BMW M3 Forum (E90 E92)
Mporium BMW
      01-14-2010, 02:28 PM   #1
albert1028
Taiwan
20
Drives: 2009 E90 Space Gray M3
Arrow DIY: Aftermarket Exhaust Heat Shield Installation - Difficulty: Easy
There was a discussion about aftermarket exhaust piping not having the OEM heat shield which could lead to premature wear on the rear right and rear left CV boots as well as the differential. (Thread is here: Heat Shield Options for Aftermarket Exhausts Thread"
This picture borrowed from golemite is an example of how close the exhaust pipes are to the CV boots and differential. (Hope you don't mind golemite for borrowing the illustration)
Here's another perpsective:
So for peace of mind and to protect my CV boots and differential, I found an relatively inexpensive and easy to install heat shield. There are other products that Thermotec sells that can also be used to protect the CV boots and differential so you might want to see what works. I know others have ceramic coated their pipes and others have installed heat wraps. I just found this to be the easiest solution.
Parts Necessary:
1. 2 x Thermotec Clamp-On Heat Shield 1 Ft. Length, 4" Clamps- Part Number 11604 (Thermotec Weblink). It would have been better if i had ordered without 4" clamps because although their clamps are high quality Breeze Aeroseal Clamps, they were too large in diameter for my Vanguard Exhaust.
2. 6 x 2.25 Inch Stainless Steel Hose Clamps (this is the diameter of my Vanguard Exhaust, so the actual diameter may be different for your exhaust pipes) from Autozone. This is probably overboard, but I wanted to get Breeze Autoseal Military Spec Clamps but couldn't find any vendor nearby with it.
Tools Necessary:
1. Screwdriver or Electric Screw Driver to simplify installation when under the car.
2. Gloves *Optional if Exhaust is Hot
3. Jack and 2 Jackstands or Ramps to allow for easier access to the exhaust system.
Here is a picture of all the parts/tools that I used:
Procedure:
1. Jack up the rear end of car and set on Jackstands or Put the car on ramps
2. Prepare the Heat Shield by sliding the 3 clamps through the metal tabs but loosen ends of clamps so that they are disconnected from each other.
3. Install Left and Right Heat Shields by sliding the 3 sets of clamps around the exhaust sections that is right underneath the CV boots and differential.
4. Screw and Secure all 6 Clamps in a direction ensuring easy accessibility in the future.
Another angle of left side:
(This is only one side but you get the picture)
5. Check to make sure that all 6 clamps are tightly secured and then You are Done!
6. (Optional) Drive around for a few days and do a quick inspection on all 6 clamps to insure that they are secure
Hope this helps those who aren't too mechanically inclined. Just wanted to help out those who might not know about the heat shields. I know there are others who have posted similar pictures, but I wanted to put this in the DIY section for those who might not easily find it and want a easy to follow procedure.
Online Site to Buy This From:
If you guys want to pick up these online, I found a reliable place, they aren't super fast but I got them for a cheap price.
Here's the link to the one with clamps for $21.89: http://www.race-mart.com/items/produ...604-detail.htm
Here's the link to the one without clamps for $20.49: http://www.race-mart.com/items/produ...600-detail.htm
I have no affiliation with this company. I just saw that they ship for free and they have one of the lowest prices on the web for this!
I had to pick up two, but I guess paying about $41 is worth the peace of mind.
      02-07-2010, 10:30 PM   #2
rav7ks
rav7ks's Avatar
38
Drives: e92 M3
08 M3  [0.00]
Since the install, have you had any NHV issues ?
      02-08-2010, 12:23 AM   #3
albert1028
Taiwan
20
Nope, the clamps are quite strong and since nothing moves around, there has been no increase in any noise, harshness, or vibration. This was done soley for my own comfort because if from factory the stock exhaust had a heat shield, then it'll probably be best to do it as well. They wouldn't increase cost of an exhaust if it was uncessary.
Hope this helps.
      02-08-2010, 04:30 AM   #4
Trier Germany
Luxembourg
58
Drives: 2009 E-90 M3 space gray
Location: Deutschland KreisTrier auf Autobahn 64 & Tucson AZ
The M3 GT4 uses heat tape on the axle back portion to protect from heat. I might have to look into this?
      02-08-2010, 12:07 PM   #5
Jaypod
Jaypod's Avatar
125
Drives: Frozen M3, AM V8V, 991 GT3
Very nice - I picked some up a few months ago. When the weather warms up here I am going to install mine as well.
