R44 Performance
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > M3 / M4 Photos and Videos
View Poll Results: Do you have drone WITH the valve mod?
YES, I have a DCT and have drone WITH the valve mod. 29 36.71%
YES, I have a 6MT and have drone WITH the valve mod. 4 5.06%
NO, I have a DCT and DO NOT have drone WITH the valve mod. 16 20.25%
NO, I have a 6MT and DO NOT have drone WITH the valve mod. 30 37.97%
Voters: 79. You may not vote on this poll
      11-29-2014, 01:20 PM   #1
Accel Junky
High on Acceleration
Accel Junky's Avatar
Drives: 08 M3, 90 GTR, 21 Gladiator
Exhaust Valve Mod Comparison Video - Dueling F80 M3s
BIMMERPOST
     Featured on BIMMERPOST.com
UPDATE: POLL added regarding drone. Please vote.
One of the advantages to having multiple M3s at my disposal is the ability to make live comparisons.
Today, I had my wife assist me with comparing her unmodified stock exhaust with valves closed to my M3 with the exhaust valve mod (valves locked open). This used to be called the golf tee mod back when I had my 335i.
There is a noticeable difference but nothing crazy it seems. Hope this helps someone deciding whether to do the mod or not. The best thing is that it takes literally seconds and is easy to restore if you don't like it.
I just added this one today...cold start comparison of no mod vs exhaust mod:
Added 12/15/2014: Interior view cruising, Light acceleration, cruising with stereo:
Added 12/20/2014: Exterior view accelerating at part throttle comparing wife's unmodded F80 and my F80 with the exhaust valve mod:
How to do the mod:
This is directly from the sound engineer responsible for the F8X and may indicate why the poll shows a lot more drone reports from DCT-equipped cars:
"There are also ranges in which we have chosen to close the valves, for instance at low engine speeds in high gears. In these ranges, which are frequently selected in the automatic mode of the M DKG Drivelogic for driving at maximum efficiency, the exhaust tract in turbo engines would have a tendency to drone if there were no damping."
Appreciate 11
      11-29-2014, 03:01 PM   #2
SOM3
Drives: SO F80
Does it drone with valves open? It sounds like it would.
      11-29-2014, 03:46 PM   #3
///M ARMY
Drives: F90
why would it drone? its on sports mode all the time.
2022 RAM TRX
2021 Ford Bronco
2022 BMW M3
      11-29-2014, 03:50 PM   #4
Accel Junky
I don't think it drones. I think it is just like rolling around in sport plus. It is louder but not by much.
      11-29-2014, 04:36 PM   #5
Jaguar
Mark 42
Jaguar's Avatar
1051
Drives: M
It does drone but only at lower speeds and during street driving in 2, 3 and 4th gear. Freeway driving at cruising speed is not a problem in regards to drone.
This is different than just being in sport +, because while in sport +, the flap is constantly opening and closing part way to eliminate drone, this mod keeps the flap fully open which makes the car louder in the lower RPM range.
After a month of driving around with this mod, I just plugged it back in to stock form, mainly due to the cold starts creating earthquake like rumble and I was living in fear of being marked for death by my neighbors.
      11-29-2014, 05:09 PM   #6
chiplee
chiplee's Avatar
307
Drives: 2015 M3
Thanks for taking the time to put a video comparison together. You certainly are in a unique position for this sort of thing with two F80's in the garage.
So I'm gathering it would be pretty easy for an industrious owner to wire up a switch that would give you full control inside the car to command these valves to just stay open when you want, and then go back to normal ops when you want, ala Jag F type...
Jimjamz4581.50
      11-29-2014, 07:11 PM   #7
KevinM
KevinM's Avatar
2936
Drives: 2002 M5;2007 M Coupe;2020 M2C
2020 M2 Competition  [10.00]
2007 E86 M coupe  [8.38]
2002 E39 M5  [9.00]
Thanks for the comparison - yours is quite a bit louder than your wife's!
