BMW M3 Forum (E90 E92)
BPM
      05-15-2011, 07:57 PM   #1
BimmerM
BimmerM's Avatar
Drives: '21 F95 X5 M C, '11.5 E92 M3 C
2013 BMW X5 M  [0.00]
2011 BMW M3  [0.00]
DIY: Replace Side Gills (easy method) on E92 M3
I took over 2 months before I finally installed my gills (back in January) as I wanted to figure out an easier method to install them. Here's how I installed mine. Hopefully it'll help you guys. Once you get the hang of doing one side your see it'll take you less than a minute to pop them out. Hopefully this will help you guys.
Tools Required
  • Scotch Packing Tape (or any super strength tape that doesn't leave adhesive behind when you peel it off)
  • Blue Painters Tape
Before you begin:
If you are afraid of scratching your car, tape the painted surface around the gills with painters tape
Installation
Step 1. Remove OEM chrome side gill
Apply packing tape to the end closest to the door (ie. the part pointing toward the rear of the car). To apply the tape, pull a long strip of tape and tape the ends to the top and bottom of the gill then press the tape together.
Assuming you are working on the driver's side (left) gill (you will do the opposite for the other side):
  • Use your right hand and grasp the long piece of the tape with your right palm and your last three fingers (your middle finger, ring finger, and pinky finger).
  • Now using your right thumb and pointer finger, grab the top and bottom of the gill pressing down on the tape.
  • So that your left hand don't feel lonely, grab the middle of the gill with the fingers from your left hand.
  • Wiggle up and down while you pull on the tape.
  • The gill should pop right out easily.
Step 2. Do not drop the wire behind the fender
Tilt the gill out of the fender to expose and pull it out.
Before you disconnect the wiring, use some painters tape to tape down the wiring so that it doesn't fall behind the fender. If it fall behind the fender you will extend your install time MUCH MUCH longer trying to fish it out.
Once the wire is secure and you know it won't fall behind the fender, unlatch the wiring harness plug from the gill.
Step 3. Install new gill
Finally, the easy part!
Plug the wiring harness into the new side gill then insert the larger end of the gill into the fender and line up the mounting points.
Simply press the gill into the mounting points till it's flush. You are done!
Below is a comparison of the OEM chrome gill vs the new OEM M3 Edition black chrome gill
Disclaimer: Use this DIY at your own risk, I'm not responsible for any damage to your car.
Appreciate 4
      05-15-2011, 11:37 PM   #2
Bimmerboy888
Bimmerboy888's Avatar
Drives: E92 M3 DCT
Great way to do it!
BAVARIANBEAST
      05-16-2011, 11:38 PM   #3
stealthM3
stealthM3's Avatar
20
Drives: 08 e90 M3
Nice man and thanks for the DIY! Im assuming it'll be the same for the e90 though? Heard alot about it being harder on the e90 for some reason...any more pics of the black chrome installed? BTW where did you get them from? Thanks!
      05-17-2011, 12:17 PM   #4
BimmerM
BimmerM's Avatar
2011 BMW M3  [0.00]
I'm not too certain on the E90 as I have not done it on the E90. However, I would assume it would come out similiar.
I bought my M3 "Edition" gills from getBMWParts.com.
Unfortunately I haven't really taken too many closeup shots of them installed. If you search on the forum there's many that have posted pics of them installed.
      06-10-2011, 05:57 PM   #5
phildeez010
Drives: 2011 E92 M3
This DIY worked out great, just make sure to put a thick layer of blue tape to avoid scratches. Also let the car sit in the some for a bit he helps out
      06-22-2011, 09:41 PM   #6
艾利克斯
Drives: SG E92 M3
Great method!
Actually I found it's easier to do with two people.
I have my girlfriend pulling the tape while I pull the gill upwards, and it pop off easily.
      06-26-2011, 05:24 AM   #7
bobs619
bobs619's Avatar
Drives: 2014 Saphire Black F10 M5
+1 worked for me!
      07-07-2011, 06:45 PM   #8
Brucewonder
Brucewonder's Avatar
33
Drives: 2011 E92 M3 yea boi
worked like a charm to get off the car. 30 sec for each side. Now, the only trouble im having is removing the chrome body from the black end thingy. Cant seem to get the 2 clips loose
      07-18-2011, 07:32 PM   #9
rye m3
Switzerland
33
Drives: 2011.75 E92 M3
OMG! You are a genius man! Simply wrap the tape around it, hold the gill with a micro fiber towel, wriggle the gill in the towel and pull hard on the tape. I changed both sides in 10 minutes! Holy crap, to think of people ripping out their fender liners and prying these things off with a screwdriver... This method there was no way you damage anything. They pop out, but not violently, very easy to control and no chance of damaging the paint or the gill.
This board should have reputation points like 6 speed. You certainly earn some with this.
