      11-14-2019, 03:56 PM   #1
austinaslink
Automotive Enthusiast
austinaslink's Avatar
Drives: 2011 PS2 N55 135i
Austinaslink's PS2 N55 135i Build
Fellow enthusiasts,
I decided it was finally time to create my own build thread and begin contributing back to the community that has provided me with so many answers, ideas and inspiration over the years.
I bought my 2011 135i in March of 2017, completely stock.
- 2nd Owner
- 60,xxx miles
- N55
- 6MT
- Alpine White
- Black Interior
- M-Sport Package
- Harmon Kardon Sound System
- Detailed Maintenance Receipts
I was coming from a 2014 Hyundai Genesis Coupe 2.0T R-spec that I had done FBO/suspension work on and just simply gotten bored of. I've owned 15 cars in my life, including a RHD 1993 Mazda FD3S RX-7, TT 300ZX Z32, Bugeye WRX, S13 240sx's, BMW Z3, E39 540i, GC8 2.5RS, V6 Swapped MR2 and a few others.
I come from a mostly Japanese car background, but have always wanted another BMW after owning my Z3 and E39 540i. There's just something about the solid build quality, sound, and feel that calls to me.
Enough about me. Here's some pictures of my 1er shortly after I purchased it. Completely stock, and the perfect canvass for my next project. At the time, the car was going to be my dedicated daily driver, alongside my Yamaha YZF-R1.
AS OF 1/12/2021
Current Mod List/Maintenance History:
Engine
- Pure Stage 2 Turbo
- Wedge Custom Tune (92 Octane/18psi, dyno’d a conservative 400whp)
- 3.5 Bar TMAP Sensor
- Mosselman Single Oil Cooler Kit w/ Thermostat
- CSF Aluminum Radiator
- Injen Intake
- Pure Inlet Pipe
- FTP Hotside Outlet Pipe
- VRSF 7.5" Race Intercooler
- VRSF Lower Charge Pipe
- Cobb Charge Pipe
- VRSF Catless Downpipe
- Berk Resonated Midpipes
- Berk Race Axle Back
- AVT Intake Scoops
- Go Fast Bits DV+
- BMS Catch Can
- ECS Oil Filter Housing Cap
- ECS Magnetic Oil Drain Plug
- Fuel-It Stage 2 LPFP
- Brass Expansion Tank Bleeder Screw
- EO Speed BPM4 EKP Module/Fuel Controller
- NGK 97506 Gapped to .022
- Eldor Coil Packs
- Fuel-It LPFP to HPFP Line
- Phoenix Racing Port Injection Manifold
- Optima Yellowtop DH6 Battery
Drivetrain/Suspension
- Quaife 3.46 LSD
- Spec Stage 3+ Clutch
- Spec Single Mass Steel Flywheel
- RTD Aluminum V2 Shifter Mini Lever
- RTD DSSR
- BMS Adjustable Clutch Stop
- CDV Delete
- Clark Diff Brace
- Condor Speed Shop Dehlrin Rear Subframe Bushings
- ECS Stainless Braided Brake Lines
- EBC Redstuff Pads
- BC Racing BR Coilovers w/ Swift Springs
- Monroe 907984 Rear Upper Shock Mounts
- Turner Pillowball Lower Rear Shock Mounts
- Rogue Engineering Trans Mounts
- TRW 11-Piece M3 Control Arm Kit
- Hotchkiss Swaybar End Links
Exterior
- OEM LCI Blackline Tail Lights
- 20% Window Tint
- LUX Angel Eyes
- Genuine M Plate Frame
- Kitty Party Grills
- ABS Lip
- 10mm Spacers F/R
- Apex Arc-8 Matte Black 18x8.5+45/18x9.5+58
- Michelin Pilot Sport 4S 225/40/18, 255/35/18
- Rampage Fab Custom Spoiler Mounts
- APR GTC-200 Spoiler w/ V.2 Euro Side Plates
- AcerRacing 75mm Titanium Studs and Lugnuts
- Reiger Carbon Fiber Rear Diffuser
- Debadged 135i emblem
- COLORADON5X Carbon M Mirror Caps
- OEM BMW Roof Racks (Uninstalled)
Interior
- Mashimarho Carbon Fiber Interior Trim
- BMW Performance Shift Boot
- BMW Performance Parking Brake Boot/Handle
- BMW Performance Shift Knob
- BMW Performance Aluminum Pedal Set
- Genuine 1M Mats
- Genuine BMW All Weather Mats
- Vader Solutions Vader Clip w/ Samsung Galaxy Tablet w/ MHD Wireless
