N52 Owners: Elec Water Pump Check-In Part Deux
View Poll Results: How many miles have you logged, and have you replaced your water pump yet? | |||
Not yet, I have 60-75,000 miles | 119 | 19.01% | |
Not yet, I have 75-90,000 miles | 97 | 15.50% | |
Not yet, I have 90-105,000 miles | 82 | 13.10% | |
Not yet, I have 105-120,000 miles | 61 | 9.74% | |
Not yet, I'm invincible and have 120,000+ miles | 69 | 11.02% | |
Yes, between 60-75,000 miles | 35 | 5.59% | |
Yes, between 75-90,000 miles | 49 | 7.83% | |
Yes, between 90-105,000 miles | 44 | 7.03% | |
Yes, between 105-120,000 miles | 34 | 5.43% | |
Yes, between 120,000 and xxx,xxx miles | 36 | 5.75% | |
Voters: 626. You may not vote on this poll |
02-06-2017, 01:10 PM | #89 |
54
Rep 141
a. year / model / transmission
2005 325i mt b. did it actually fail or was this preventive maintenance? Failed at 160 000km ~100 000 miles. c. how much did the repair cost (and indicate labor vs parts)? Parts $300-400 (+expenses to get the car home on a tow truck) d. was it replaced at indy or dealer? Replaced it myself e. was there any other damage caused as a result? No damage f. do you track your vehicle? (DO NOT reply if you participate in canyon carving, street racing, etc.). strictly referring to auto-x, road course, drift and drag. No.
Yngvejos.
2005 E91 325i |
02-16-2017, 04:13 PM | #90 |
20
Rep 240
===2011 323i E90 110k km ===
Back in Nov 2015 ( Temp really low around -10*c ?) and in Dec 2015 ( -5*c? and snowing ) , fan was running really really loud, and heard it and went to the closest parking spot that i saw, turn the engine off , waited for around 10 minutes , and continued my trip with no problems at all, other than that , I had no overheating symptoms nor dash lights warnings. The BIG question is.... Should a replace my WP and TM as a preventive maintenance ? Ps : I dont have $1000 in my pocket to spend on this preventive maintenance just because "it won't hurt" |
03-15-2017, 02:28 PM | #92 |
10
Rep 101
a. 01.2005 / E90 330i / Manual
b. At 114,000 miles. Failed within 100 miles of overhauling the suspension. c. £290 parts - water pump and thermostat. £150 labour. About $540 total. d. Indy e. No. f. No.
E90 330i SE Manual / Bilstein B12 Pro / M3 Control Arms / Performance Exhaust / CDV Delete
04-07-2017, 09:02 PM | #93 |
Rep 5
2007 328i
115,000 miles It died 400 for the pump replaced it myself do not track Last edited by superjdavis; 04-07-2017 at 09:03 PM.. Reason: forgot model |
04-30-2017, 09:29 PM | #95 |
Dealer Speed
64
Rep 140
94K Pump died on the highway. Engine temp wasn't even that high and still went into YELLOW, then RED limp mode. Limped about 4 miles home, stopping every mile for about 5 minutes. Initial signs, fan on full speed at cold start for about a few weeks. No check engine light. Scanned on the night of the freeway incident and codes 2E82 DME ELECTRIC COOLANT PUMP CUTOFF 2E81 DME ELECTRICAL COOLANT PUMP, SPEED DEVIATION. My oil pan is leaking, and had a recent oil filter housing leak that leaked FOREVER. This oil leaked down onto the water pump may have had something to do with...
Edit: Original post: 4/30/17 Today: 2/10/18 Replaced water pump with aftermarket Orion Tech and still running strong.. |
05-20-2017, 04:34 PM | #96 | |
Rep 43
a. Nov 2005, 330i, 6MT b. preventative maintenance - but it was making an electrical buzzing sound which worried me, and when I took it off, the impeller shaft rattled and wobbled about - I don't think it was going to last much longer. That said, the car never overheated (in my time) and showed no real signs that it was gonna go. c. £333 pump + £50 thermostat. d. myself. e. no damage yet. f. no track as of yet, mostly longer journeys but do give it a hoon now and again. Last edited by zippyonline; 05-20-2017 at 04:36 PM.. Reason: It's not a record! |
05-21-2017, 06:04 PM | #97 |
Rep 40
Drives: '16 340i Estoril/Saddle/THP
Haven't been too active on here but I should give some info to help out the next generation of e90 owners. Here you go:
a. year / model / transmission - '06 330i Auto b. did it actually fail or was this preventive maintenance? Failed! Overheated while driving someone to the airport in the summer. I did consider preventative swap a year or two before but never ended up doing that. c. how much did the repair cost (and indicate labor vs parts)? Parts: Thermostat - $140 Water Pump - $546 Coolant - $85 (2 gallons) Total - $780 Labor - $360 d. was it replaced at indy or dealer? Indy e. was there any other damage caused as a result? Nope, continued on another 10+ miles in limp mode to get to airport. Opened hood and cooled off for a bit, then drove to mall and let sit for couple of hours. Added water, drove 3 miles and overheated again. Parked and called tow truck from there. f. do you track your vehicle? (DO NOT reply if you participate in canyon carving, street racing, etc.). strictly referring to auto-x, road course, drift and drag. Nope, occasional spirited driving but no tracking. Had car since '10 with 42k. Failed at 86k Overall, this was the first real failure or maintenance issue I had with this car in the then 6 years of ownership. |
05-29-2017, 10:55 PM | #98 |
Rep 4
a. 2005 330i Auto
b. Failed, overheated on highway however after turning the car off pump continued to work long enough to get home c. all from FCP around 500-600 AUD d. replaced by myself e. upper rad hose needed replacement after swap f. never being tracked |
06-01-2017, 07:20 PM | #99 |
Save the manuals!