E92 M3 MR on Red/Black ZCP Sound
Carbon
2007 997S - sold
2003 E46 M3 Steel Grey on Red- sold
1997 E36 M3 Arctic Silver on Black- sold
      07-18-2011, 07:43 PM   #10
BimmerM
BimmerM's Avatar
2011 BMW M3  [0.00]
Glad you found it useful.
      07-29-2011, 07:52 AM   #11
mmaroto
Drives: 2011 M3 e90
Please clarify...
Can this method also be used to replace gills on a 2011 e90? I ask bc of the "grille" on the gills unlike the vert or coupe.
thanks
      07-30-2011, 01:55 AM   #12
OC3
Havin' a blast!
OC3's Avatar
Drives: 2013 M3 E92 Jerez Blk DCT ZCP
Originally Posted by mmaroto View Post
Please clarify...
thanks
Not so simple on E90, lulz
http://www.m3post.com/forums/showthread.php?t=497779
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
      09-28-2011, 09:32 PM   #13
mazing
mazing's Avatar
14
Drives: 2011.5 Jet Black M3
Brilliant worked just as indicated. Just completed install on E93 took about 20 mins. Thanks for this method.
2011 Jet Black Bamboo Novillo/DCT/Gloss Black Grills/Gloss Black Reflectors/Gloss Black Side Gills w/Light Tinted Lenses/Black Vinyl Window Trim
      10-08-2011, 06:20 PM   #14
llis
octane chick
llis's Avatar
Drives: ex-M
2013 BMW M3 ZCP  [10.00]
2003 BMW M5  [0.00]
Sticky this thread, please!
I am shaking my head, seeing how obvious this approach is, because the hardest thing about swapping gills was getting a firm grip on it to get it out. It takes gorilla grip to do it! But the tape technique could really help.
Now did I read you right: OEM black chrome gills? I got black chrome, but they were not OEM afaik.
Edit: Moderators, please sticky this thread. This is very useful!
      10-08-2011, 10:13 PM   #15
BimmerM
BimmerM's Avatar
2011 BMW M3  [0.00]
Yes, it was part of the M3 "Edition" car that was released overseas. The OEM Satin/Black Chrome parts can be ordered from here: http://www.trademotion.com/partlocat...catalogid=4462
      11-21-2011, 08:42 AM   #16
JRV
Drives: 2011.75 AWE90M3
To the OP - I love you! LOL This worked like a charm. It was much better than the screw driver trick. The only thing i added was 2 more strips of packing tape from the little end towards the middle for more leverage...you rock!
'11 Black/Black GLK350 (Wife)
'19 Black RAM 1500 Big Horn Night Package
'11 Loaded AW Fox Red/Black/Black Carbon Leather ZCP E90 M3 (Halloween Delivery)
      12-14-2011, 04:00 PM   #17
jwarner
Drives: 2011 E92 Alpine White ZCP
Video instructions
I followed this advice, and it worked extremely well. The packing tape is the key method for getting the gill off with no fuss, all other methods risk scratching the paint or using too much force, in my opinion.
I did the first gill replacement, and then took videos of the second.
Before you start, it's worth watching all 4 videos (sorry, I don't have time to splice them together) so you know all the steps.
Overall, this is a very simple procedure that even non-mechanically inclined people can do.
Now that I've done one set, I could do 1 gill replace and removal in probably 7-8 minutes, so 15 minutes for both sides.
I hope this is useful.
Part 1 is here:
Part 2 is here
Part 3 is here
Part 4 is here
      12-14-2011, 04:07 PM   #18
jwarner
By the way, this should probably be a sticky thread.
Jason
      12-14-2011, 06:56 PM   #19
ss134
ss134's Avatar
230
Drives: F80 M3
Please clarify...
thanks
Even my dealer managed to break the plastic vents when they changed the side grilles for me on my old car - for the E90 the safest way is to remove the wheels and go in from the wheel well - it can be done without doing this but youre taking a risk of something breaking.
2014 AW F80 M3 DCT
2011 AW E90 M3 DCT - Sold
2010 JZB E90 M3 DCT - Sold
2009 6MT E90 LCI 335i M -Sport - Sold
      12-30-2011, 07:07 PM   #20
0311_grunt
9
Drives: 2008 M3
Took 20 min total with replacing all the parts and whatnot. I'm glad I stumbled upon this...all the other DIY's were way too difficult..
      01-01-2012, 11:26 PM   #21
skins333
skins333's Avatar
Drives: 08 E93 BMW M3 MR/21 X7 40i AW
you guys are the best...took less than 10 min total, no scratches. ( i did spend some good time doing research though)
      01-26-2012, 07:40 PM   #22
pak10
Drives: E92
BimmerM
Thanks for the excellent write up. I swapped mine out today and it looks so much cleaner.
m3post
