BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 328d HPFP Bosch CP4.1 "Disaster prevention plate"
Studio RSR
      02-21-2020, 11:30 AM   #23
Enabled
Drives: 328xd Wagon, M2 Competition
I'll test this if you want, including how it responds to cars with power increases.
Currently I'm trying to figure out why all the effort for the fuel to come from the inside of the pump to feed the metering unit. That seems intentional, and with some sort of purpose.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
haagm58810.50
      02-21-2020, 06:25 PM   #24
Sinner328
Drives: BMW 328i 2016
One stupid question, would a diesel additive decrease the chances of fuel “grenading”?
I’ve had a couple of diesels and always have used additive (Diesel Kleen).
      02-22-2020, 12:11 PM   #25
Enabled
Ok e had a couple of diesels and always have used additive (Diesel Kleen).
Theoretically additives add lubrication, so yes it would help.
If your diesel station provided you with a gallon of condensation water, then no amount of additives will help.
Others:
      02-22-2020, 05:49 PM   #26
va121mir
30
Drives: 2014 328d
Originally Posted by eugene89us View Post
Man, va121mir , this looks really great! High end. That filter looks similar design (albeit smaller) as the OEM filters on TDI VWs. Any data to suggest restricted flow or higher amp draw on low pressure fuel pump?
What part of Texas are you at? We may be going by Austin sometime soon via Dallas or Houston, if you're not far from those places we could stop by to test fit on LCI pump.
I want to say this filter setup is supposed to flow 25 gpm but I cant find the reference. That is more than plenty for this engine. Plus, given the size of the ports on the filter housing, I do not suspect any significant increase in resistance to flow.
Im in wichita falls which is 2 hrs nw of dallas but I may be moving back to AZ soon.
      02-22-2020, 05:58 PM   #27
va121mir
30
Drives: 2014 328d
Let me get some good pics for the install manual write up and then I can ship out the other setup. I only had 2 proof of concept pieces made. 1 for my ride and one for someone to test out.
Honestly, i think that design was for ease of machining. I see no specific reason to have that setup except that additional ports would have to be added to avoid this problem.
      02-22-2020, 06:09 PM   #28
FaRKle!
At what pressure though?
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      03-05-2020, 09:18 PM   #29
va121mir
30
Drives: 2014 328d
Not sure. Havent been able to find the spec. But the setup seems to be running great.
      06-19-2020, 11:17 AM   #30
haagm58
haagm58's Avatar
Drives: F30 328d Sport Line
va121mir, after a few more months of driving, how has this setup been working for you? Are you starting to sell these kits? 2014 328d here, approaching 49k miles.
      06-19-2020, 11:32 AM   #31
eugene89us
Drives: 2018 BMW 328d
I am curious myself. If everything is running great, I would be curious to see how this tests on both Bosch pumps pre-LCI and LCI. I am at 43K, so would definitely like to have something like this if there is no effect on pump operation. An ounce of prevention is definitely worth a pound of cure, even if the likelihood of fuel contamination and pump failure is low.
      06-22-2020, 04:44 AM   #32
Cyruskint
Drives: 2017 F31 LCI 330d; 2002 Z3 3.0
I was not able to find a commercially available "disaster prevention kit" for a CP4.1 so I made one using the same principles that the ford, etc CP4.2 kits use. After lots of protyping and waiting for the parts to arrive, I finally installed the kit in my ride yesterday. Below are the pics of the final product and it installed. So far everything runs perfectly. I am also working on a filtering setup for the return fuel line to take care of the debris if the pump grenades but may have to get another part machined to get the filter I want hooked up. Based on how the testing goes, I may start selling these kits. Let me know if you would be interested picking up a kit. Ballpark prices will be around $200 for the kit and an extra $150 for the filter addition.
Thank you for sharing your considerable efforts on the Forum - much appreciated.
As you may see in my Post, I have this issue with a 330d LCI Touring (May 2017 build) which is now subject of a dispute with the supplying Dealer.
If I get the car back (and your device fits the LCI) I would certainly be interested.
My October 2012 330d had no such issuesprior to trading it in for the new one
      06-22-2020, 12:02 PM   #33
PhadeOut
Drives: 2019 X2 M35i
So what are the real chances of this happening on a 2017 328d? First I've heard of this and crazy it can even happen.