- OEM additional cupholder
- OEM Trunk Mat
- OEM Windshield Sun Shade
- LED Interior Kit
- Red Push Start Button
- Broadway Mirror
- Corbeau FX1 Pro Seats (Black Microsuede)
- Corbeau 5-Point Camlock Harnesses
- Corbeau E82 Seat Brackets with Sliders
- NRW Custom Carbon Fiber/Alcantara Steering Wheel
- RTD Aluminum V2 Shifter Mini Lever w/BMW performance knob
Maintenance
- OEM Coilpacks @ 63k
- OEM Spark Plugs @63k
- OEM Coolant Flush @64k
- Walnut Blasted @67k
- OEM Intake Manifold Gaskets @67k
- OEM Belt/Tensioner/Idlers @68k
- Redline D4 ATF Transmission Flush @71k
- OEM Trans Fill/Drain Plugs @71k
- OEM Brake Fluid Flush @72k
- OEM Parking Brake Shoes @72k
- OEM Boost Solenoid @74k
- OEM Spark Plugs @75k
- OEM High Pressure Fuel Pump @75k
- EBC Redstuff Pads @76k
- ATE TYP200 Brake Fluid/Clutch Fluid Flush @76k
- Pentosin CHF 11s Power Steering Fluid Flush @77k
- OEM Oil Pan Gasket and Bolts @78k
- OEM Motor Mounts @78k
- OEM Windshield and Trim @79k
- OEM Battery @79k
- Bosch Coil Packs @79k
- Alignment @80k
- FRM 3 Replacement @80k
- NGK 97506 @81k
- OEM Roundels @82k
- OEM Condensation Sensor @84k
- Blower Motor Wiring Recall @85k
- Duralast F&R Brake Wear Sensors @86k
- OEM Rear Main Seal @86k
- OEM Flywheel Bolts @86k
- OEM Downpipe VBand Clamp @86k
- OEM Pilot Bearing @86k
- OEM Bellhousing Bolts @86k
- OEM Guibo/Bolts @86k
- OEM Radio Knob Replacements @86k
- Redline D4 ATF Transmission Flush @86k
- OEM Turbo Oil/Coolant Lines @86k
- OEM Waterpump/Thermostat/Coolant Flush @86k
- OEM Radiator Hoses @86k
- 3.5 Bar TMAP Sensor @86k
- OEM Boost Solenoid @86k
- OEM Clutch Slave Cylinder @86k
- OEM Fuel Tank Vent Valve @86k
- OEM Fuel Tank Cap @86k
- OEM Fuel Tank Breather Line @86k
- Redline 75W90NS Rear Diff Fluid @86k
- Eldor Coil Packs @86k
- NGK 97506 Plugs @86k
- Michelin Pilot Sport 4S @86k
- Fuel-It LPFP-HPFP Line @87k
- OEM DME @88k
- OEM Valvetronic Motor, Gaskets & Harness @88k
- Injen x-1021 BB Filter @88k
- Injen Hydroshield @88k
- OEM M-Door Sills @88k
- OEM HVAC Buttons @88k (paint was fading on originals)
- OEM Radio Retention Clips @88k (one was missing and caused a rattle)
- Alignment to 1M Specs @89k
- OEM Serpentine Belt @91k
- OEM Engine Cover @91k
- OEM Bosch Starter @91k
- OEM Engine Grounding Cable @91k
- Eldor Coil Packs @92k
- NGK 97506 plugs replaced @92k
- Optima Yellowtop DH6 Battery @92.6k
- OEM Power Steering Reservoir/Filter replaced @94.8k
- CHF11S Power Steering Fluid Flush @94.8k
- Cabin Air Filter @94.8k
- OEM Coolant Expansion Tank/Cap/Fluid Flush @94.8k
- Oil Filter Housing Gasket @94.8k
That basically brings us up to speed with where the car is at today.
Any future updates will be posted below, and I will also update the above lists as appropriate.
Thank you for following along!
Last edited by austinaslink; 08-20-2021 at 04:47 PM.. Reason: Mod List / Pictures Update
      11-14-2019, 04:22 PM   #2
austinaslink
Cool Big changes on the way
After daily driving the car over the last 2 1/2 years with full bolt ons, I've decided to pull the trigger on a BIG list of mods that I've been eyeing for a while.
The car is officially paid off, and my new plan is to make her track worthy, and begin tracking her in 2022 as soon as we leave Hawaii and move back stateside. Once we move, I will be picking up a Porsche Macan S for a daily driver, and the 1er will become my dedicated weekend/track car. I have loved every minute I've had with this car, and plan to keep her for a long time.
