04-07-2012, 12:20 PM | #45 | |
Rep 600
Drives: 2012 E92 SSII ZCP DCT
AA Green Filter/AA Pulley/AA catless X-pipes/AA signature exhaust/AA TUNE/TMS studs/Project Kics R40/R888/VOLK ZE40/ST60,ST40 BBK/MCS 2WAY NR/Vorsteiner GTS5 Bumper/APR GT250/APR SPLITTER |
04-07-2012, 03:17 PM | #46 |
11817
Rep 23,187
right it works on either and the module is needed for the edc car.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
04-08-2012, 12:19 PM | #48 |
11817
Rep 23,187
do tell. what type of horror stories? when harnesses attack!
04-08-2012, 12:32 PM | #49 | |
Rep 8,076
Drives: 11 E90 M3 Individual
So, again, I'm coming from the standpoint that 4pt belts ARE safer because they provide a significant increase in the control you have over the car especially in a turn. Plus, you've heard...never tried. I've also heard that there are flying pigs and honest politicians...just saying.
2018 F30 320iX Melbourne Red
04-08-2012, 01:07 PM | #50 |
44
Rep 310
If he's talking about "submarining", where you slide down and under the lap belt, that does sound pretty bad. That was the whole point behind Schroth's ASM feature.
Schroth Engineering :: Safety Through Technology I wouldn't buy a 4-point without it. |
04-08-2012, 03:26 PM | #51 | |
General
21117
Rep 20,741
Drives: 2021 911 turbo
However, the risk comes when you are in an accident. With the force of the impact, your torso moves forward and pushes on the shoulder belts. These in turn pull the lap belts upward. So the lap belt is no longer holding you hips firmly against the seat bottom. Instead, it straps around your belly destroying your internal organs in the process . This is what is commonly called submarining. This is where the fifth point comes in. It essentially holds the lap belt down and against your hips in an impact. However you need to ensure you are properly and firmly strapped in for it to work properly. Three point harnesses are designed in a way that when your torso moves forward, the shoulder belt tightens the the lap belt. Made even move efficient with pre-tensioners installed in most modern cars. Very interesting read on the Schroth harness. Thank you Drifty//. They seem to have found a way to work around the problem by leveraging the OEM pre-tensioner system. I will definitely look into it more . Last edited by CanAutM3; 04-09-2012 at 12:14 PM.. |
04-08-2012, 03:51 PM | #52 | |
Rep 8,076
Schroth 4pts incorporate anti-submarining technology for what its worth.
04-08-2012, 05:39 PM | #53 |
Rep 927
What are you all's thoughts on 4 point and HANS devices?
Craig Brickner
Click to Join: BMWCCA # 366493 |
04-08-2012, 06:07 PM | #54 |
Rep 8,076
Don't see how it could hurt but none of the non-quick fit 4 pts will really work with HANS. The quick fit pro does but there's nothing for the E9X chassis yet.
04-08-2012, 10:13 PM | #55 | |
Moderator
673
Rep 4,737
Brakes... if budget is important, get a front kit only. Brembo and StopTech are both great kits. Both will work excellent with the high performance pads that come with the kit (if you are doing HPDE). Parts cost (pads, rotors, etc) will be higher on Brembo. I don't have much experience on AP or Alcon. |
04-09-2012, 06:56 AM | #56 |
General
21117
Rep 20,741
From the Schroth web site:
Current Head And Neck Supports (HANS®) provide further reduction of head deceleration and neck bending. The asm® system on all SCHROTH Rallye and QuickFit belts - excluding the new QuickFit Pro - is not compatible the with HANS®. Only belts having a center RFR Cam lock can be used with HANS®. We recommend that only non asm® belts be used in competition harnessbelts. Racing harnesses without asm® must be worn with an anti-sub strap! |
04-10-2012, 01:22 AM | #57 |
44
Rep 310
Right, so the answer is that you can only use a HANS with the 4-point that's not yet available for the E9x.
Incidentally, I have the QickFit Pro for my A4. It's really nice, except I wish it had the twist cam lock. I don't care about DOT, since I only used them on the street to get acclimated to the sensation of driving while strapped in. Otherwise, it's too inconvenient & restrictive for street use. |
07-11-2012, 10:47 PM | #58 |
44
Rep 310
Reporting back after my first 2-day HPDE in my EDC E92.
