BMW M3 Forum (E90 E92)
      08-22-2012, 02:51 AM   #23
Dannys M3
Dannys M3's Avatar
Drives: Jaguar F Type R
2008 M3  [10.00]
Looking at the photos, those looks like torx bolt for the drain and fill.
      08-22-2012, 05:30 AM   #24
driftflo
Germany
468
Drives: M2 F87, M3 E92 & E46, C63, 911
14mm allen key... no torx!
      08-22-2012, 07:22 AM   #25
Grail05
Putcha ang ganda...
Grail05's Avatar
Drives: 17 F82 M4
Yes thats right.. not a torx...when doing fluid change on our E92 m3 from Oil Change, Tranny and Diff uses HEX... no TORX...
      08-22-2012, 09:29 AM   #26
Dannys M3
Dannys M3's Avatar
2008 M3  [10.00]
Ok thanks, in the photo it looked like a torx.
      09-10-2012, 11:46 AM   #27
ixm3
Drives: M3x2
FM
Fwiw, you can use non FM fluid and if the noises bother you, then add FM later.
      09-10-2012, 03:19 PM   #28
Grail05
Putcha ang ganda...
Grail05's Avatar
Drives: 17 F82 M4
yes exactly and if people that will use the NON FM FLUID... make sure to get one at MERC dealer which is
16 bucks a qtz... compare to 30 bucks a qtz for the FM version...
      09-10-2012, 11:53 PM   #29
jjw2331
jjw2331's Avatar
54
Drives: 2011 JtBlk e92 M3
Is there any significant difference other than the price between the two oils? For example, does the non-FM perform better vs the FM? Better protection? Better performance from the diff?
      09-11-2012, 08:15 AM   #30
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
I'm using the OE BMW fluid while under warranty.
Has anyone used redline or something else in the rear diff? I would imagine that the Redline 75w-140 would work fine.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      09-11-2012, 08:47 AM   #31
Grail05
Putcha ang ganda...
Grail05's Avatar
Drives: 17 F82 M4
I would assume so... I read somewhere that when your diff starts making the noise BMW will use the FM fluid. I say why wait for that noise just use the FM... I have 72k miles on the car and never made a diff noise, and still opted for the FM fluid just for a piece of mind.
Yes people have used the REDLINE... they dont have a diff fluid that comes with Friction Modifier but they do have an additive. not sure how much you need to mix it but i think its safer to just get the BMW FM fluid.
      09-27-2012, 02:11 PM   #32
driftflo
Germany
468
the more fm, the less the plates inside the lsd grip (so less noise)... so less locking of course!
it also is aggressive to the oil seal.
so i would only use the fm oil if you really need it and dont want to have noises.
for bmw it is easier and more profitable to sell the fm booster oil and dont have to argue with "customer noises".
if you dont have noise issues or dont mind it, stay with the normal syntrax limited slip for better locking performance and healthy seals!
but when talking about locking performance... if you want a proper performance diff, you will need to swap to a clutch-type lsd anyway... vlsd sucks ;-)
      09-27-2012, 02:18 PM   #33
Porschefile
Porschefile's Avatar
59
Drives: E92 M3
I use Redline. It was rec'd by Bimmerworld.
      10-08-2012, 11:55 PM   #34
Cepheus
14
Drives: M3
I also use the Redline 75w140, but remember one think is use the redline 75w140 not the 75w140NS !!!
      02-13-2013, 02:11 PM   #35
jdmish
jdmish's Avatar
Drives: e92
where did you purchase the fluid with FM booster at??
      02-13-2013, 02:20 PM   #36
jjw2331
jjw2331's Avatar
54
Your dealer should have it or can order it for you. (you need 3 bottles)
Or...
You can order online
http://www.ecstuning.com/BMW-E92-M3-...tial/ES197413/
http://www.turnermotorsport.com/p-29...46-e9x-m3.aspx
      02-20-2013, 09:40 AM   #37
LucWerkz
78
Drives: e70 X5 4.8i (Temporarily)
Newbie question but is this the same process for a DCT car? I remember reading somewhere about DCT and 6MT having different diffs...
      02-20-2013, 01:15 PM   #38
jjw2331
jjw2331's Avatar
54
The DCT differential is slightly different in size and has a taller gear from what I understand. However, the process to change the fluid should be the same as well as the differential fluids you use. A quick call to a dealer service foreman should confirm this.
      03-19-2013, 07:45 PM   #39
5soko
5soko's Avatar
333
Drives: M5
Do the plugs have washers or O-rings? Im assuming new drain bolts come with the o ring and both the drain and fill new replacing once opened?
Also anyone have a copy of the TIS of changing the rear diff oil? That would be awesome!
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
      03-19-2013, 11:45 PM   #40
jjw2331
jjw2331's Avatar
54
Both plugs have rubber o-rings in them. I've reused them with no leaks but it never hurts to use new ones.
      06-17-2013, 01:28 PM   #41
RBB
RBB's Avatar
22
Drives: E92 M3
Going to change my diff fluid this weekend. After the initial fill and a short drive is it necessary to open the fill bolt back up and top off the fluid? I've seen conflicting instructions.
      06-20-2013, 01:13 PM   #42
MasterD78
10
Drives: '08 E90 M3 JB/IR
Just did this, thanks! Super easy!
      06-24-2013, 09:22 AM   #43
RBB
RBB's Avatar
22
Drives: E92 M3
Completed my change this weekend and it was very easy but I had a hell of a time getting the drain bolt out. There simply was not enough clearance between that bolt and my exhaust to fit my 14mm socket plus the wrench. The socket I have was just way too long. Ended up going to the hardware store and found a 14mm nut there that was about 2" long. I was able to insert that into the drain plug and put a 6 point box wrench on the other end and twist the plug off. Put the new one on as well, but obviously I couldn't torque to spec.
Apparently this is an issue for a lot of BMW owners and there are specialized stubby 14mm hex sockets for this application. I found one here and placed an order:
http://www.bimmertools.com/Perfect-f...mstubby3-8.htm
Just a heads up for you guys. You might want to order one of these beforehand and save yourself some trouble. I'm surprised no one else has mentioned having the same problem.
      06-24-2013, 11:42 AM   #44
signes
signes's Avatar
Drives: 991 GT3 RS
I ordered a stubby 7mm hex from them for brake changes and it makes life a lot easier. Pricing is a ripoff but couldn't find it elsewhere.
Thanks to the OP for posting this, going to do next weekend.
GT3 RS | Desperately seeking the next great M car...
m3post
