BMW M3 Forum (E90 E92)
      10-23-2012, 01:19 PM   #45
dukeandtheland
Drives: F10 550i M-Sport
Impossible to reach
For M3, you may have enough room, but for my 2008 335Xi, there is absolutely no room to reach the bleeding valve.
The damn valve is way deep behind the hard lines. Even if I find a extra long wrench to reach it, there will be extremely limited room for me to make even a half turn. And there is the rubber cap part, no way I can put my hand in and take that cap off; imagine I have to put it back on, also connect the hose cap to it.
I cannot believe the design of this. This is just designed to make sure that no one can touch it!
A picture is attached here
Originally Posted by elp_jc View Post
Pleasant clutch bleeding surprise folks. After half an hour of turning the bleeding valve a full turn with my vacuum machine attached to it (no freaking s p a c e -why the hell the system censors that word????) and no fluid, I knew I was dealing with a check valve. Got out from under the car, opened door, push clutch pedal with hand and it went in like butter. Did that 10 times more and I was done. Clutch worked perfectly after closing it. Next time it's going to take me 2 minutes after removing shield.
Here's the drill:
- Remove belly pan (3 screws in front, 2 in back, and 2 on each side).
- Remove cap from valve and loosen it one full turn with a 1/4" ratchet and 11mm standard socket.
- Valve will just spew fluid when you push the clutch pedal, so use any method you want to catch it that won't splash. This is a one-person job folks .
- Push clutch pedal slowly (and return slowly as well) about 10 times, and you're done.
- Screw valve clockwise with ratchet until you feel a 'click' and it stops turning. DO NOT apply too much force since it's PLASTIC.
- Reinstall belly pan and you're done. This is the easiest clutch I've ever bled, and the most effective way is by pushing the pedal, but I never do it that way since helper can screw up. No chance for that here; great feature .
By the way, rear brakes require a 9mm closed wrench and front 11mm, and are regular valves (the way I like them on the brakes). Job done in about an hour with a vacuum bleeder (the best way IMO). Fluid was clean (no debris inside the reservoir, like most of my new cars), which was good news, so no need to destroy the filter to clean the reservoir. Just amber in color. From now on will do it yearly, like all my other vehicles. Just $10 and an hour of my time. Well, probably 2 hours since I like to clean the undercarriage . Hope this helps folks.
      11-18-2012, 05:54 AM   #46
nez
nez's Avatar
Australia
Drives: e90 m3
um stupid question, but if I'm using a pressurised bleeder tool, do i have to take the wheels off to change the brake fluid. So long as I jack the car up and can get to the bleeder nipples I'm good to go right?
      11-18-2012, 08:38 AM   #47
Car54
Drives: 2014 M-Sport Wagon - EBII
You can do it with the car on the ground so long as you get to the bleeders. Be careful of spilled fluid on wheels though. Use water to rinse of messes.
      01-08-2013, 09:07 PM   #48
bizzurk4
Drives: 2008 e92 m3 IB
question i have is how do you reset the computer for service date after you do the bleed? i tried reseting it the same way i did when i changed the engine oil using the computer buttons on the steering column but for some reason it wouldn't reset. any tips or tricks that i'm doing wrong? thanks for the photo's the steps were very easy to follow!
      01-09-2013, 03:10 PM   #49
Car54
Search youtube for a video...it's the same process for all the conditions based services.
      04-22-2013, 08:59 PM   #50
jfirwin
Drives: 08 E90 M3 6spd Jerez Blk
Resetting the Service indicator.
A must for any DIY. Resetting the service indicator.
The detail from mikem's thread http://www.e90post.com/forums/showthread.php?t=51049
Step 1
Insert key into slot
Step 2
Press start/stop button without depressing clutch/brake and wait for the service reminder to disappear.
Step 3
Immediately after service reminder goes out, press and hold the odometer reset. After 3 secs a warning triangle will appear, keep the odo. button pressed and after another 2-3 secs the Oil can will appear. I f you hold it too long (10 secs in total) you will overshoot the runway and some German writing will appear giving the software level/ can bus etc. of the car. Go back to the beginning and start again.
Step 4
You are now in the service menu, use the toggle switch on indicator stalk to scroll up/down through the various service items.
