The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > AVIN 8.8inch - who has this?
      02-17-2018, 12:11 AM   #89
maddmatth
New Zealand
555
Drives: F82 M4, E92 335i
It's really disappointing to read the comments about sound quality. I guess it's a warning sign when it only has Bluetooth 2.0 and doesn't mention the audio processor/DAC.
Definitely won't be buying one now.
      02-20-2018, 12:29 PM   #90
tdott
Drives: M3
Agreed, very close to getting one, but sound quality is a deal breaker.
      02-20-2018, 08:54 PM   #91
siphor1989
Drives: 2020 m340i xdrive
Would have bought this in a heartbeat if the sound quality was like the stock unit.
      03-06-2018, 09:05 AM   #92
Coolhandchuck
Drives: 2007 E92 6 speed manual
Just received my unit from Avin yesterday and today got an email with the install instructions. Before I bought it, I had a message exchange with their customer service and asked specifically if it required use of my "aux" input for use and he said "no". Back to the email... the first thing the email references is:
You must connect the 3.5mm audio cable from the "AUX-OUT" on the MAIN harness to the AUX input under your armrest. (Do NOT make the mistake of plugging this 3.5mm cable into the MIC-IN)
I don't want to insert an analog source into the system and BT sounds like crap. I've already started to return process without even taking it out of the box. There has to be a reasonably price way to upgrade the CCC audio system without the downgrade in sound quality.
      03-10-2018, 10:29 PM   #93
303e90
303e90's Avatar
Drives: Jerez on Black e90 M3
In another thread a user stated that he added an in-line pre amp before going into the aux port. Has anyone else tried this? I just ordered a unit to replace the CCC in my '08 e90. I had read a few complaints about the sound quality before ordering, but not to the extent as in this thread and no I'm second guessing if I actually want to install this or not. The CCC interface really doesn't bother me nearly as much as I thought it would when I purchased the car
      03-10-2018, 11:24 PM   #94
Supermoon
Supermoon's Avatar
South Korea
166
Drives: 2011 e92 335xi
I paired a Fiio amp with Avin 8.8 and music sounds a lot better now but didn't help with the intermittent buzz.
I wish I could use an external DAC like AudioQuest one.
Too bad Android 4.4 doesn't support usb audio output.
2011 E92 335i xDrive
Pure Stage 1 | DV+ & Inlet | Injen Intake | M3 Cowl | ETS 5" FMIC & CP | Aquamist HFS4 Direct Port | CSF Radiator | Wagner Catted DP | BMW PE | Apex FL-5 | Michelin PS4S | 335is Engine mount | SDW Monoball thrust arms | UUC Swaybars & SS Brake lines | Bilstein B8 | Dinan Springs & Shock mounts | Whiteline RSFB | M3 Rear Control arms | Manzo Toe arms | Wavetrac LSD
      03-13-2018, 11:43 PM   #95
e36mcab
30
Drives: e36mcab
Originally Posted by Supermoon View Post
Does the back-up camera support dynamic parking lines? I'd really like to know!
Originally Posted by 08TUNDRA View Post
yes it does!
Is your car a 6sp manual?
Did you wire it like these instructions?
https://drive.google.com/file/d/17vj...p8qoiE531/view
There have been complaints on the F30/32 forums that the dynamic parking lines are not working with the manual transmissions.
'19 M5 Competition - Donington Grey
'99 M3 Convertible - Estoril Blue
'08 M3 Sedan - Sparking Graphite Metallic *Sold*
'95 318ti - Alpine White *Sold*
      03-13-2018, 11:49 PM   #96
Supermoon
Supermoon's Avatar
South Korea
166
No I have 6AT. Both PDC and PAS work flawlessly.
      03-14-2018, 01:12 AM   #97
6ixSpd
Save the manuals!
6ixSpd's Avatar
6016
Drives: '16 M3, '23 718 Spyder
Welp, that's that. Maybe Avin can figure this out in a year or two...
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      03-14-2018, 11:35 PM   #98
e36mcab
30
Drives: e36mcab
Got the answer from Avin USA today...
Dynamic parking lines do not work with manual transmissions for the E90 CCC i-drive.
