BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Muffler Delete Rusty?
ARMA SPEED
      04-06-2022, 04:17 AM   #1
patriotaki
27
Drives: E90 320i 2009, F32 420i 2018
Hey all,
so i've went to a local exhaust shop and i got a muffler delete and he replaced it with some black pipes.
The car sounds awesome, but the pipes have become very rusty after 2 years.
Usually a big portion of the rust goes away after a 1-2hour drive, but it comes back.
Is this something to worry about or is it normally? is it possible that the rust can transfer in the rest of the car?
Should i replace the pipes with stainless steel? Let me know your thoughts
car: f32 420i 2018
Note: i rarely use the car, done only 500km in 1 year
      04-06-2022, 07:42 AM   #2
MaverickCruise
MaverickCruise's Avatar
50
Drives: F30 328
rust will not transfer to other place of the car
Just leave it alone,even rust can be used for several years. Another exhaust system can be replaced later
Billfitz8250.50
      04-06-2022, 07:59 AM   #3
patriotaki
27
thanks for the suggestion, my only "problem" is that due to the muffler delete the backend of the car looks a bit higher and those behind me will be able to see the rust on the pipes.
Here is how it looks now
Removing the rust is not recommended from what i've read here, correct?
      04-06-2022, 09:13 AM   #4
MaverickCruise
50
Drives: F30 328
Looks like it is. Rust is difficult to remove unless the material is changed, so just leave it alone, if pursue aesthetics, you need to replace the exhaust system. For saving money, and tell others don't lie down on the ground to watch it.
      04-06-2022, 10:15 AM   #5
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Not a huge deal but if concerned about the look, get under there with a can of high temp black paint and a piece of cardboard to block overspray. If you want to get extra clearance, back up on a set of ramps.
      04-12-2022, 02:35 PM   #6
Info@mad-us.com
Info@mad-us.com's Avatar
1924
Drives: bmw
Originally Posted by patriotaki View Post
Hey all,
car: f32 420i 2018
Just have it redone in stainless and not steel.
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices!
Email: info@mad-us.com
      04-12-2022, 02:38 PM   #7
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
You can try exhaust system paint. It will probably have to be periodically re-touched.
      04-12-2022, 04:40 PM   #8
Info@mad-us.com
1924
Drives: bmw
When new I think that would of worked but the rust will just flake it off unless he cleans the entire thing.
- Click Here
      04-17-2022, 11:47 AM   #9
patriotaki
27
That's what i was thinking, does the sound change with stainless?
      04-17-2022, 11:53 AM   #10
Billfitz
Billfitz's Avatar
Only if you're hitting it with a stick.
      04-17-2022, 06:19 PM   #11
Info@mad-us.com
1924
Drives: bmw
. I don't think it would be different enough to hear.
- Click Here
      04-17-2022, 09:20 PM   #12
Billfitz
Billfitz's Avatar
It probably would, since the resonant frequency of a pipe varies with length, material density and thickness. I doubt that SS would be identical to plain steel in those respects. But as for the exhaust sound, fahgeddaboutit.
exhaust, muffler delete, pipes, rust