Step 5
When you have the item you want to reset showing, press the BC button on end of indicator stalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secs and a clock will start whirling around and hey presto, its done
Step 6
You can now either scroll up/down to select another item (as in step 4) or you can press the start/stop button to exit.
      10-29-2013, 05:45 PM   #51
johnyb62
Drives: 2008 320D M Sport LCI
I've just replaced my fluid on an 2008 320d M Sport LCI, and although the brakes are good they are not as solid as before.
I purchased a vacuum pump which didn't work so resorted to the tried and tested 2nd person pumping (Opened value, pumped until looks like new fluid and no bubble, held brake on floor and tightened the lock valve, Offside Rear, Nearside Front, N/S R, O/S F). Its been mentioned above this could be something unavoidable without BMW specialist / main dealer equipment, is this the case? If not any other suggestions
BTW I've bleed brakes on numerous cars in the past using the same method.
      04-19-2014, 06:22 PM   #52
SeaMonkey
Drives: '08 e92 m3
ABS activation
Curious to know if anyone is using diagnostic software to activate the ABS system when bleeding/flushing brakes...TIS says to do it once for rear and once for front thanks.
      04-29-2014, 04:13 AM   #53
IntegraXTR
Drives: MY08 E92 M3 and MY15 F80 M3
Just did the brake flush a couple days ago with the Motive bleeder and man it was a breeze!
I went to my friends house (he has a lift) and went underneath the car without taking off my wheels and used the motive bottles to prevent any spillage.
The maintenance minder on the Idrive says every two years. The fluid that came out looked pretty good, not dirty at all. But I flushed it out anyways.
Great DIY =)
2008 Alpineweiss III E92 M3
Amuse/Varis/CAE/BBS/BRIDE
IG: Integraxtr
      09-09-2014, 05:38 AM   #54
3M
3M's Avatar
Germany
Drives: E90 M3
Hi,
My 2011 just gave me the indication. Is the procedure pretty much the same? I'd like to do the flush myself using the 2-man method but the mention of ABS is giving me 2nd thoughts. Is the majority taking their cars to the dealer because of this?
      11-22-2014, 02:19 PM   #55
2fast4
2fast4's Avatar
30
Drives: 2008 BMW 335i
Bleeder hose with check-valve?
Can a bleeder with check-valve on the hose work? I used to do it on older cars with this and worked really well as a one-man job.
Nowhere is it mentioned about the cheap and simple hose with "check-valve" at the end....it goes out, but won't come back in...
(if you do use the check-valve, be sure to spray or put some oil on the steel ball of the valve for storage. It rusts over time esp around seat).
So that I pump the pedal several times(and checking the reservoir level), see that old fluid is gone and new color is showing...then lock the nipple.
Is it related to ABS pump that requires 2 people doing the job? Doesn't seem like it if we use $$$vacuum pump.
Please clarify...
      06-14-2015, 12:10 AM   #56
MiamiE93Vert
Drives: E93 M3 Convertible
Just finished flushing the brakes for the first time, very happy with the results and that I could do it myself! Here are some things I learned:
Removing the box cover in the engine bay uses an 8mm wrench;
I used a motive pressure bleeder, worked great as a one person job: 10 psi to test pressure, 15 psi with fluid;
I have a stoptech bbk, 11mm bleeder screws; and
2 wheels I did not even have to remove but 2 needed to be removed as not to strip the bleeder screws. I am buying an 11mm flare nut wrench to make future flushes easier.
Total time was 2 hours but if I did not have to take off two of the wheels I would have finished in an hour. I think doing it again I can finish much quicker.
AA Pulley, Air Filter and Tune - Full Evolve Valvetronic Exhaust - 380/355 Stoptech BBK, BBS FI's and other fun stuff.
      10-21-2015, 05:30 PM   #57
tubedreamer
42
Drives: (Sold) 2008 SSII 6MT E90
I got a motive power bleeder to do this car and the E36. Did my brake pads, bled my brakes, and then proceeded to bleed clutch per this thread's recommendation.
To make cleanup easier, I don't even put fluid in the pressure bleeder. I just keep an eye on the reservoir and fill frequently.
