03-22-2009, 05:03 PM | #111 | |
Rep 1,347
Drives: 2011 335d
Well I get the feeling I'm mostly alone here but I do a lot of autocross so that might explain a lot of it. I'm assuming that the new 1series M will focus extensively on weight savings. If they can take a significant amount of weight out of the car by going to a 4 cylinder while increasing efficiency I'm all for it. I personally have the feeling that lighter weight = better sports car. In my mind cars are plenty fast these days in a straight line. I'd much rather see them address handling by reducing weight. Like I said though, I think most people are just power hungry... and there is nothing wrong with that but if you are lucky enough to drive an old e30 or e36 M3 I don't find it exactly lacking in power. I also think you are absolutely right about it possibly over stepping the M3 if they kept a 6 cylinder in there. Lets remember that BMW is clearly a business... and they'll do whats in their best interest to build shareholder value which often means compromising their products to achieve the best monetary results. Either way I'm stoked for a 1 series M variant with proper cooling, less weight, wider track, slightly more efficiency and a sweet 4 banger! |
03-22-2009, 05:28 PM | #112 | |
103
Rep 2,626
I agree 100% in terms of weight.
If they built a 3000-3100lb 1 series I'd buy it regardless of HP or straightline acceleration. Something basically an E36 M3 clone in fun-to-drive, with braking/grip on par or superior to an E90 M3, and straightline power similar to a 135i+SSTT/JB+ would be an excellent car, IMHO. I generally like my streetcars to trap in the 111-118 range for DDing, I think that's comfortable. I don't think the car will be quite that fast stock, but if it could get there with very minor tweaks, I'd be completely satisfied. Quote:
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me. -ChuckV |
03-22-2009, 06:26 PM | #113 |
14
Rep 148
[QUOTE=aus;4751993]I don't think BMW has made a 6 cylinder motorcycle yet!! ie: Beemer = BMW motorcycle.
Yeah I know I own a BMW bike also. I was expressing that I love all things BMW. |
03-23-2009, 12:10 AM | #115 | |
Rep 415
BR |
03-23-2009, 01:13 PM | #116 | |
Rep 1,337
If everything seems under control, then you aren't going fast enough"
03-23-2009, 01:20 PM | #117 |
Rep 1,337
thank you!!!!!!!
03-26-2009, 04:22 PM | #118 |
Rep 1,379
Drives: E89 Z4 sDrive28i M Performance
03-26-2009, 05:27 PM | #119 |
Commander-In-Chief
2146
Rep 8,936
Drives: 2023 M2 Coupe, 2020 GLE 450
You are right; my post #111 later acknowledged that the 350 hp number was low, unless they take 400 lbs out of the car, which isn't going to happen.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
03-27-2009, 04:51 AM | #120 | |
Rep 8,019
That gives it a major weight advantage over all the others and should be the one to give the best solution in the commerical sector of car manufacture. |
03-27-2009, 05:38 AM | #121 |
PCA, BMWCCA
102
Rep 2,058
Not only that, but it would make so little torque in the upper rpm region there would be absolutely no point to having a high redline. Plus, it would just grenade. Since BMW opted to go to the E46 block for the current N54 TT, wonder which old block they'll use for the next turbo?
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU |
03-27-2009, 05:44 AM | #122 | |
PCA, BMWCCA
102
Rep 2,058
It can be tuned to peak at that on a very ambitious dyno, which means very little to torque values across the entire rev range and especially at higher rpms where you would want it. Tuning = waste of money and high potential for reliability and/or warranty problems! BMW may as well build a plant in Japan as that's the audience they are appealing to these days. Number seekers and those that can't translate them to real output. In other words, ricers.
03-27-2009, 06:28 AM | #123 |
Rep 8,019
I am expecting a setup similar to the one Jaguar are using on their new XF 3.0d S, a larger turbo complimenting the bottom end of the rev range with a smaller unit coming in a bit higher up the rev range to increase to power and maintain the torque levels. This would give excellence overtaking and everyday driving ability but would probably still not give anything like the throttle response or high end zing that is common in previous M engines.
I can't see it having more than 6 cylinders and more than 3.0L capacity, if it even has that much. |
03-27-2009, 06:46 AM | #124 |
PCA, BMWCCA
102
Rep 2,058
No matter how the air/fuel is introduced to the motor, power is at the expense of fuel economy. With massive fossil fuel price fluctuations across the globe, I really can't see the horsepower war continuing the way it has been. At some point cars getting city epa economy in the teens per US gallon have got to go. I bought a MINI JCW as my new daily driver just for the cross between fun factor and fuel economy. It still gets high 20s mixed and 34 highway! I love my Z4M and vow to never sell it, but one gas guzzler is enough. Even the current 135i/335i are gas guzzlers compared to where I hope BMW is headed with the smaller displacement, lower powered turbos. Afterall, BMW is selling to the mass market, not the enthusiast anymore.
03-27-2009, 03:15 PM | #125 |
Rep 713
Drives: e46 330ci, e92 335i, 2008 128i
04-06-2009, 11:29 AM | #126 |
Moderator / European Editor
1545
Rep 6,754
With the introduction of the V8 TT engine (code S63) in the X5 M and X6 M there are rumors coming up again that the next M3 engine might indeed be a V6 TT.
This engine is said to be based on the S63, being basically a S63 minus two cylinders. Any thoughts or comments? Best regards, south
04-06-2009, 12:00 PM | #127 | |
Commander-In-Chief
2146
Rep 8,936
Next M3 engine
I would definitely miss the instant response and high-revving nature of the current NA engines, but I'm sure I'd learn to adapt, especially if there were significant economy gains over the S65.
04-06-2009, 03:23 PM | #128 | |
Moderator
7516
Rep 19,368
Why not just destroke and/or debore the S63 to 3.3L (or whatever) and use that in the M3 instead. Sure it is a bigger package, but who cares? The next 3 series chassis is very unlikely to get smaller (though it will likely be lighter) so a V8 will still fit I'm sure. If they want lower weight then they should look at employing the magnesium block for the turbo motors, including the V8s. I am sure it is technically feasible, it just needs more R&D. Don't waste that money on a new V6. Alternatively, they'll have a successor to the N54 ready for the next 3 series so that too could form the basis on an M motor. It does not seem worth the development effort to go with the V6. |
04-07-2009, 06:04 AM | #130 |
Rep 8,077
Drives: 11 E90 M3 Individual
The only thing I hate about the M3 is the fuel efficiency. The M3 is dead last in the class.
I welcome a I6T...something different and I don't mind evolution. There is nothing that says an M3 can't be turbocharged.
2018 F30 320iX Melbourne Red
04-11-2009, 03:49 AM | #132 | |
Rep 8,019
Another thing, a Vee engine is much shorter than an in-line so this will also allow for better packaging inside the engine bay, allowing it to move futher back thus improving it's natural weight balance of the chassis and allow for less use of exotic materials to achieve the idea weight balance. |