      06-26-2020, 09:37 AM   #34
eugene89us
PhadeOut there is a thread on Mechanical Maintenance Subforum (erroneously created there instead of this subforum) with multiple 2017 328d's reporting these issues. One person had HPFP fail twice within 6 months of first replacement. Their failures likely point to a fuel station which either has fuel with low lubricity and/or contamination that leads to failure. Given that re-design of HPFP roller occurred (I think) mid-2017, not sure if yours is redesigned or not. However, I am certain fuel contamination can lead to any HPFP failing no matter the roller size - bigger roller probably will take longer to fail, but will still fail. Best prevention is avoiding contaminated fuel, which is easier said than done - you won't likely carry fuel testing lab with you all the time. So this plate from va121mir is supposed to reroute fuel so that failure will only result in pump contamination and not the entire fuel system.Thus, you'd look at $1000 pump replacement vs $10,000+ to replace entire fuel system. BMW extended warranty on HPFP for some, I don't think mine was extended given it is "redesigned" version.
      06-28-2020, 07:42 PM   #35
Silverslk
Drives: 2014 328d, 2004 Suburban 2500
Good evening. I just joined here just so I could see if these are available yet. I have a 2014 328d with 89,000 miles on it and this is totally worth the peace of mind.
      07-14-2020, 08:50 AM   #36
Nork
Drives: F10
Hello, I also joined since I am looking for plans to have this adapter CNC machined.
I noticed also on some VAG forums guys are using this type of adapter, but no one shared publicly or on Thingiverse plans for it. Greetings from Slovenia
      07-14-2020, 09:08 PM   #37
CTMike
Drives: 2021 X5 40i MSport/2011 E93 M3
Curious about this as well for my 2015 F31 328d... I want to see it live a long happy life.
      08-02-2020, 07:33 AM   #38
discoboy1
discoboy1's Avatar
123
Drives: E82 1M VO/F30 328D
would also be interested for 2016 X5 35d
      01-15-2021, 12:46 AM   #39
daniel35d
Who reads these?
daniel35d's Avatar
234
Drives: '10 E91 325d
Originally Posted by HighlandPete View Post
Serious question, is this a US issue due to poor diesel quality, contributing to the fault?
Don't think i'm missing it, but haven't seen this issue filling forums over here, and we've a lot more diesel's with the pump over here in Europe.
Sorry for bump, but I just wanted to say that no, this is not an US specific issue.
We see quite a bit of CP4 failures here in Norway as well. BMW N47, N57 and other car manufacturers that use these pumps (VAG, Volvo etc).
Lower mileage cars, higher mileage cars etc.
It has been mentioned that it is VERY important that proper bleeding proceedure via BMW diagnostic is done after diesel filter change, as other methods that seem to be okay on older M47/M57 cars does not work the same way on these.
If not this can be bad for the already fragile CP4 pump.
Instagram: daniel.35d
      02-16-2021, 09:16 PM   #40
Mr.fork
Drives: 2014 BMW 328D
Sending a message to OP.
      02-17-2021, 08:38 PM   #41
Prof. X
Drives: 14 328d
Interested to see how it goes. Highly interested myself. Looking to avoid a ticking time bomb if possible just rolled over 110k on my 14 328d.
      04-20-2021, 02:31 PM   #42
seki1234
Drives: Bmw 5 series
Are there any news, did anyone start making kits for BMW CP4.1 and CP4.2?
I bought CP4.2 disaster prevention kit for Ford Powerstroke engine hoping it will fit CP 4.2 on BMW 6 cyl diesel. Tried to install it today but looks like it wont fit.
      08-03-2021, 07:36 PM   #43
rhombus
Capt Rhombus
rhombus's Avatar
Drives: E46 M3/6, E91 325xi/6
PM'd
E46 M3 6MT : ESS VT2-575 : Euro Headers : PSS10 : ARC8
F15 35i : MHD EWG, FMIC, 4" ER DP; E70 35i : MHD, ER Downpipe; E53 4.4i : 31.5" BFG K02s on BBS Style 19s
      08-12-2021, 01:18 PM   #44
JENKSEVM
Drives: 2014 328d
A buddy of mine was able to reverse engineer this for me based on the photos above. After completely replacing my own fuel system I had one of these installed for peace of mind, wish I would have done before I had a failure. I’ve put about 12k miles on my own 2014 328d since without issue.
Serious inquires can contact snsengineeringllc@gmail.com for CP 4.1 prevention plate.
This thread is what I somewhat followed to repair myself if its already too late. About $1200. VS $11k quoted from BMW. Also the filter and housing is what I used vs the fancy one above.
https://forums.tdiclub.com/index.php...ir-diy.444273/
