BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Why is My Exhaust Butterfly Valve Permanently Open! BMW E90
      10-07-2010, 09:25 PM   #1
nottibimmer
Notti Bimmer
nottibimmer's Avatar
30
Drives: E90 JB 330i
Angry Why is My Exhaust Butterfly Valve Permanently Open! BMW E90
I checked my exhaust valve several different times, when the car was off, cold idle, warm idle, etc.. it is always open. Anyone know what I can do to find out what the problem could be?
Also, how is the butterfly valve suppose to act? Is it suppose to be closed until 2500 rpm? Closed until 50% throttle? Anyone know?
I know people like doing the golf tee mod, but I just like everything on my car to function like BMW made it to. So closing and opening at the correct times would be just fine with me
Thanks guys, much appreciate any help with this...
      10-07-2010, 09:55 PM   #2
PKumarM3
Air India
India
145
Drives: 2018 Dodge Durango
2 things that may be simple but might have been overlooked
1) is the rubber vacuum line connected?
2) there is a connector in the trunk behind the driver side rear taillamp. if its disconnected, the butterfly valve remains open.
PKumarM3
      10-07-2010, 11:10 PM   #3
jaybird124
jaybird124's Avatar
156
Drives: 2017 M3 ZCP
I'm going to take a shot in the dark that it's supposed to stay open. The butterfly was installed on your car primarily to allow the DSC to function (also as a failsafe, I think).
Remember the valvetronic controls your throttle on that car. I would imagine it stays open to reduce pumping losses (which is one of the original premises of Valvetronic).
That's my guess...
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport
      10-08-2010, 04:29 AM   #4
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
On the 330i it's supposed to stay open on idle. It closes when you drive, but I'm not sure the exact conditions.
The 335i closes it at idle.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      10-08-2010, 05:49 AM   #5
slowSwede
Sweden
21
Drives: 335 coupe
I thought that was for the catalytic converters so they get up to operating temp faster....far from sure though.
      10-08-2010, 10:46 AM   #6
dre_2ooo
dre_2ooo's Avatar
30
Drives: '14 435i
Uhhh.... it has a VACUUM line, so under heavy VACUUM it should shut (ie. in gear during deceleration....) which means you can't see it shutting at idle or when the car is off. I think it's to help prevent afterburn or something.
You'd have to strap a camera to the bumper and then drive it up to 25mph in 1st gear, then let off the gas while leaving it still in gear, then review your footage
      10-08-2010, 10:51 AM   #7
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
On the 330i, if you look while the car is stationary, it will seem like it is always open. When you drive, do you get much more soot on one tailpipe versus another? No doubt, you do. The cleaner one is the one with the butterfly valve. It closes from time to time while moving, presumably to alleviate exhaust noise while cruising.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
      10-08-2010, 10:52 AM   #8
SpmnE9zero
DENY THE WORLD THAT SURROUNDS YOU
SpmnE9zero's Avatar
Drives: JB 33ZERO
2006 330xi  [0.00]
this is very insightful! Thanks I had the same question!
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler |
Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers |
      11-05-2010, 02:32 PM   #9
nottibimmer
Notti Bimmer
30
Drives: E90 JB 330i
Nice! So basically there is nothing wrong and it is acting as it should. I went all OCD for nothing
p.s. i think the 325i and 335i butterfly flaps act differently than 330i
E90 330i Jet Black Sport/Prem
      11-05-2010, 02:46 PM   #10
E90aL
Drives: n52
i've always had the same question but during deceleration i would hear a rattle from the flap. I unplugged the connector and now i dont have to worry about rattles.
      11-05-2010, 03:40 PM   #11
reprod
Drives: '16 M3 ZCP
My butterfly valve is always open at idle but then closes if I accelerate moderately to alleviate exhaust noise at the mid-level RPMs. If I accelerate quickly it stays open the full way. My exhaust note is quite noticeable at idle. I am still waiting to get performance exhaust on the next one.
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned)
'16 Mineral Grey F80 M3 ZCP
      07-07-2014, 02:00 PM   #12
loudenvier
loudenvier's Avatar
Brazil
9
Drives: 2006/2007 BMW 130i M
(my car is a 2006/2007 BMW 130i with barely 52.000km/32.000miles on the "clock")
I really believe I have this noise... So I went on to check the butterfly valve... It was open at idle, so I thought something was wrong with it, but ruled out the noise coming from it since it is "always open" (I thought it was stuck!)
Then I found this thread and now I believe the rattle comes from the valve since I can hear it at low RPMs, with only the windows open. If I keep playing with the gas pedal the rattle becomes crazy, if I keep a strong, or even constant acceleration it is gone/barely noticeable. Anyway, after 2500rpm there's no rattle anymore...
Can anyone put a picture of the connector I have to unplug for it to stay always open? Or will I have to resort to some GO-PRO footage from my exhaust?
(I even took a video of it, but I guess it is a useless video:
      07-07-2014, 04:07 PM   #13
v1nc86
25
Drives: 335xi
Thread revival!
YouTube | 335xi Best 1/4 mile: 12.3@110 MPH | 335xi Top speed: 0-270 kph (165+ mph)
      07-07-2014, 04:15 PM   #14
loudenvier
loudenvier's Avatar
Brazil
9
Originally Posted by v1nc86 View Post
Thread revival!
Sorry for that! I didn't even checked that date of the last post... It was relevant to me now though If I get to make the "GO-PRO" video I'll behave like a necromancer once again and revive this thread!
butterfly, e90, exhaust, open, valve
