08-06-2019, 02:02 AM | #1 |
219
Rep 139
Moonroof fuse?
I haven't used the moonroof in a while and tonight I just found out that it isn't working (nothing moves when I move / push the button) -- neither the cover nor the glass. I figure the first thing I need to check is the fuse. I pulled the cover on the right side panel in the trunk. There's a piece of paper listing all fuses and location. From the graphic it looks like moonroof is #28 and 38. Can anyone confirm? And it looks like these are located in the engine bay on the passenger side?
TIA |
08-06-2019, 06:30 AM | #2 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
Most probably under the glovebox - don't think there are any fuses in the engine bay. And that piece of paper is the most reliable source, so if it says 28 and 38 - it's 28 and 38.
Freude am Fahren.
08-06-2019, 10:45 AM | #3 |
Rep 7,580
If you're unsure of which fuse...the icon on the fuse diagram should match the icon that is on the sunroof's switch button. That is how to tell what some of the obscure fuse diagram icons are for...look for the icon on the switches or buttons around the vehicle.
You can also double-check by using the TIS website: www.newtis.info If you enter the last 7 digits of your VIN (or select appropriately for model) you can type F28 or F38 into the search box...and the TIS will give you info about that fuse number. If you have lost electrical power to the vehicle (removed/replaced the battery) since the last time the sunroof worked...then you'll need to simply reinitialize the sunroof. The instructions should be in your owners manual...every BMW that I've owned that had a sunroof has had instructions for how to reinitialize it because they won't function properly or fully once they've lost electrical power. Do check your manual because the f10/f11 instruction below might be SLIGTLY different:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-20-2024 at 07:02 AM.. |
08-06-2019, 02:13 PM | #4 |
219
Rep 139
Thanks TheUltimateDrivingManiac and Qsilver7 !
The car hasn't lost power recently, so it's probably the fuse. But I'll try the reset procedure first. And yes it looks like the fuse box is under the glove box. |
04-20-2024, 02:44 AM | #5 | |
Rep 5
Drives: F15 - 2018 BMW X5 35d - Stock