      03-15-2018, 05:42 AM   #99
dpaul
Drives: 2009 E90 335xi, 2011 E93 M3
The dynamic parking lines work fine on my 2009 335xi iDrive (CIC not CCC) with manual transmission. In fact, its the only thing about the AVIN unit that I'm really happy with.
However, I have PDC installed, which I think might be important
A couple of years ago, I installed an aftermarket backup camera controlled by one of the cheap ebay modules. No matter what settings I coded, the camera would not work, even though many posters with AT had no problems with the same unit. Eventually, I bit the bullet and retrofit an OEM PDC module and rear bumper sensors. To my surprise, the backup camera then began working fine.
Just a thought
      03-15-2018, 12:17 PM   #100
e36mcab
30
Drives: e36mcab
Just a thought
That's very interesting...A few people on the F30/32 forum with manual transmissions can not get the dynamic parking lines to function. It seems to be related to the difference in wiring for rear camera activation. Manuals need a trigger from the reverse light to activate the camera, where I believe the automatics use the canbus for reverse sensing.
      03-20-2018, 12:07 AM   #101
christoepurrr
Drives: BMW M3
Hesitant on installing one of these on my E60 after reading some of the feedback regarding sound quality. I wouldn't consider myself an audiophile, but I can definitely notice when sound quality isn't up to par.
Would pairing this with a DSP such as Bimmertech's PP82DSP solve the sound quality issue?
      03-21-2018, 01:31 PM   #102
Castel
Castel's Avatar
Drives: Tanzanite Blue '13 E92 M3
Interested in this but too bad it doesn't support Android Auto, I have an Android phone and won't be changing it to Apple...
      03-24-2018, 04:33 AM   #103
aclearersky
Drives: 2011 335i
If youre willing to spend 8 dollars you can have Android auto over WiFi by downloading headunit reloaded. There is a free version to try first to make sure your phone works with it but it works pretty well. I'm using it with my note 8 and my Frankenstein setup to help the sound quality
      03-30-2018, 02:23 AM   #104
Cydeen
Drives: BMW E90 320i
Originally Posted by dreyo27 View Post
works OK, install is a 6/10. You will need to dremmel to cut a few things out.
IT IS NOT "PLUG AND PLAY"
but yes I have Logic 7 and it works, it sends the sound in via AUX setting and picks up steering wheel controls via CAN Bus.
Really not "PLUG & PLAY"? Which wire do you mean?
      04-16-2018, 10:14 AM   #105
aclearersky
Drives: 2011 335i
Hey I filmed a tutorial on how to set up headhunt reloaded in order to get android auto to work wirelessly
[YOUTUBE]
[/YOUTUBE]
hxxps://youtu.be/eycPp2cPRWY here is the link in case it stops working
      04-16-2018, 12:28 PM   #106
HollowmanVIII
HollowmanVIII's Avatar
36
Drives: BMW 3 Series E92
Still on the fence about getting one of these after hearing the issues with audio and other bugs.
Of course my CCC looks dated but it's running the latest maps and has usb input, overall it works flawless really.
      05-23-2018, 09:17 AM   #107
Tyetiger
32
Drives: 07 335xi MperorTuning Stage 2
Has there been any other better options out there? I really want to change my CCC head unit. The sound quality issue and the response time with the idrive is a killer for me with the AVIN unit. So far retrofitting to a CIC might be a better option, unless someone has discovered anything else out there.
      05-25-2018, 02:02 AM   #108
officer140
Drives: 2007 Convertible
The topic started was for the Avin 8.8 inch screen but the 10.25 inch screen is mainly talked about here. May sound like a silly question but is there a difference between the 2 units when talking about the poor sound quality and other negative comments? I already ordered my 8.8 inch unit and will have it by this afternoon. I just came across this topic yesterday. My sound system is all upgraded so outside of a severe sound degradation, I'm not really concerned at the moment with poor sound quality.
      06-06-2018, 03:01 AM   #109
officer140
On an update - I installed my unit and have great sound quality. The bluetooth audio volume is not as loud as the AM/FM radio, CD, or aux wire but there is no loss in sound quality. I have played with the features that I would be using the most and have no complaints at all. I'm loving my new Avin unit and am very happy with my purchase.
      06-06-2018, 12:03 PM   #110
HollowmanVIII
36
Does it boot into the avin android side when you restart the car?
