The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > LOGIC7.. Finally, Optimal EQ Settings for E90, E92
      05-14-2018, 09:32 AM   #331
cactusleaf
cactusleaf's Avatar
Drives: 2006 330i MT E90 named Otto
Originally Posted by SoaDMTGguy View Post
Very interesting! I'll have to experiment with this on my drive home.
Question: Why "Concert Hall" not "Theater"? I have those subjective terms... I wish it was just "Stereo" or "Surround".
I'm a total, utter noob about E90s, but I've been thinking about this, and my thoughts so far are: "Theater" (or "Cinema" on my non-iDrive E90) is probably tailored more for center-focused speech-heavy stuff like what might come out of a DVD player, for instance. (Podcasts, perhaps??)
"Concert Hall" (or, on mine, "Music" haha) is better suited for wider stuff that should be less colored by the space it's in. That's what mine seems to do...take out some of the coloring of the car's interior, among other things.
I find "Cinema" to center and almost box the sound in, as if you're in a movie theater. I don't have a DVD player in my car, but some E90 owners do indeed!
Seeing as Logic 7 is the same DSP tech that's in some 7.1 home theater systems, with some of the same settings carried over, having a Theater setting makes sense.
I'm probably wrong about 100% of this.
      06-06-2018, 06:27 AM   #332
BeamerNub
Drives: 3 series
I don't have the LOGIC7 setup, but I tried the first settings in my aftermarket radio and they made a world of difference to the stock setup.
Great job
      04-26-2019, 09:20 AM   #333
Fogger
Drives: 2010 335i Convertible
First, I appreciate all the info provided in this thread. As a previous owner of 2 5 series and a 6 series, I must say I'm really enjoying this 335i.
Regarding the settings, I initially used an iPod with the cable and found the initial settings in this tread to work great. Since I moved to an iPhone XR, the connection shows my phone as "not supported". I worked with Apple and BMW but basically chalked it up to newer technology not supporting older technology. Since I decided to go with the Air Enabler, I chose these settings and I must say, they have brought my stock system alive. I"m an olderl guy and still love my music so I've got stuff from the 60's to today and a wide range of genre. I will say if you want to know if your system is really reproducing bass, even though you think you can't get enough, the song "The Embrace" from Al Dimeola's "Kiss My Axe" will give you the results you are looking for. If you are not familiar with the song, there are thunderous bass notes in the song that I believe to be kettle drums. Anyway, thanks again for loving the music and all the feedback that users like me were able to find on this website.
      04-26-2019, 09:25 AM   #334
Fogger
Air Enabler
These are the settings I was referring too!!
Originally Posted by Isaiah5411 View Post
Turns out the Dragonfly couldn't handle the volume output of the AirEnabler required to have the AUX input level be anywhere near the other sources (CD, SAT, FM). I could not get it to take more than 70% from the AirEnabler without obvious distortion.
So, I reinstalled the Fiio E17, which I thought initially was defective due to some crackling but realized that it, too, couldn't handle the 95% volume output level I had set in the AirEnabler (with default setting being 60%).
So...I dropped the volume of the AirEnabler down to 85% and bumped up the volume of the Fiio to 58/60...perfect! No distortion and all source levels much closer to being matched. And...the Fiio sounds MUCH better than the Sound Blaster (I originally used) and the Dragonfly...better clarity, soundstage/separation, and detail, especially once I reloaded all CD's into iTunes using Apple Lossless encoding.
But, the point of this post is: With the Fiio and the BavSound Stage One Speaker Upgrade (which is great!), I redid the Spectrum Analyzation...three times on three different days...using an external mic (iPhone as source, iPad mini with mic as monitor) and got a VERY different equalization pattern, something I would not have guessed (see below).
And every genre of music I listen to (from classical to jazz to heavy rock) sounds good and accurate, with only sub adjustments being required (using LPL44 external sub control with my PG xs2500 amp).
Also, the Fiio has BALANCE controls so I was able to adjust the balance to center without using the L7 balance, the latter tending to ruin the soundstage. The Fiio balance adjustment (+4 to Right) was perfect and the soundstage is great.
So...here are my EQ settings with this setup (AirEnabler, Fiio E17, BavSound Staqe One, stock L7 amp and rear speakers and underseat woofers), using AUX input and THEATER Surround setting, not Concert.
Attachment 1142330
Attachment 1142331
Attachment 1142332
Although the 200hz adjustment seemed weird to me at first, it now makes sense knowing we have 4" mids and 8" woofers as stock sizes in the L7 system.
