highly recommend getting the following hex bit that you will be able to use with your ratchet... and save loads of time: http://www.bimmertools.com/7MM-Stubb...p/ahbmw307.htm
- also, I have come to realize that you can easily remove the anti-rattle springs without any tools!! Just push in the direction of the axle and gently lift the back... it comes right out and goes right back in this way.
The first time, it took me probably 3 hours or so to change the pads and now it is a real piece of cake. On this high note.... I am back to the American Le Mans series....
pix plz for the 2nd part ur talking about
      08-31-2010, 09:19 AM   #68
LiM3y
LiM3y's Avatar
70
Drives: 2008 E90 M3
Thanks for the stubby hex bit...it means I can use my electric impact wrench (as opposed to driver) now!
      11-27-2010, 09:02 AM   #69
M3V8Driver
M3V8Driver's Avatar
Drives: E92 M3 - DCT
I already covered these two items in my rewrite of the procedure (please see the pdf). I did recommend a pliers instead of hands though, just because it's less messy and provides better grip.
There are a couple of things I'd change in another rewrite however; 1) I'd suggest jacking up all four corners, rather than one side at a time. This saves a lot of time and let's you bleed all four corners one after the other (starting farthest from master cylinder and ending closest to it); and 2) I'd recommend using a power bleeder to better do the job solo. I've gotten the whole procedure down to an hour even now
Mmmm... M&Ms,
Dale
      12-30-2010, 01:27 PM   #70
WCM3
Î canŧ főcus mŷ attėntĭon
WCM3's Avatar
Drives: 13 Rubicon
Does everyone replace their rotors when they change the brake pads? I've been told by some BMW techs that you should buy new rotors everytime you change the pads, then other techs that you only change them if you need to. My M3 has 51k on it now and it needs brakes, so I'm debating if I need to change the rotors out or not.
2011 M3 Coupe - Individual Fire Orange/Black Novillo Extended Leather, 6MT, Mode Carbon, Eisenmann Race, BBS CH-R, BC Coil-overs (Sold)
1995 M3 Coupe - Avus/Hurricane, AEM EMS, Precision Turbo, Boostlogic, H&R, Fikse FM/5, MaxVelocity, Maximum PSI, 20% Tint, etc etc..(Sold)
2009 M3 Coupe - AW/Fox Red, 6MT, Carbon Roof, Shadow Trim, etc (Sold)
      12-30-2010, 01:29 PM   #71
knifegun
knifegun's Avatar
Drives: M4
I am not a mechanic so take this with a grain of salt. I replaced the brake pads on my S2000 multiple times w/o changing the rotors and did not have an issue. I always checked the rotors to ensure they weren't too thin and checked to make sure there weren't any scoured areas.
      01-31-2011, 09:10 PM   #72
IFX
Drives: AW e46M/N54
No, you do not need to replace rotors every single time you buy pads.
Usually, you can resurface rotors, but drilled rotors, no.
If your at 51k on stock rotors however, they may need to be changed. But what they said is complete bs.
      04-03-2011, 10:31 AM   #73
2000gsr
2000gsr's Avatar
18
Drives: 2018 M4
When pushing the piston back with the c-clamp, do we need to remove the cap on the brake reservoir or is ok to leave it on?
      04-03-2011, 05:55 PM   #74
haze gray
haze gray's Avatar
Drives: 2009 M3 Coupe / 2011 X5
Why are you balking at replacing rotors at 51K? Trying to get another 1K out of them? You drive an M. Maximize your advantage.
      04-03-2011, 06:41 PM   #75
quads
Drives: bac mono
Originally Posted by FrenchBoy View Post
Thanks Lucid. Great write-up.
One question about the anti-rattle clip. I am very familiar which changing brakes pads as I have done it many time on my E46 325Ci. Overall, seems to be a similar setup.
The anti-rattle clip looks quite different though and seems trickier to remove. Do you have input or close-up shots on how it is attached and how to removed.
I am installing Carbotech XP10 in about a week for a track day.
Thanks
Regarding the carbotechs - I've had great results with xp12's with my v8 miata - but i think you can't just swap pads since carbos require resurfacing the rotor because the bedding process leaves a film on the surface in order for it to work properly.