      02-08-2010, 02:02 PM   #6
Krozi
Krozi's Avatar
Drives: 2008 E92 ///M3 Alpine White
Glad I found this...gonna do the same once my exhaust arrives. Thanks!
2008 E92 ///M3 Alpine White//Fox Red//6MT//
Florida Bimmer - Join us on FaceBook!
      02-08-2010, 02:19 PM   #7
xchosun1x
Track Duty
xchosun1x's Avatar
Drives: Track build 08 E92 M3 DCT
nice...im going to do this next week!
      02-08-2010, 11:02 PM   #8
albert1028
Taiwan
20
Do you have any pictures of that heat tape wrapped portion of the M3 GT4? I'd like to take a look!
      02-09-2010, 02:43 AM   #9
Trier Germany
Luxembourg
58
As requested
http://www.m3post.com/forums/showthr...&highlight=GT4
      02-09-2010, 12:32 PM   #10
swamp2
swamp2's Avatar
Drives: E92 M3
There seems to be a requirement to keep the heat away from the portion of the exhaust closer to the front of the car in the proximity of the driveline. Probably some more rubber components there. Pretty sure there is a radial rubber shock absorber. Does the OEM system have any shields there?
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      02-09-2010, 02:14 PM   #11
ium3
ium3's Avatar
127
Drives: e92 m3
Thanks, exactly what i am looking for. And if you guys call thermo-tec directly and ask for the closest distributors thats located near you, you'll most likely get them much cheaper than purchasing them through their website. I got mine shipped for cheaper than what i would have pay for if i were to buy it directly from them before shipping.
      02-09-2010, 02:14 PM   #12
ium3
ium3's Avatar
127
Drives: e92 m3
Yes, the OEM system do have a shield there.
      02-10-2010, 09:16 PM   #13
albert1028
Taiwan
20
Here's the link: http://www.race-mart.com/items/produ...604-detail.htm
      02-11-2010, 06:50 PM   #14
PunjabiM3
PunjabiM3's Avatar
Drives: M5 CS
Hey guys why not buy Thermo Tec part # 11600 instead of the 11604? The 4" clamp is not used correct?
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia
2020 BMW X7| Mineral White
2024 718 GT4 RS | Arctic Grey
      02-11-2010, 07:22 PM   #15
Krozi
Krozi's Avatar
I did, but I got the clamps anyway.... lol...I'm not complaining lol.
      02-11-2010, 07:51 PM   #16
Lemans_Blue_M
Automotive Industry Insider
Lemans_Blue_M's Avatar
Drives: Lemans Blue M3
Hi Albert,
Glad to see you are happy with the results from the exhaust heat shield mod.
Since you PM'd me a few months ago (asking about an inexpensive solution that works), I was wondering if you ever actually installed the exhaust heat shield.
Great DIY install thread by the way.
The best is yet to come...
      02-11-2010, 09:39 PM   #17
albert1028
Taiwan
20
Originally Posted by Lemans_Blue_M View Post
Hi Albert,
Lemans was the one to guide me to this product! So thank you lemans for your guidance! I love how many members on this forum and willing to help out those that have questions!!!
Thanks for the compliments, hopefully more to come!
      02-11-2010, 09:41 PM   #18
albert1028
Taiwan
20
Yup 11600 would probably work better. Not sure if there's a difference in pricing though. It's like a $1 difference but you would get 3 military grade 4" clamps, guess you can use it for another project! I think these Breeze Aeroseal Clamps are priced around $2.50 each, so 3 of them to have around is nice!
      05-04-2010, 01:02 PM   #19
riyatch
riyatch's Avatar
15
Drives: e90 M3
thanks for this diy.
just wondering if their is any advantage to using this over the heat shield wraps
      05-05-2010, 03:23 PM   #20
albert1028
Taiwan
20
Was hoping that this DIY would help out one person at least. Glad to be of help. I don't think there is advantage except that it is removable and not permanent. I feel it's easier to put and less attention needed as well as time saving compared to heat shield wrap. That's my $.02.
      12-02-2010, 12:53 AM   #21
py0413
py0413's Avatar
110
Drives: Slow
this is just what i need. thanks for the great DIY and product info.
I have vanguard exhaust as well.
Must stop eating..............
      06-24-2012, 01:03 PM   #22
MikeyV3D200
MikeyV3D200's Avatar
Drives: 2008 E92 M3
Just did this for my Meisterschaft GT2 muffler install.
m3post