Pad changes in the stock calipers suck. I didn't realize how the clips on the stock pads positioned the caliper for you, and it took me forever to get the pins back in with track pads. Then, there's the wonderful anti-rattle clip and the wear sensor. Brake fluid seemed to be coming from somewhere, but I couldn't figure out where. I'm done messing around with the stock brakes. Also, while modulation is pretty good, the stock brakes feel rather squishy. I'll be upgrading these very soon. EDC is crap. The car handles more like a friggin truck. The stock spring rate is incredibly low. If you've had coilovers and know what you're getting into, I'd say skip EDC and buy a good set of coilovers with the savings. I have a coilover suspension on my A4 and it feels so much more controlled and nimble than the M3, and that just ain't right. I'm planning on getting a spring & sleeve kit before my next track day, assuming it works with the camber plates I already bought. M-Dynamic Mode (MDM) is something else to do without. I like the idea of being able to use it on the street, but I usually just leave DSC fully on. On the track, DSC off is the only way I roll. Verdict: while the M button is definitely handy, I wouldn't get the MDrive package just for MDM. Regarding ZCP: I don't have any direct experience with it. From what I hear, it's probably still not firm enough to my liking. Unless you really like the wheels, I'd probably save the money and go aftermarket. Exhaust: stock exhaust sounds better in person than in all the videos I'd seen. I was sure I wanted the performance exhaust, but I'm not going to bother. More money to spend on brakes, I guess.
07-12-2012, 10:52 AM | #59 |
Rep 633
Since we have some experienced folks on this list....
I have had this car for about 2 outings now during DE (instructing, I do get to co-drive with other driver's in club races so this is STRICTLY a street car). I have the EDC and intend to keep it. Besides brakes (thats another subject), my only other issue is that the car turns in great, but once settled, washes off mid corner (terrible understeer), and upon track out, I have no issues putting the power down or and the car is compliant. Partially because I scrub off speed mid corner and at times I literally have to lift for it to bite. I have adjusted my driving so the tire wear is fine and the pins are out in the front for more camber. Would getting plates on stock EDC help with mid corner grip (I am asking because I dont have issues with outside wear) or is this a function of better suspension with stiffer springs? I recall James Clay stating that the dynamic camber on these cars are decent and do not require camber plates. Thoughts? Lutfy |
07-12-2012, 11:38 AM | #60 |
America
Rep 62
I used EDC for a while but it quickly gets old. Its nice if you like to drive to the track and if you are a beginner. As people have indicated, you will want something more. E9X M3's are just too heavy for a soft setup. Far too much body roll on the track. I would definitely look into new suspension. Also, brakes will become an issue even with race pads. That would be my second recommendation. E9X M3's are a blast!
07-12-2012, 05:14 PM | #61 |
Rep 927
Have you guys seen the TCKline EDC spring/camber plate kit?
What kind of truck are you talking about the M3 riding like? 1/2 ton or a dully? I don't think it's fair to say a certain suspension is for beginners. Don't you agree that an experienced driver should know how to drive all types of cars?
Craig Brickner
07-13-2012, 12:05 AM | #62 | ||
44
Rep 310
I'm planning to look into a spring & sleeve kit by GC. I already have GC camber plates, so hopefully they'll be compatible.
I want something a bit more taut and energetic, like my modded A4. I've never never felt as enthralled about my M3 as I did about my A4. Quote:
07-13-2012, 08:19 AM | #63 | |
44
Rep 310
But another thing I'm thinking is that this is a natural consequence of EDC. I don't know too much about the tech, but I think it only varies the damper rate. That means that in sport mode, it gives you a high damper rate & low spring rate. I'm thinking the high damper rate is responsible for the initial turn in. The reason for the mid-corner instability is probably that the damper is further compressing throughout most of the turn. Since you're not running as much camber, this probably gives you a smaller lateral contact patch, which means hotter localized tire temps, which could cause the grip to drop off. I'm no expert. Just speculating. Try running more camber and/or better controlling body roll.
07-16-2012, 10:54 AM | #64 | |
Rep 633
Regards, Lutfy |
buying, mods, options, specs |