      07-15-2019, 07:25 AM   #335
Jurciks
58
Drives: BMW E91 325i
Can anyone suggest good Logic 7 settings for E91?
      10-01-2019, 02:17 PM   #336
drumm8
Drives: e46 zhp
Anyone? I just picked up an e91 for my wife, trying to figure out the best EQ settings.
      10-02-2019, 11:39 AM   #337
colorado.e9x
eBay Special
colorado.e9x's Avatar
Drives: E90 330xi
2007 BMW 328xi  [9.50]
2006 BMW 330xi  [10.00]
I'd use the E90 settings and adjust the fader to -4 or -5, and tweak the rest of the settings to your preference if that's even necessary
Common sense is a flower that does not bloom in everyone's garden
      10-03-2019, 06:11 PM   #338
drumm8
Drives: e46 zhp
Why -4 or -5 for fader? The recommended here is +2, would you not go higher for wagon?
      10-03-2019, 06:26 PM   #339
colorado.e9x
eBay Special
Drives: E90 330xi
Fader makes the sound go from front to back, I personally use -4 fader in my E90 because I prefer the sound to float around me than be in front of me. The E91 has more space so in my opinion it makes sense that the fader is set lower
      10-03-2019, 07:36 PM   #340
drumm8
Drives: e46 zhp
It sounds like maybe you're saying that lower=rear. It's actually the opposite. Positive (higher) is more rearwards. So in that case I would agree with you 🙃
      10-03-2019, 08:52 PM   #341
colorado.e9x
eBay Special
Drives: E90 330xi
I've read a few other places that - be to the rear and + being to the front idk
      10-30-2019, 12:43 PM   #342
Hotter
Hotter's Avatar
72
Drives: BMW E92 328i -> 330i
What logic7 EQ settings would you recommend for E92 non i-drive, for ppl who like bass?
First post settings seems to be with bass only at high volume.
Update:
I decided to use these settings which gives a little bit more but still reasonable amount of bass (E92 NON I-DRIVE):
80hz 0
200hz 0
500hz +2
1khz +2
2khz -3
5khz -1
10khz +4
BASS +5
TREB +1
FADER +2
LOGIC7 = MUSIC
So far I like it, suggest your settings.
      05-09-2020, 02:59 PM   #343
BWK
BWK's Avatar
122
Drives: E91
Bumping in hopes that someone has nailed down the settings for an E91
      06-07-2020, 05:54 PM   #344
jowiesplash
Drives: e91 xdrive
Also interested in settings for E91 I just bought one a couple of weeks ago... thanks in advance
      06-07-2020, 06:50 PM   #345
colorado.e9x
eBay Special
Drives: E90 330xi
E91 drivers I'd start with the settings for the E90 and just keep tweaking it until you like it, everything's trial and error
      10-02-2020, 03:42 PM   #346
sypher01
Italy
15
Drives: BMW E90 318d LCI
Thanks for the settings!
      03-08-2021, 06:53 PM   #347
Timp11
Drives: Bmw e90
Up 7dsp
Is there any profiles for e90 up 7dsp?
      11-05-2021, 04:31 AM   #348
Hotter
Hotter's Avatar
72
Originally Posted by Malek@MRF View Post
The settings posted above, I recommend using LOGIC7 in the MUSIC mode for NON I-Drive vehicles. Why did I say leave it off before, and now I am saying its good to turn on? Well here is the reason: With the FADER set to 0 or biased toward the rear like how some others recommended, you will get that dreaded rear fading issue, where it sounds like the rear's are cutting in and out.
OMG! I realized that if you set to LOGIC7 to MUSIC for some reason it cuts off rear speakers slightly sometimes! I thought I have bad connection to speaker or bad AMP! Now the question is how to use MUSIC mode without that annoying rear speaker cut off?
      01-12-2022, 08:28 AM   #349
Hyphnx
Drives: BMW 335i
I have been using these settings for 10 years... Absolutely love it
      04-01-2022, 11:41 AM   #350
Trottonyou
Drives: BMW 335i E93
2010 BMW e93  [0.00]
jeez 10 years?
      12-30-2023, 08:40 PM   #351
gmarcs02
Drives: 2012 BMW e92 335xi
E92 Individual Audio 752 option EQ Settings with Spotify
Hey guys I know im about 14 years late here but if anyone has 752 packaged BMW 3 series speakers, here's the best EQ to have with Spotify HI-FI. Bless your ears guys!
i-Drive EQ:
Spotify EQ:
If the links don't work I attached the files below.