Here is the long list of parts I am pulling the trigger on. Most significantly, I am going to being installing a Pure Stage 2 turbo, a Quaife LSD, a Mosselman Oil Cooler Kit, as well as some cosmetic mods.
- Pure Stage 2 Hybrid Turbocharger
- Spec Stage 3+ Clutch and Steel Flywheel
- OEM Blackline Tail Lights
- OEM Driveline Center Support Bearing
- OEM Driveshaft Guibo
- Wedge Custom Tune for 92 Oct & E50
- NEW OEM Turbo Lines –
Oil pipe inlet - 11427585402
Oil pipe outlet - 11427585403
Coolant Supply - 11537583900
Coolant Return - 11537583903
- Complete M3 Control Arms Conversion
- OEM Water Pump Replacement Kit
- OEM Thermostat – Pump Hose
- OEM Expansion Tank Hose
- OEM Upper Radiator Hose
- OEM Lower Radiator Hose
- CSF Radiator
- BMW Performance Pedal Set
- APR Spoiler Stainless Hardware Kit
- APR Spoiler GTC-200 V.2 Euro Side Plates
- Mosselmanturbo Single Oil Cooler Kit
- Hotchkis End Links
- YCW/MFactory Rear Axles
- RTD Aluminum Shifter (Silver finish, black knob, V3)
- Quafe 3.46 LSD
- 1m Rep Bumper
I hope to have everything ordered by the end of the month, waiting for Black Friday Sales to kick off to finish my shopping. I plan to begin the installation of everything around Christmas time!
Stay tuned for new part goodness! Very excited to be taking my 1 to the next level, and finally be able to make good power to redline!
135j22.50
      11-14-2019, 04:46 PM   #3
austinaslink
Random Pictures
I didn't want to make the intro post entirely too long, so I didn't include all of these.. But here are some of the pictures of the 135i I've collected over the past few years!
135j22.50
      11-14-2019, 07:45 PM   #4
Just Apex It
Euro Haus Founder
Just Apex It's Avatar
138
Drives: '04 E46 330Ci ZHP
Welcome! Car seems to be extremely well sorted out and I love the progress! Those Apex's sure do look great on the car and for whatever reason, the 225/255 setup looks really meaty. Perhaps an optical illusion. Keep it up man! 🙌🏼
What made you decide to replace the UUC Poly trans mounts with the RE trans mounts?
Euro Haus - Come for the cars, stay for the people!
TheEuroHaus.com
Current: '04 E46 330Ci ZHP 6MT
Sold: '16 F22 M235i 6MT - '15 F82 M4 DCT - '11 E82 135i 6MT - '07 E90 335i ZSP
      11-14-2019, 08:49 PM   #5
austinaslink
Originally Posted by Just Apex It View Post
Welcome! Car seems to be extremely well sorted out and I love the progress! Those Apex's sure do look great on the car and for whatever reason, the 225/255 setup looks really meaty. Perhaps an optical illusion. Keep it up man! ����
Thank you for the warm welcome! I agree with your opinion on the tires looking meatier than they truly are. I believe it has to do with the RS-RRs running a bit bigger than they advertise. The aggressive tread pattern probably adds to the illusion as well.
As for the transmission bushings, the UUCs are just too loud to be honest. They add more NVH than any other mod on the car. I am worried once I install the single mass Spec flywheel, the transmission noise will be unbearable. So going back to a more humble transmission mount for now.
- Austin
      11-14-2019, 09:17 PM   #6
Petro135
Drives: 2008 135i E88
2008 BMW 135i  [0.00]
Nice ride!!!
Welcome
      11-14-2019, 09:53 PM   #7
austinaslink
Originally Posted by Petro135 View Post
Nice ride!!!
Welcome
Thanks Petro! I love spending my time reading through others build threads, so figured I'd contribute to the cause!
      11-14-2019, 10:56 PM   #8
MN.BIMMER
No Cop No Stop
MN.BIMMER's Avatar
Drives: 2012 BMW 135i
Another beautiful AW 1er
Current Garage!
2012 BMW 135i - 6MT w/ OEM 550i clutch & MFactory LWFW, Pure Stage 1, MFactory LSD, VRSF Catless Downpipe, JB4 w/ MHD BEF
      11-15-2019, 09:25 AM   #9
seagrasser
Drives: E82 M sport
More details on the lip if there are any. Looks great
      11-15-2019, 11:23 AM   #10
austinaslink
Thank you! BMW did something right with this color. Looks great when properly taken care of.
