M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      12-28-2021, 01:32 AM   #1
bear55
Drives: F10 M5
VANOS motor problem?
My car is 2012, 92000km, oil change every 5-6000 km
Got the below codes
133711 Intake valves 2 adaptation air mass flow: lower limit position reached
102902 Air mass 2, plausibility: air mass too low
for DME2 a few months back, no CEL, cleared it and they comes back randomly.
It happened when the car stops (at traffic light or idle for a short time). RPM will drop to 500 or below and it will go back to normal after a few seconds, or just stall sometimes. This is what happened when codes came out. After that idle will be a little rough, rpm will be a little higher when stopping, and the exhaust sound deeper.
Replaced both pre-cat O2, replace MAF, clean and swap solenoids, replaced coils and plugs. Codes still come back
Need some input, thanks in advance
      12-28-2021, 06:02 AM   #2
M5Rick
General
M5Rick's Avatar
60145
Drives: M5 F10 DCT Gunmetal
Got the below codes
Could be the cold start flaps engaging.
      02-08-2023, 08:59 PM   #3
WH1TE_M5
WH1TE_M5's Avatar
Drives: 2013 M5
Did you figure this out ?
      09-13-2023, 05:08 AM   #4
isjm91
Drives: BMW M5
I have this exact same problem now. did you manage to find out what was the issue?
      09-13-2023, 06:06 AM   #5
M5Rick
General
M5Rick's Avatar
60145
Remove and check both air filters, often forgotten and if black against the sun then replace them.
      09-13-2023, 08:59 AM   #6
isjm91
Drives: BMW M5
Thanks for the advice. Do you mean the air intake filters?
My fault codes says 133711: valve tronic 2 eccentric shaft adaptation, lower stop reached
      09-13-2023, 11:56 AM   #7
M5Rick
General
M5Rick's Avatar
60145
Yes, if intake filters are dirty/partially blocked then revs would drop in some instances, it's worth clearing this first before going deeper.
      10-01-2023, 03:49 AM   #8
Kyriakos84
Drives: BMW M5 F10
I have the same Codes. The CEL light pops up sometimes After 800km of driving . No issues with boost . Just the anoying CEL. Air filters are also new Original ones. Did anybody figuered out this issue???
      10-01-2023, 03:50 AM   #9
Kyriakos84
Drives: BMW M5 F10
Forgot to mention that the cel pops up not when boosting but when cruising with about 1500rpm
      11-23-2023, 09:59 AM   #10
isjm91
Drives: BMW M5
Changed new filters. Did not solve the problem
      11-23-2023, 12:47 PM   #11
M5Rick
General
M5Rick's Avatar
60145
Ok it's a 2012 and US didn't get M5's until 2013, could it be a Canadian one (who got them in late 2011 onwards) and I'm just thinking bad gas now, where in California are you.
      11-25-2023, 04:40 AM   #12
isjm91
Drives: BMW M5
Hi M5rick, appreciate that you’ve been following up. I’m from Singapore and my car is a 2012 MY. I have been using 98/100 Ron which should be equivalent to Oct 93/95. We get good fuel here so I don’t think it’s the fuel problem
M5Rick60145.00
      11-25-2023, 05:37 AM   #13
M5Rick
General
M5Rick's Avatar
60145
Glad the fuel is ok there, but with what bear55 was saying about revs dropping it has all the hallmarks of possible bad gas.
      02-19-2024, 07:26 AM   #14
Kyriakos84
Drives: BMW M5 F10
Hi guys ! Did somebody manage to find out what the issue is/was ?
      02-20-2024, 09:12 AM   #15
anoller
Drives: F10 M5, F10 535i, Duramax, etc
Holy craptards, I’m hitting this issue also. “Cold start not controllable”, “air mass plausability: air mass too low,” and more. I’ve replaced plugs, coils, MAF sensors, VANOS solenoids (all 4), exhaust side VANOS camshaft sensors. And she still runs like (bleep). Need help, don’t want to pull the covers and replace timing chains and cam sprockets just to continue to have issues.
      04-01-2024, 08:21 AM   #16
isjm91
Drives: BMW M5
Hi sir. Just an update, I rebuilt my engine as the oil consumption got pretty bad. My workshop replaced the timing chains too for vanos, but did not replace the vanos sprockets. I no longer fault codes but I still have a mild version of this where I gently throttle, the rpm goes down before going up, and drops back down to about 500rpm before going back to idle rpm at around 700. This happens in neutral, d1 and reverse. So just letting you know, might be the timing chain. But I did not get this issue fully resolved. Power also feels down for some reason. I’m on stock map, no mods.
      04-01-2024, 05:03 PM   #17
Solo_M_Tech
Solo_M_Tech's Avatar
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
Have the valvetronic system tested. Had an F06 M6 with these faults, TSARA indicated swapping DME’s and reprogramming the car to fix the issue. 100% resolved.
2014 M5 6MT
JayDD007104.50
m5post
