Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Photo/Video/Media Gallery > DIY Track Aero: Side Splitters and Varis Rear Diffuser... well maybe
      08-02-2013, 12:10 PM   #45
Myrder
Myrder's Avatar
Drives: 2010 E92 335i MSport 6MT LMB
looks sick
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56|
-I will look on your treasures, gypsy. Is this understood?-
      08-02-2013, 06:13 PM   #46
dragazn
Drives: i
2008 BMW 335i  [5.76]
Originally Posted by SneakyDeeky View Post
UPDATE 7/31
Finished, wrapped and mounted the first part of the rear diffuser. Side splitters are complete and ready to be wrapped and mounted; I just ran out of time this weekend. Too much work
I love it
      08-02-2013, 06:22 PM   #47
chrisE92
chrisE92's Avatar
Drives: Monaco Blue E92
I love the shape of the rear fins. You or Tee need to make me a set.. I'll gladly pay
In my opinion, you should paint the mounting hardware black. Also, the fins are a little too inward for me... but it still looks great!
      08-02-2013, 09:39 PM   #48
SneakyDeeky
driver mod in progress
SneakyDeeky's Avatar
Drives: with both feet
2015 VW Golf R  [5.50]
2014 Audi SQ5  [10.00]
Thanks, bro. I'll make you a set, but it may take me a while since I end up spending more weekends working than I'd like. Not looking to make any money so I'll just have you cover the cost of materials; probably like $20 with all the hardware and vinyl wrap.
I thought about painting the mounting hardware black, but opted against it since when I'm all done it will be covered up by the rest of the diffuser and to do it right I'd of had to sand the finish off of the brackets to help the paint stick and the finish helps prevent corrosion.
As for the inward / angle, you're right in that it's farther in than the Varis diffuser, but when I lined it up like the Varis kit I didn't like it as much since the edge of the fin didn't line up with the angle on the bumper. To each his own. When you mount yours straighter post up a pic. Tomorrow I'm planning to mount my side splitters so I may not get to yours until next weekend or so. I'll let you know when I finish.
      08-02-2013, 10:02 PM   #49
notnow
Bit by Modbug
258
Drives: F86
Wow, these fins are awesome! Great job.
I want to order a set of those rear fins as well!
PM me details when you have the time!
      08-02-2013, 10:31 PM   #50
hawaiianeze
Major Pain
hawaiianeze's Avatar
Drives: LCI E92 335i
really been trying to think of something that would separate my new e92 from the rest and seeing what you and some others have been doing lately and I'm really stating to feel the diffuser idea, wanting to do a mix of varis and mikes
but with a different exhaust setup
looking to do one that goes all the way around the rear bumper but with fins only as big as yours, and placed where your is. As for the side skirts very tempted to try yours or just get the LT ones
      08-03-2013, 12:47 AM   #51
mapleridge
Drives: E90 N52 AT
beautiful work so far.
      08-04-2013, 10:33 PM   #52
SneakyDeeky
Side Splitters Installed
So this weekend I finally finished off the side splitters and overall I'd give myself a 7/10 with the finished product.
1) I used this DIY guide to remove the rocker panels (aka - side skirts).
2) I managed to break 6 of the white, plastic M3 clips (note the 335i uses the rectangular yellow clips). I wasn't too worried since I figured I could just pick up a couple of new ones from the dealership, but they didn't have any in stock so it looks like I'll get to drive around with no rocker panel on the passenger side until Wednesday. For comparison, the left clip is broken and the right is good-to-go.
You can see only 4 of the 10 plastic clips are left on the passenger side rocker panel below, because I had to use some of the good ones from the passenger side to complete the driver side before re-installing.
3) The heat gun was key to help bend the black plastic door trim around the tighter radii of the front and rear end of the splitters. The trim gives it a little more weight and a nice finishing touch.
Ordered the trim from here. 15' is enough to do two splitters.
All said, I'm happy with how it turned out.
If I were to do it all over again, I'd go back to CalSak Plastics with my father-in-laws truck and use the thicker, 1/4" ABS. Because it's twice as thick, the sheets couldn't be rolled like carpet and didn't fit inside my car. Oh well. I have lots of extra. Next up is finishing the rear diffuser and then onto the front splitter. Oh, and make ChrisE92 a pair of rear fins.
      08-04-2013, 10:45 PM   #53
rbtamms
rbtamms's Avatar
Philippines
63
Drives: 2011 E90 and 2013 F25
2011 328i  [0.00]
You're the best...
      08-04-2013, 10:57 PM   #54
jlo834
bleeds purple and gold
jlo834's Avatar
Drives: 325i
Awesome job OP! I was researching for a DIY side splitter and came across a DIY on a Lotus forum (possibly the same one as your friend?). I believe the member used a material called alumalite or something. I found a local sign shop who could get the material and do the cuts for me but I lost myself when it came down to where I could mount the splitter on the oem side skirts to keep them stable.
Big props for getting the job done! From the looks of it you got the job done right too!
      08-04-2013, 11:05 PM   #55
SneakyDeeky
Originally Posted by rbtamms View Post
You're the best...
Thanks... I think??? Sarcasm???
