M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      06-06-2023, 09:41 PM   #89
E46MysticM3
50
Drives: 2015 F10 BMW M5 6SPD 209k Mile
Bumping this thread, 208k miles on my 2015 6spd on mine now running great. Ill post the service history shortly.
Appreciate 7
SCD-1983575.50
m5rosco210.50
M5Rick60145.00
1320racer136.00
      06-07-2023, 04:15 PM   #90
ricardofors68
ricardofors68's Avatar
326
Drives: '15 F10 M5
Are you the original owner? I'm in the DMV area as well.
'17 C7 Vette GS (bye) / '15 F31 328 ix (sold) / '08 E92 335i (sold)/ '08 E92 M3 (RIP)/'01 M5 (sold, sniff)/'07 M5 (sold)/ '15 M5
      06-07-2023, 08:41 PM   #91
E46MysticM3
50
No, actually just bought the vehicle. I am the 3rd owner. 2nd owner put 140k of the miles and maintained it at the dealer.
      06-14-2023, 09:01 PM   #92
DjangoM5
Drives: Bmw m5 f90
85k miles BPM stage 2, no issues , car is a beast !
      07-17-2023, 10:27 PM   #93
turboslut
27
Drives: '14 M5, '18 GT3, '08 911 Turbo
Bought with 173k miles as second owner. The car ran, but engine clocked another 3k-4K miles before spinning a rod bearing.
Engine was original and dealer maintained since new and even then, by the time I bought it, the engine had two blown turbos, consumed at least a quart a week of oil and AC compressor was shot.
To be honest I was pretty impressed with the amount of miles and the fact that it ran.
I bought it for a price that took into account and engine rebuild and that’s what I did with the guys at RK, but again bone stock engine did make it all the way up to 178k miles before calling it quits.
M5Rick60145.00
      07-19-2023, 04:45 PM   #94
ricardofors68
326
Drives: '15 F10 M5
72k, '15 comp, bone stock
1320racer136.00
      07-20-2023, 01:17 PM   #95
slandis
Drives: 2013 BMW M5
2013, just rolled 77k. Only owned it for a week. Such a blast to drive!
1320racer136.00
      07-22-2023, 04:32 PM   #96
texsn95
56
Drives: 2014 Frozen Silver M5
Originally Posted by texsn95 View Post
16,800. Bought at 11,800 last January.
2.5 years later, still haven't hit 24k.
2014 Frozen Silver M5, CP, B&O, 601s
1995 Mustang Cobra - 347 stroker
      07-27-2023, 10:34 PM   #97
danielgmanm6
danielgmanm6's Avatar
Drives: 2013 BMW ///M6 F13
2013 Bmw M6  [0.00]
  [0.00]
  [0.00]
What year is it?
      07-27-2023, 10:57 PM   #98
turboslut
27
      07-29-2023, 12:22 AM   #99
thxbuff2001
Dictator for Life
thxbuff2001's Avatar
Drives: To many
16k miles.
After 12k miles of daily duty, I got a job 3 miles from my home. I use it in the weekend only.
03 e39M5 Imola Red-Tubi Exhaust/GROMAudio
16 F10 M5JavaGrun/MT/CP/CCB/B&O/ReaRDVD
23G82M4SignalGrun/MT/CCB/CarbonBuckets
09 Ferrari SCUDERIA Rosso Corsa
23CayenneGTSCoupe
      07-29-2023, 03:25 AM   #100
M5Rick
General
M5Rick's Avatar
60145
Drives: M5 F10 DCT Gunmetal
42k miles not being used for local errands anymore, have a gas friendly Civic for that and the M is used for longer journeys.
SlimM572.00
      07-29-2023, 09:50 AM   #101
SlimM5
SlimM5's Avatar
72
Drives: F10 M5 Comp
  [0.00]
2014 comp, 70k. Still runs strong.
A/C compressor went out at 60k and fuel injectors at 65k. Both fixed at dealer.
M5Rick60145.00
      07-31-2023, 02:53 PM   #102
1320racer
1320racer's Avatar
136
Drives: 2013 BMW F10 M5
I’m the second owner and I began driving my 2013 F10 M5 near 47k miles. Last week I just passed 119k miles.
Current:2021 Mazda MX5, 2013 BMW M5 Tuning Tech Stage 1, 2013 Buick Encore, 2013 Chevy Traverse LTZ
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI
SlimM572.00
M5Rick60145.00
      07-31-2023, 03:04 PM   #103
1320racer
1320racer's Avatar
136
Wow! Looking at the gauges in your picture, the oil temp is nice and low. Either your engine had not been running long in the 97F heat, or did you installed a much cooler thermostat. Has anyone installed a lower temperature thermostat and if so, what was the temperature?
      08-01-2023, 08:29 PM   #104
SlimM5
SlimM5's Avatar
72
Drives: F10 M5 Comp
  [0.00]
Thanks, but no adjustments made. Ride was still in the cold start phase and slowly rising, just after startup. Normal temp sits just a tick or two above the 1st hash mark and the mid.
M5Rick60145.00
      03-26-2024, 01:52 AM   #105
m760iM5
Drives: G12 M760i, F10 M5
2013 147.3k miles. I am the second owner and purchased in November of 2017 with 67k miles. The car has never been modified under my ownership. Next should be the suspension and I'd like to have the drivetrain and transmission inspected for possible service, just because not much has been done in that area and the miles are getting up there. Here is my service history since 2018.
77963 oil change, air filters, spark plugs, brake fluid service, wipers, rear axle service, alignment
89170 brake pads and sensors, replace lug bolt
93594 oil change
99972 replace turbo coolant pipe hose and heat shield
109402 oil change, air filters, spark plugs
122569 oil change, brake fluid service, rear axle service, rear brakes pads and rotors, wipers
130726 front brakes pads and rotors, cabin filter, right paddle shifter
142201 oil change, recharge a/c, replace battery
144290 replace oil pan gasket upper and lower, replace motor mounts, oil change, spark plugs and ignition coils, replace a/c condenser, air filters
145111 replace high pressure fuel pump
The only issues that I incurred that are slightly out of the norm are the high pressure fuel pump and turbo coolant pipe, but I think many S63 engines had this. Otherwise, the replacement of the oil pan gaskets and motor mounts were a little out of the norm. I had an oil leak and I wanted to take care of it. Lastly, I wasn't happy spending money on the a/c, but we need that in Southern Cal! As you can see, I only did 15k oil change intervals, I even did that with my e46 M3 back in the day too and I never had any issues. My miles are mainly commute and sparingly WOT, so I haven't put too much strain on this one.
I'll probably never sell it, the only way out is with a total loss. I'm in around 70k to purchase it, buy an extended warranty and maintain it (not including tires). I tried to sell this bad boy last year and I couldn't even get a bite at 23k selling price. Even with a solid maintenance history and perfectly running M5 and new PSSs. I can't justify getting rid of it. Anyways, next year is when I add the F90 to my stable.
M5Rick60145.00
      03-28-2024, 05:49 PM   #106
snoep
Drives: M Coupe, E60 M5, F10 M5
211000 km
M5Rick60145.00
      04-07-2024, 12:57 PM   #107
Deke
Drives: F10 M5 Comp 6MT, G30 540xi
16400. Take it out about once every 3-4 weeks. Mainly a garage queen.
      04-16-2024, 11:36 AM   #108
texsn95
56
23,9xx. Avg about 3k / year.
m5post
