BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      06-18-2012, 06:52 PM   #23
DARK_M3
Drives: 08 E90, 89 Grand Wagoneer
Originally Posted by CCL16M3 View Post
Since your kind of on the topic, what is the purpose of the passenger side vent since its a closed rubber piece???
I see no purpose except to hold excess heat in the engine bay. I removed mine.
      02-03-2013, 03:56 PM   #24
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Great post. Used the DIY to solve 2 problems:
1. Top painted plate was the source of a rattle
2. Polishing the hood and restoring the black to the plastic mesh piece.
Thanks!
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
      07-26-2013, 06:55 PM   #25
OilPatch
OilPatch's Avatar
Drives: VW TDi & BMW M3
2013 BMW M3  [0.00]
2010 VW Jetta TDI  [0.00]
stupid question but does BMW make any of these that are different? Specifically the edition ones that are black chrome?
2013 E92 M3 | Le Mans Blue | 6 Speed Manual | Competition Pack | Premium Pack | Cold Weather Pack |
      07-26-2013, 07:50 PM   #26
ducman
Drives: E92 M3
No. IND can paint it any color for you but not black chrome.
      01-16-2014, 03:02 PM   #27
M3-S65
43
Drives: M3
Originally Posted by Snow M3 View Post
I just did mine but I didn't have to go under the hood. That seems way too much work. I just pried them up from the top, starting at the thin rim part (toward the front) and worked my way back (toward the windshield). There are tabs on windshield side so starting on that end would be too hard and could even break the OEM vent. My hood vents are from AutoTecknic and they don't fit 99%. I'd say 95% but still looks pretty good.
Be careful with taking it off. Like this post ^^^ above states. There are tabs that the OEM vent slides onto (rear portion near windshield). Once you release the "thin part" (either by prying up like post above states or from underneath with a screw driver) you need to wiggle the larger part in a forward motion pulling it away from the windshield DO NOT pull straight up it will break the OEM vent.
When releasing the "thin small part" of the vent I went from underneath and used a screwdriver. The tabs of the OEM vent actually insert into the plastic OEM beehive black vent. If your car is not black (like the plastic bee hive vent ) you will see the OEM vent tabs, as they will be the same color as your car. With a small blade screw driver pry the tabs to release them, very little pressure is needed. Then push each tab up with the screwdriver popping them out. Will make a crack sound when they pop out. Prying from above may damage the clips on the OEM vent and also damage the paint. IMOP.
      12-11-2014, 02:17 PM   #28
steven_s
50
Drives: M3
Just did this. Made the mistake of going under the hood and removed the rubber seal. Took me forever to put it back on.
Then just followed this:
      04-28-2015, 08:16 PM   #29
hayes180
hayes180's Avatar
Drives: E92 2013 M3
2013 E92 M3  [10.00]
when removing the vent, make sure you put a rag (one that you would use to polish your bimmer) around the hood vent when removing, not to scrape the paint or your hood itself. Besides that the above method in the video is great and is what i used to install my carbon fiber hood vents !
Good luck to everyone doing it!
      08-04-2015, 09:55 AM   #30
soredogg
soredogg's Avatar
Drives: 2017 BMW M3 Jahre Edition
Thanks for the tip! Where did you pick up your carbon fiber hood vents from?
      08-10-2015, 10:02 PM   #31
hayes180
hayes180's Avatar
Drives: E92 2013 M3
2013 E92 M3  [10.00]
soredogg,
here you go https://www.bimmian.com/AutoCarbon-C...r-E93-3-Series
m3post