6028
Rep 6,754
2009 328i RWD 6MT
134k miles and counting on original WP & TStat I have a replacement kit ready to go preventatively when I have some time to do it.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
07-04-2017, 11:23 PM | #101 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
- 2009 E90 328i AT with 110k km (70k mi) b. did it actually fail or was this preventive maintenance? - Preventative maintenance. There were no symptoms of a failing water pump. c. how much did the repair cost (and indicate labor vs parts)? - Wahler thermostat and Pierburg pump were $330 and BMW coolant (concentrate, 1 gal) was $20 from FCP. The parts were exactly the same as the factory parts I replaced but without BMW logos. The pump came with the three mounting bolts. I used around 1.8 gal of coolant (50:50 mix) to refill the system. d. was it replaced at indy or dealer? - DIY in about 5 hours on jack stands. e. was there any other damage caused as a result? - No f. do you track your vehicle? (DO NOT reply if you participate in canyon carving, street racing, etc.). strictly referring to auto-x, road course, drift and drag. - No |
10-22-2017, 09:06 PM | #102 |
Rep 8
a. 2006 330i manual
b. Failed on highway on 90 degree day. Somewhere around 114k miles. Got the dash warning to stop running the car. Pulled over, let it set for about 10 minutes while I investigated online. Turned off AC, opened the windows and ran the heat to cool the coolant more than normal. Made it the 30 miles home at normal highway speed in this condition with no more dash warnings after resetting. c. Parts were $336.82 including water pump, thermostat, BMW coolant, and new bolts. d. Replaced myself e. Luckily no other damage. Car still runs great! f. I do track my car, but not before this. I have only owned it since 100k miles, so no idea how it was treated beforehand. |
01-04-2018, 06:50 PM | #104 |
King of Goodness
152
Rep 185
Drives: 2012 128i Coupe
I'm replacing my 2012 128i water pump and thermostat at 61K as a proactive measure. I have replaced a lot of parts as a hedge against failures. If the 128i can give me another 5 years and 60K miles of relatively trouble free driving, I'll be happy and glad that I did...
01-08-2018, 04:34 PM | #105 |
Combined Applications Group
1061
Rep 680
a. 2008/ 323I N52B25 / 3 pedals
b. Failing, weird temp fluctuations - 195xxx KMS c. Total 960 USD, Pump $400, Thermostat $120, Coolant and Labor rest d. Indy, I had no time to do it e. No? f. no Track, Drive it hard as hell every day though
02-05-2018, 07:30 AM | #106 |
25
Rep 167
a. 2006 325xi AT
b. Failed 100k c. $200 For pump and thermo along with replacement bolts. I do all the work on my car. d. I did the work e. None f. No do you? |
04-30-2018, 03:17 PM | #107 | |
Crazy Frog
543
Rep 1,212
How is it holding up? Any issues?
05-04-2018, 11:40 AM | #108 |
Rep 20
a. 2007 328i sedan w/manual transmission
b. Water pump actually failed at 124,732 miles c. $410.09 (USD) w/shipping for the pump, thermostat, connecting hose, and bolts. d. I did the work myself. e. Yes, the thermostat sensor plug wire broke off and I needed to replace the plug and wire, took a bit to find and assemble, cost an additional $15 USD for parts and shipping. f. Infrequent (e.g. once per year) track days, previously autocrossed |
05-22-2018, 03:30 PM | #109 |
25
Rep 167
NO issues, they are all plastic ones these days if they OEM spec or aftermarket all the same honestly if they are going to fail they are going to fail.
06-14-2018, 07:47 AM | #110 |
45
Rep 157
Drives: 2011 328i
A. 2006 325i 6MT
B. Failure at ~150,000 miles C. $300 parts, $0 labor D. Self installed E. No F. No |