The alumalite would work nicely. I put a link to my friend's thread on the Lotus forum back on the first page (somewhere ).
As for cutting, if you can hand somebody a template and have them professionally cut it for you, I'd highly recommend it. The majority of my time was spent carefully cutting & grinding the splitters into the shape I wanted... tedious.
The mounting wasn't as simple as I expected either since the splitters would angle up or down depending on the location of the fastener hole; too far outboard and the splitter angled up - too far inboard and it angled down. You can see in my photos that I ended up just going with a fastener located every 6" or so right down the spine of the rocker panel. The final product is really sturdy; it'd be even better if the splitters were thicker.
Thanks for the kind words.
      08-04-2013, 11:10 PM   #56
J-Spec Dan
ALL RIGHTY THEN
J-Spec Dan's Avatar
Drives: 12 STX Advance
Sneaky, that is some ballin' DIY. would your rear diffuser parts mount up well with stock or M-Sport rear bumpers?
BMW CCA Member 483866
      08-04-2013, 11:25 PM   #57
SneakyDeeky
Thanks
My diffuser rear fins would go with just about anything.
I know for a fact that you can't buy the Varis rear diffuser system and expect it to work on a non-M since the M3's are wider than the non-Ms. Even though mine's kind of unique with the M3 rep rear, which is actually a replica of the E92 M3, it still is too narrow for the Varis system so I knew I had to make my own if I wanted a diffuser. Also, because my rear is an M3 rep it has the exhaust located more towards the center than OEM or any of the other bumpers (i.e. - MTECH, Performance, rep, etc.). Hope this helps.
      08-05-2013, 12:07 AM   #58
notnow
Bit by Modbug
258
Drives: F86
My goodness, I am down to buy your products, those side skirts are exactly what I am about to buy for like 7 bills!
      08-05-2013, 03:03 AM   #59
Tallgeese00MS2
9
Drives: 335i
really nice job !!
does anyone know what black concave wheels are on the white m3 on page 1 ???
      08-05-2013, 04:37 AM   #60
tigermack
OPN DIFF
tigermack's Avatar
Hong Kong
475
Drives: 10' E90 M3 6MT LB
2010 M3  [0.00]
1995 BMW e36 325i  [7.91]
2006 BMW e90 330i  [8.34]
Hm, side skirt piece looks good from pics, wonder how they look in person.
'10 LB E90 slicktop/speed cloth/6MT
ex. '06 330i 6MT & '10 n54 6MT Msport
Autocross vids https://www.youtube.com/user/tigermack
https://www.instagram.com/tigermack
      08-05-2013, 05:36 PM   #61
Misturrtinnie
Addicted.
Misturrtinnie's Avatar
43
Drives: 2007 335i Coupe AW
Wow if only you lived near me.. haha i would be coming to you for custom stuff.
#TeamNemesisTX
      08-05-2013, 06:09 PM   #62
DC_Oldboy
Q(*.*)-D Q-(^.~Q)
DC_Oldboy's Avatar
Drives: like an old person.
2006 BMW 330i  [8.48]
Originally Posted by Taran.J View Post
I may be able to hook you up with a set D ; still working on the rear of my e90.
Damn you need to hook it up! Lol
      08-05-2013, 06:21 PM   #63
Taran.J
Taran.J's Avatar
Drives: BMW, LEX, MBZ, RAM, TESLA
I got my rear in today so in a little bit I'll text you when I get the time :0
      08-05-2013, 06:36 PM   #64
chrisE92
chrisE92's Avatar
turned out great! I'm usually a DIY guy myself, and I admire the work that went into this. Thanks in advance for the fins, but I don't want you to go out of your way to make them. If you have time, awesome Just let me know and I'll paypal you the cost for materials and whatnot.
      08-05-2013, 09:26 PM   #65
SOL403
SOL403's Avatar
18
Drives: E90 330xi
This is fantastic!
Mtec AE - Blacklines - ACS style front lip/roof spoiler/pedals - CF grill/trunklip/licenseplate frame/badges/diffuser - 19" VMR V701 - Michelin PS2 - Res delete - Remus Powersound Quadexhaust - Simota V2 intake - Cyba airscoops - KW V1 coilovers - BMS PBX - Stoptech brake pads/rotors - Mtech rear - Matte Silver Vinyl Wrapped
      08-05-2013, 10:46 PM   #66
SneakyDeeky
Seriously? I'll hook you up and make you a set for half that price. $200 and you install them My back's still stiff from crawling around on my garage floor.
Originally Posted by mikex228 View Post
really nice job !!
Klassen M52
- Front: 19X9.5 ET27
- Rear: 19x11 ET31
More pics and info here...
http://www.m3post.com/forums/showthread.php?t=788251
They were for sale too...
http://www.m3post.com/forums/showthread.php?t=851433
If you're serious, you can come check 'em out in person if you want. PM me to setup a time. If not, have fun hating.
Road trip!
No worries, bro. I had fun making them and will definitely be able to knock them out in the next month or so. I've got a vacation to Alaska next week so I'll be gone for 2 weeks, but I've got so much extra material it's silly for me not to make you guys some.
Originally Posted by SOL403 View Post
This is fantastic!
diy, e90, side splitter, track aero, vrs rear diffuser
