2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 20 inch Wheel Fitment Question.
      05-15-2019, 12:13 PM   #45
sbechard7
23
Drives: BMW 535i
2012 BMW 535i  [0.00]
@.BMW. So none of the wheel options I listed will fit, correct?
      05-15-2019, 12:35 PM   #46
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
All your listed setups will fit (except maybe for ET40 up front).
But the rears are more aggressive than the fronts for all those setups. Can be solved with front spacers if you like.
      05-15-2019, 10:01 PM   #47
716535i
Drives: 2011 BMW 535i
Originally Posted by .BMW. View Post
The good thing with square wheels and tires is that you can rotate front to rear and get more even wear.
With staggered wheels you can fit wider rear tires, either for increased traction or if you like the look.
Make this decision first, square or staggered wheels. Then we can help you recommend tire sizes for the wheels you like to run.
I ended up going with 295/30 r20 101y and 255/35 r20 97w
Seems like a lot of rubber on the road but they are growing on me.
      05-19-2019, 07:07 PM   #48
716535i
I think they are too big 😪
      06-04-2019, 02:59 AM   #49
athras
Greece
Drives: Bmw 520d f10
I believe 40 plus
      07-14-2019, 03:45 PM   #50
Bitchn5ive
Bitchn5ive's Avatar
Drives: F10 550i xdrive
Can I throw one out here:
I have 20x9 et 30 and 20x10 et 38 on a 550i xdrive lowered on ACS springs.
Currently on 245/35 and 275/30 w/o issues but want to go a bit wider.
How do you think 255/35 and 295/30's work out? I've seen people go with these sizes but what about with my offsets and being xdrive and lowered... am I good?
Thanks in advance!
      07-15-2019, 03:45 AM   #51
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Will fit, but the rear will be close to the fender with 295 tire and ET38.
245/35 front and 285/30 will give you more margin.
      07-15-2019, 11:22 PM   #52
Bitchn5ive
Bitchn5ive's Avatar
Appreciate ya!
So, maybe some light rubbing on big dips or with weight/passengers.... been there before on a previous vehicle. I may still test the water with this setup.
Is it widely accepted that PS4's are more square than DSW's? Maybe I'll stand better odds with a more rounded profile.
      07-24-2019, 03:06 AM   #53
Oto Apkhadze
Drives: BMW F10 550i
Hello everyone. I'm new member in this group. My name is Oto and I am from Georgia (Tbilisi). I need you to share me your experience about F10 550i wheels, tires and brake system.
1) I decided to replace 19 inch wheels with 20 inch. I searched more what sizec will be better choice, but I completely confused. I think front wheel sizes should be 20x9 ET 35 / rear wheel size should be 20x10 ET 40. I have standard brake and suspension systems. Question: Could I fit these without any problems and what would be tyre sizes? Front 245/35/R20, rear 275/30/R20 - Are this items (wheels and tyres) suitable for my BMW F10 550i. Thank you in advance.
      07-30-2019, 01:56 AM   #54
Rayzor
South Africa
10
Drives: F10 Msport 535i
Hello everyone.
I am also looking on fitment advice.
Will these fit on my 535i rwd.
20" X 9.5J ET22
20" X 11J ET40
What size tyre would you recommend with minimal stretch on stock M-Sport suspension.
Thanks
      08-03-2019, 01:56 PM   #55
JayBimmer83
Drives: 2016 535i
Love the Niche wheels. I have the same ones but all black. I got the 20x9 square set.
      06-05-2020, 02:30 PM   #56
Nathans0s3xy
Drives: 2013 bmw 535i
hello!!!! I have set of 20" inch and need help deciding which tire set up I should go for without the rubbing and others issues front 20x8.5 rear 20x10.5 please help!!!!!!!!!!!
      06-07-2020, 01:00 PM   #57
aykutsf10
Drives: F10 535i RWD
NEED HELP !
I have a currently stock F10 535i. It still has the stock 19"wheels and stock suspension.
I'm installing a wide body kit next wheels as well as 30mm ST lowering springs. I'm wondering if 20" wheels of any kind would fit without any issue ? (Front fenders will be roughly the same dimensions as a F10 M5 ) Has anyone gone through this process before ? I'm worried that 19"s will look small and 20"s might rub against the inner walls of the fenders.
      06-09-2020, 03:16 AM   #58
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Originally Posted by aykutsf10 View Post
NEED HELP !
which wide body kit are you installing and do you have pictures of the kit?
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~
Follow me on Instagram: lsturbointeg
      07-05-2020, 03:19 AM   #59
al_breezy535i
al_breezy535i's Avatar
Drives: bmw 535i
Hey guys so I'm thinking of getting mrr wheels ground force 6 . Had them on my accord back in the day and I loved them . Plus I think they will look sick on the f10 too .
Looking at 20x9 f and 20x 10.5 r , now I wanna know what offset to get . I want it to be flush and not poking out but I want the wheels to be concaved . Need help with the fittment 😓
      07-06-2020, 12:55 PM   #60
remmib
General
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
What offsets can you choose from? Common fitment for the f10 with those widths are approx et25 F and et38 R.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      07-06-2020, 03:52 PM   #61
Unspec
Unspec's Avatar
1303
Drives: 2015 BMW 535xi
Hey remmib, I'm currently running M5 343M's (20x9 34 F, 20x10 34 R) with 255/35/20 and 295/30/20 on my 535 xDrive. I'm not 100% sure, but I think I hear a tiny bit of rubbing when going over smaller speedbumps. In theory, should that setup fit fine and I'm just hearing other things?
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets
ISTA VM Setup/Tutorial
      07-07-2020, 01:42 PM   #62
remmib
General
remmib's Avatar
Norway
1569
Sounds plausible that the 295s on et34 could rub.
      07-07-2020, 01:49 PM   #63
Unspec
Unspec's Avatar
1303
Interestingly enough, the occasional rub is coming from the front.
2015 BMW 535xi
      07-07-2020, 01:53 PM   #64
remmib
General
remmib's Avatar
Norway
1569
Weird, can't imagine where it could rub in the front.
      07-07-2020, 05:54 PM   #65
Unspec
Unspec's Avatar
1303
Maybe it was just my suspension being squeaky and I was mistaking that for rub? I'll keep an eye on it.
2015 BMW 535xi
      07-15-2020, 08:51 AM   #66
Gavins30
Drives: 2012 BMW 550I
Hey guys, looking at getting wheels with 20x8.5 ET +18 on front and 20x9.5 ET +18 on rear. I have a 2012 550I M sport. Will these fit good or will I run into any issues?
5post