Brakes was cake. Clutch was almost a disaster. The early information in this thread is kind of misleading. I was panicking when my clutch went soft and air was blowing out the bleed valve. I found out that is because the clutch feeds from a high point in the reservoir so you have to keep it topped off at max, and the short line to the clutch bleeds fast.
Also clutch goes soft easily, but when the reservoir is filled, pumping the clutch multiple times (20-30x?) makes it firm up to how it feels when it is normal.
Anyone interested in bleeding the clutch please read this thread first:
http://www.m3post.com/forums/showthread.php?t=491319
      10-23-2015, 04:06 PM   #58
aussiem3
aussiem3's Avatar
Australia
274
Drives: Goggomobil
Just performed my BF flush after two years and replaced the BMW fluid with retail Castrol Dot 4. Used the Motiv DIY brake bleeder, and removing each wheel and completing the job took about two hours. The old fluid was slightly less translucent compared to the new, but of the exact colour - yellow. Seriously, maintenance on these cars thanks to some excellent DIY post is easy, time and money saving, and gives you some joy!
Thank you all
F86 X6///
      12-27-2015, 10:03 AM   #59
Duckengine
Drives: 2020 BMW X5 x40i
Can't get the pressure back after multiple bleeds
Hello all. Time to flush the Brake system and put in some new fluid. Driver rear bleed screw frozen and then broke. Tried to get it out on the bench to no avail and so bought a new caliper. Put it all back together and then using a pressure bleeder, bled all four calipers with 500 ml of new fluid. First go with pressure bleeder was air pressure only (no fluid) at about 12 psig. Took the car out for a spin and virtually no pressure but I could pump it and build pressure enough to lock up the brakes. Try bleeding again with same method as previous and a slight improvement but not much. Tried again a third time with traditional pump brake process. No improvement. Tried again with the pressure bleeder but used fluid in the pressure bleeder instead of just air as done the two previous attempts. Flushed almost an entire liter through the calipers but still have little pressure on the pedal and need to pump it to get pressure which is firm and can lock up (activate ABS) the brakes. I'm about to give up and take it in but thought I would reach out to see if there are any obvious steps or considerations I am missing. I have read this entire post and others and I'm convinced I am not doing it wrong but I do think I am missing a step not specifically described as it relates to my e92 M3. TIA to all those that reply.
      12-27-2015, 10:37 AM   #60
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Never heard of trying to force air thru the system. That's the opposite of what you want.
      12-27-2015, 11:27 AM   #61
Duckengine
No, not trying to force air through system. Brake booster Reservoir is full before pressurizing pressure bleeder and refilled before it reaches the min line.
      12-28-2015, 12:57 PM   #62
ayao
Thread killer
643
Drives: 1M
All the things I was going to suggest (e.g. revert back to traditional 2-person pedal pushing flush technique) you've already done.
Is it safe to assume that there's no loss of fluid i.e. leaks from bleed screws or the line connection from the replaced caliper?
This must be super frustrating. Please post back when you figure out the issue ...
      12-28-2015, 08:29 PM   #63
Powashiftin
Drives: E92 M3
Ok to use PB plaster on the caliper screws? Don't want to run the risk of stripping a head or breaking a head.
      12-28-2015, 11:18 PM   #64
ayao
Thread killer
643
Drives: 1M
I don't see why not. Would just take care not to get it on the rotors. If they were stuck I'd just buzz them off with an impact wrench ...
      12-28-2015, 11:40 PM   #65
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Why not suck out that fluid instead and not have to pump up pressure twice?
      12-28-2015, 11:49 PM   #66
BzsBimmer
BzsBimmer's Avatar
3274
Drives: '23 G80 FO M3, M3 & MY Tezzy's
I think somehow you got air in the system. You have DCT so no clutch to bleed or worry about. You may need to run through INPA or take it to an indy to pulse the ABS system.
Typically I find, right after a brake flush, you need to start the car and press on the brakes and top off fluid prior, during, and after.
Assuming you went furthest from master cylinder to front, everything you did sounds correct however, the output of your effort points to air in the system.
Since the air/gas is MORE (thanks admranger!) compressible than the fluid, it would make sense that you can eventually build up pressure.
There COULD be some other issue causing your symptom like a leaking master cylinder. The caliper you replaced could also still have air in it since it was new.
m3post