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel
2007 E86 Z4M Coupe Silver Gray/Black
2021 Kia Telluride (hauler)
      11-29-2014, 07:33 PM   #8
CanAutM3
General
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
According to BMW, it could drone. Even in Sport and Sport+ modes the valves close under certain conditions to minimize drone. From the exhaust deep dive interview:
In SPORT and SPORT PLUS modes, other engine characteristics are selected for controlling the exhaust valves. At lower gears, the exhaust valves are always open, while when higher gears are selected under constant driving conditions, they are closed; however, if the load conditions change accordingly, they open up in a flash. There are also ranges in which we have chosen to close the valves, for instance at low engine speeds in high gears. In these ranges, which are frequently selected in the automatic mode of the M DKG Drivelogic for driving at maximum efficiency, the exhaust tract in turbo engines would have a tendency to drone if there were no damping.
      11-30-2014, 01:38 PM   #9
Accel Junky
I just added a new video to the first post with cold start comparison.
      11-30-2014, 01:48 PM   #10
wolfbane1967
93
Drives: BMW M2
Hi
Sorry, but how is this fix Done ?
      11-30-2014, 02:03 PM   #11
wolfbane1967
93
Drives: BMW M2
Originally Posted by wolfbane1967 View Post
Hi
Found it
      11-30-2014, 02:16 PM   #12
Accel Junky
Found it
I made an instructional video yesterday. Did you find it?
Appreciate 6
      11-30-2014, 03:01 PM   #13
Gac101177
M4-SAHD
Gac101177's Avatar
512
Drives: M3
2015 BMW M4  [10.00]
Found it
Thanks for the video, I'll try this When I get home
      11-30-2014, 03:11 PM   #14
GrussGott
GrussGott's Avatar
Drives: 2018 M4 Comp Indv
Awesome Values-open cold start is definitely the angry-neighbor mod ... thinking I'm gonna go for it.
Originally Posted by TurtleBoy View Post
He tries to draw people into inane arguments, some weird pastime of his.
      11-30-2014, 08:24 PM   #15
m5sdse63
Drives: 2014 M6GC CP
So, is this a purely aural mod, or any other advantage to it? Forgive the ignorance if it appears as such...
      11-30-2014, 08:47 PM   #16
Blindside_137
Blindside_137's Avatar
Drives: 2011.75 SSII E90 M3 ZCP
That's much better, and a bit more volume and character. I love what you've done.
      11-30-2014, 09:10 PM   #17
ES_TRADER
344
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [10.00]
2013 X5  [0.00]
2013 335i F30  [8.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
Any noticeable difference from inside the cabin?
      12-03-2014, 10:44 PM   #18
Maddict3
Maddict3's Avatar
192
Drives: 2015 991 GT3
I love this mod!!
2015 Porsche 991 GT3 Sapphire Blue Metallic
2015 BMW F80 M3 Silverstone Metallic
      12-03-2014, 11:31 PM   #19
YianniM3
YianniM3's Avatar
Drives: F80 M3
2011 335i  [10.00]
Am i really debating getting out of bed walking down three flights of stairs and trying this right now haha. sounds much louder to me
Current:F80 M3 SB/SO Full leather, Black Wheels, Executive Package, Adaptive Suspension, Manual
Sold: LeMans Blue 335i e92
Sold: JB 325xi e90
      12-03-2014, 11:55 PM   #20
onatuesday
Drives: Hyundai
It does drone unfortunately. But the startup sound went from being embarrassing to being something you can be proud of.
      12-04-2014, 09:48 AM   #21
Diver
Diver's Avatar
Drives: Black '12 135i - Sold
I suspect on M cars the valve is open more often than on a regular 335.
      12-04-2014, 09:56 AM   #22
BMV///M3
BMV///M3's Avatar
419
Drives: BMW f80 M3
Your car sounds so much better cold start, no comparison. Me doing this at 5:30am might not be the best thing, but boy it sounds great.
exhaust, f80, f82, mod, valve
f80post
