BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > ABS , DSC problem!
      01-17-2012, 06:18 AM   #1
Clayshooter
Drives: BMW 328i 07'
Angry ABS , DSC problem!
After 15 m/h come on lights dsc, abs, brake. When I brake below 15 m/h lights off. When accelerate more 15 m/h come lights again on. I was on diagnostic in ECU no errors, and canon body can find prodlem. Dsc ECU I changed but it didn't help.
Please help me?!!!
      01-17-2012, 06:21 AM   #2
JonDiesel@ColemanAutobody
14
Drives: 2011 BMW 335d
wheel speed sensor ?
      01-17-2012, 07:15 AM   #3
Clayshooter
When computer check all it's ok. But when i begin to drive lichts come, when stop and check with diagnistik computer no error codes in ecu. Before 8 months ago i changed dsc ecu, because was error in this case. Now mechanic tries change to new dsc block and it does"t help, they check all wheel sensors, all are ok.
      01-17-2012, 08:54 AM   #4
3Coupe4Me
3Coupe4Me's Avatar
81
Drives: 2007 328i Coupe
When you say DSC block do you mean DSC control unit? Are they reprogramming the new one when they put it in?
      01-17-2012, 12:51 PM   #5
Clayshooter
Yes, sure. Today mechanic looks for wiring problem. The biggest problem error don't save in ECU.
      01-17-2012, 05:07 PM   #6
e90n52b30
Drives: '06 AW E90 330xi
He must not have a proper diagnostic tool then. What is he/you using to scan your car?
To my knowledge, problems with the DSC or any other major system in the car will store shadow faults. You need a proper tool to pull those. INPA, GT1, DIS, Autologic, etc.
It could be related to the wheel speed sensor, ABS sensor, steering angle sensor, etc.
You really need to pull those shadow faults to find out.
No normal autozone or pepboys scan tool will pull those shadow faults.
      01-18-2012, 03:58 AM   #7
Clayshooter
Today i got my car from shop. Problem was in minus wire, mechanic fix it and now it's ok.
      01-18-2012, 07:03 AM   #8
e90n52b30
You know there was a TSB out for the positive battery connection at the fuse panel. If you still have problems, look there.
abs., dsc