Austinaslink's PS2 N55 135i Build - CLICK HERE
      11-15-2019, 11:29 AM   #11
austinaslink
I bought the lip about two years ago off of Ebay. It was only $90 shipped, but fitment was not great. I had to use a heat gun and really put some elbow grease into it. I had my wife assist in holding it to the bumper while I worked it into place and attached it. I do use some plastic trim restore cream every now and again because it fades slightly in the sun.
Still worth the money I'd say. It does a great job at protecting the bottom of the bumper.
Here's a link to the same lip;
ebay.com/itm/Fits-07-11-BMW-E82-1-Series-H-Style-Front-Bumper-Lip-Spoiler-Polyurethane-PU/282332000781?epid=1841902908&hash=item41bc4c720d:g :jhwAAOSw2KBa6YLW
      11-15-2019, 11:37 AM   #12
Petro135
I like that lip too, I need one. My car had major damage under the bumper when I got it, I'm contemplating fixing it or just buying another bumper. I'd like to fix it when I respray my hood but body work is a nightmare for me. Then I can add a lip like that. Yours looks good.
      11-15-2019, 11:42 AM   #13
austinaslink
That's another reason I bought the lip. My car had some light curb rash on the bottom of the bumper as well. The lip does a good job of hiding most of it, as well as protecting it from further damage. 1M style conversion bumper is in my future, so not worried about repainting the bumper anymore. Although I do have two M-Sport bumpers sitting in my attic. All with similar damage. lol
      12-03-2019, 02:40 PM   #14
austinaslink
Took advantage of numerous Black Friday/Cyber Monday sales, and got 90% of the parts ordered. Last thing to order is the Quaife LSD and MFactory axles. Should have them ordered before the end of the month.
Parts will start to arrive this week. I will be posting pictures of everything, and plan on documenting the install of everything the best I can.
Can't wait for the first pull with the PS2/Spec Clutch setup!
      12-04-2019, 04:09 PM   #15
Petro135
Awesome, i love a good sale. Its great you have nice weather to get all that work done. I think I'm shut down for the winter. It's already really cold in my garage
I'll be following along!!
      12-06-2019, 12:38 PM   #16
austinaslink
Pure Stage 2
Well, the parts have started to arrive!
Nothing but good things to say about my experience working with Pure. The turbo arrived to me in Hawaii 5 days after ordering, and I received email updates throughout the entire process.
On to the turbo. It came packaged extremely well, and everything appears to be in perfect condition. If I didn't know that Pure rebuilt used cores, I would think this was a brand new component.
A few more weeks until the rest of the parts come in, so for now, pictures will have to do.
Appreciate 3
135j22.50
      12-06-2019, 12:43 PM   #17
Petro135
Beautiful, what type of power do you expect out of the pure?
      12-06-2019, 02:20 PM   #18
austinaslink
Hey Petro!
The plan is to have a tune for 92, and another for E50. I'm hoping for around 450whp on 92, and closer to 500whp on E50.
If I don't hit those numbers exactly, I won't be too upset. Not going for insane numbers, just smooth consistent power to redline. Reliability and driveability are the most important factors to me.
      12-07-2019, 08:02 PM   #19
Petro135
Originally Posted by austinaslink View Post
Hey Petro!
That is a good goal. I'm looking near the same from my turbos and tune. Smooth DD tune for 93 oct but I think a little bit aggressive on the e50 tune. I don't have easy access to e85 here, so I will really only get it for special occasions.
I glad you are doing the turbos, put up some pics. I'd like to see an n55 taken apart.
      12-09-2019, 11:58 AM   #20
austinaslink
My E50 tune will have to wait as well. Used to be able to get E85 on base in WA, but there isn't any here on Oahu..
I will do my best to document everything! Still waiting on a bunch more stuff to show up first.. I will probably begin the install process around Christmas.
Austin
      12-10-2019, 12:10 PM   #21
austinaslink
Another update
The first half of my order from FCP Euro arrived last night! It included the rest of the pieces needed to complete the turbo install, as well as all new coolant hoses, water pump and thermostat and some other small maintenance items. It also included an M-Performance pedal set which I've been wanting for a while, and an 11-piece M3/1M control arm upgrade kit!
I had time to get the pedals installed last night, and they look great! I'm hoping they provide a bit better grip than the standard rubber covers I had previously.
Here are some pictures;
      12-10-2019, 04:30 PM   #22
Petro135
Nice and nice!!! Your gonna be busy. All new lines are important. You will read why in my next update.lol
Like christmas time for you..
I was just checking on prices and what all is needed with those control arms. I'm not far behind you on that.
Congrats again. Wait until you feel the pull to redline with new turbos. I got my first taste of it today.
