BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 328i wheels offset ?
proTUNING Freaks
      05-01-2012, 10:43 AM   #1
HKF30-328i
Drives: F30
Dear Brother,
I want to change to 19'x8.5J, which is the best Front & Rear offset, Thanks!
Alex
      05-01-2012, 10:55 AM   #2
E90Fleet
South Africa
1312
Drives: BMW
Standard offsets
F30:
18"
8Jx18
ET 34
19"
Front 8Jx19 ET:36
Rear 8,5Jx19 ET:47
20"
Front 8Jx20 ET:36
Rear 8,5Jx20 ET:47
BMW if you are reading, I need a job, Please.
      05-01-2012, 11:06 AM   #3
HKF30-328i
Drives: F30
Originally Posted by E90Fleet View Post
Standard offsets
F30:
18"
8Jx18
ET 34
19"
Front 8Jx19 ET:36
Rear 8,5Jx19 ET:47
20"
Front 8Jx20 ET:36
Rear 8,5Jx20 ET:47
Thanks buddy, do u know the pcd?
      05-01-2012, 12:30 PM   #4
E90Fleet
South Africa
1312
Drives: BMW
I believe its the same as the E90 , 5x120
But i cannot confirm that.
      05-01-2012, 12:51 PM   #5
J1n
Drives: R8 V8 '14
Kinda noob question here but could someone explain what this "offset" is?
      05-01-2012, 11:19 PM   #6
_BMWnEwBiE_
Drives: 2012 328i
source Tirerack
http://www.tirerack.com/wheels/tech/...jsp?techid=101
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).*
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
      05-02-2012, 01:41 AM   #7
J1n
Drives: R8 V8 '14
Thanks for that. So every wheel will have different offsets ?
SteelCT27.00
      05-15-2012, 02:51 PM   #8
ModBargains.com
Drives: JB E92 335i
You can run the 19x8.5 ET35 up front and the 19x9.5 ET40-45 in the rear without any issues on the F30!
      09-05-2013, 01:26 PM   #9
echangf30
Drives: 14' F30 MSport 335xi
what about et25 with 19x8.5 will that fit??? what tire size do I need?
      09-11-2013, 04:12 PM   #10
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
Have you tried 245/45 for front ?
      06-30-2014, 10:54 PM   #11
F80 M Freak
F80 M Freak's Avatar
Drives: 2016 f80 m3
Help please!!!
what's the correct off set if I want to put 19x9 front and 19x9.5 rear on a F30(2014 328i)???
Thank you!
      07-01-2014, 12:10 AM   #12
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Around 35 front and 40 rear.
      07-01-2014, 02:57 AM   #13
rustyminded
248
Drives: BMW 328i
I will get 18" with 8-8.5 wide & 18" 8-9 wide depending on wheel and I have 12mm & 15mm wheel spacers.. any idea what wheel & what offset to use with spacers
      07-01-2014, 03:12 AM   #14
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Why do you want to use spacers?
If you look for new wheels isn't it better to find a direct fit for F30?
      07-01-2014, 04:16 AM   #15
rustyminded
248
Drives: BMW 328i
First time to get an aftermarket wheel, I want aggressive look with normal tires because of the availability of tires in my country 18" are good but 19 no good
      07-01-2014, 06:21 AM   #16
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Spacers are often used to give a car a more aggressive stance with existing wheels.
If you buy new aftermarket wheels you can look for wheels with aggressive offsets directly instead of buying wheels that need spacers to result in a wide stance on F30.
An example of a staggered setup for F30 without need of spacers:
F: 8.5x18" ET35
R: 9.5x18" ET40
1/2" wheel width corresponds to 6mm in offset, which means that a 8" ET29 wheel will look similar to a 8.5" ET35.
      07-01-2014, 06:42 AM   #17
rustyminded
248
Drives: BMW 328i
F: 8.5x18" ET35
R: 9.5x18" ET40
That's a lot of info for me lol, what's the offset ? sorry for my ignorance in wheels
the most important thing that I can get 245 & 255 so for instance if i have 9.5 won't it be too much for 255 wide as the rims will be out ? & i don't want that, I want aggressive look while protecting the wheels from road as well
      07-01-2014, 07:17 AM   #18
franzzz
franzzz's Avatar
Italy
144
Drives: BMW M4
F: 8.5x18" ET35
R: 9.5x18" ET40
for your point of view is correctly fitted this setup ? :
F: 8.5x19" ET35
R: 9.5x19" ET35
http://www.ebay.it/itm/111368685264?...84.m1436.l2649
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
      07-01-2014, 07:29 AM   #19
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Offset, also named ET, explain where the hub of the wheel is located relative to the centerline of the wheel. Offset in combination with wheel width is most important when looking for new wheels.
Lower offset results in wider stance.
If you like 245 front and 255 rear tires the most narrow wheels you can choose are 8" front and 8.5" rear. With those wheel and tire widths you can search for wheels with front offset around 30 and rear around 35.
F: 8x18" ET30, 245/40-19 (1% shorter than OEM)
R: 8.5x18" ET35, 255/40-19 (OEM F30 tire size)
If you find wheels you like with higher offset you may fit them with use of spacers.
      07-01-2014, 07:34 AM   #20
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
F: 8.5x19" ET35
R: 9.5x19" ET35
The rear is aggressive for F30, but it works with slightly stretched tires.
Here is a member with very similar setup: f30.bimmerpost.com
      07-01-2014, 07:41 AM   #21
franzzz
franzzz's Avatar
Italy
144
Drives: BMW M4
Ok tnx !!!
I try to find a rear 9JX19 ET 35
      07-01-2014, 10:23 AM   #22
rustyminded
248
Drives: BMW 328i
Great !! I can't go lower than 45 side because of our roads, so will i be able to fit wheel spacers with this setup or it will rub ?