      06-15-2011, 08:53 PM   #76
MK599
72
Drives: E92 M3
When you say "Remove the pad wear sensor. It is clipped onto one of the brake pads. Just pull on it and it will come out. The chances are the tensioner clip will remain in the pad. Make sure to get it. They are not sold separately, and if you lose it, you'll need to buy a new sensor."
Are the pad wear sensors reusable?
Are the tensioner clips removable and essential?
When you swap to track pads, do you guys attach a sensor? if not, what happens? do you just receive a brake light? aka are pad wear sensors necessary?
Thanks
      06-15-2011, 09:20 PM   #77
jgalaxy
Gearing
jgalaxy's Avatar
86
Drives: E46 M3, F22 M240
Thanks
Are the pad wear sensors reusable - Yes.
Are the tensioner clips removable and essential - Yes and yes, unless you want or care about warnings/errors on the console.
Re: Track pad swap, do we attach? - I no longer do. See below.
If not attached - you get an computer error. Car works as normal.
I re-used my sensors until I lost the little metal tensioner clip or the cable system failed in some fashion (they are cheap $18-$22). I eventually got so sick and tired of having to frig around with the cable system that I have since disconnected them front and back and simply cut off the sensor to expose both wires, twist them together (system shorted out to believe all is well) tape them off and tie wrap them up. Only makes sense to do this if you track often and are very aware of your pad usage. Otherwise I dont recommend anyone doing this.
If at first you don't succeed ...
      08-06-2011, 10:48 PM   #78
m3heaven
m3heaven's Avatar
Drives: 2003.5 E46 M3
Does anyone know the torque specs for the caliper bolts?
      08-07-2011, 02:28 AM   #79
JCtx
Drives: No BMW yet
I'm stumped why BMW doesn't use the proven method of audible wear indicators on the pads, like all other freaking cars in the market . They try too hard to be different... and many times with non-desirable results. Not having an 'off' HVAC button is another example. Or a freaking dipstick. You get my point . Hey, I thought that just putting the sensor aside (taped up somewhere) didn't trigger any faults, no? They're supposed to trigger a fault when the sensor is grounded after being grinded down by the rotor. How the hell does it 'know' it's attached to the clip? Thx.
      08-07-2011, 05:28 PM   #80
LiM3y
LiM3y's Avatar
70
Drives: 2008 E90 M3
30N.m or 22lb.ft
      09-25-2011, 06:23 AM   #81
Moe's M4
Moe's M4's Avatar
Drives: 2015 BMW M4
2015 BMW M4  [10.00]
Thanks for sharing, and thanks for taking the time and efforts in providing us pics...
      03-07-2012, 02:29 PM   #82
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
useful DIY and very easy. switched to my ds2500 pads this morning, removed my dust shields for extra cooling with my gt4 ducts and put on my track wheels so set for the season!
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      03-30-2012, 10:45 PM   #83
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
Compared to my Stoptechs...What a PIA! And thanks for the DIY!
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      04-07-2012, 05:21 PM   #84
Zzhou
Zzhou's Avatar
Drives: 2012 E92 SSII ZCP DCT
How did you get rear anti-rattle spring out? I tried so hard and is not working..so I only changed front pads.
AA Green Filter/AA Pulley/AA catless X-pipes/AA signature exhaust/AA TUNE/TMS studs/Project Kics R40/R888/VOLK ZE40/ST60,ST40 BBK/MCS 2WAY NR/Vorsteiner GTS5 Bumper/APR GT250/APR SPLITTER
      04-07-2012, 06:31 PM   #85
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
the rear was super easy i think i may have just used my hand. the front was harder for me.
      04-07-2012, 09:09 PM   #86
Zzhou
Zzhou's Avatar
Really!How did you do it by your hand. Took me half hour and still can not get it out.
      04-07-2012, 09:37 PM   #87
r53s65e90
8300
r53s65e90's Avatar
Drives: r53 s65e90
By hand it is almost impossible for me. I use a screwdriver. You put it in one of the holes and use it as a lever pushing the metal away from the center of the hub. This way you can wiggle one of the hooks out. The second one is then easy.
The fronts are easy and can be done by hand.
      04-08-2012, 12:13 PM   #88
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
weird i had the opposite experience. the fronts took me about half an hour to figure out and my rears just popped out.
m3post
