The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > How to remove N55 Cylinder head (n54 owners can chime in)
      02-19-2017, 09:47 PM   #23
Broken135i
33
Drives: 2011 135i Black 6 Speed
Additional photo
      02-20-2017, 09:47 AM   #24
weehe126
Drives: 2017 340i
Nice job, but getting it back on without damaging the gasket is the difficult part.
      11-04-2017, 08:08 AM   #25
Broken135i
33
Well its been back together for a while now, probably put 8000kms on it since the head went back on. No problems!
      04-09-2019, 05:19 PM   #26
burninmedia
Drives: F25 X3 3.5i, E46 330i
did you have to remove the cams to get access to the head bolts? What was the torque pattern? Outside in?
      04-09-2019, 06:35 PM   #27
Broken135i
33
Cams did not come out, send me a PM and i'll take a picture of my bentley in regards to torque pattern
      04-09-2019, 09:07 PM   #28
bbnks2
1207
Drives: 135i N55
Www.Newtis.info
That site has every torque spec you'll ever need.
musa423.00
      10-21-2019, 11:42 PM   #29
BustOutAnotherThousand
Drives: BMW 135i
I'm about to tackle this job on my N55/DCT 135i. Previous owner stripped the spark plug thread on cylinder 2 and resulted in a broken spark plug, now the head must come off. SMH
Any advice you would recommend?
      12-09-2019, 07:28 PM   #30
Alturiak
Alturiak's Avatar
19
Drives: 2011 E92 335i
Sorry to revive this old thread, but about how many hours is pulling the head while in the car? I'm going to have to pull my head off, E92 N55, and see why my motor is measuring 0psi compression on all cylinders
2011 E92 M-Sport BSM, Built N55 with 9.5:1 compression and forged internals, VAC Stage 3 Ported Head, custom tuned by Twisted Tuning, PR Coils, Pure Stage 2, Fuel It! Phoenix Race PI Manifold, StopTech BBK 380mm front 345mm rear, BBS CH-R Titanium, Dinan exhaust w/black tips, BMS Intake, DCT shifter retrofit, VRSF 3.5" downpipe, VRSF 7" HD IC, CSL CF trunk, 335is Rear Diffusor, Alpina B3 Trans Flash
      12-10-2019, 09:16 AM   #31
weehe126
Drives: 2017 340i
I responded to your other thread, you probably need a new motor if the pistons are damaged from hitting the valves.
      12-10-2019, 09:17 AM   #32
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
2657
Drives: 11' 335is DCT
Originally Posted by ihernandez7910 View Post
no. I also can't write.
Yeah I can see that, you're missing your capital "N".
      04-28-2020, 08:10 PM   #33
Mikaeldarer
Mikaeldarer's Avatar
Drives: 2011 e90 335i N55
Do you have to pull injectors to remove the head?
Also, any chance you have a parts list compiled of all the necessary gaskets, orings, seals, etc?
2011 E90 N55 / Injen intake / PS2 / Pure inlet / VRSF 7" HD FMIC / VRSF DP / FTP CP's / N20 TMAP / BMS OCC / M3 Front Control Arms / Bilstein B12 Pro-Kit Sport Suspension
      06-26-2020, 08:12 AM   #34
Chrisn812
Drives: E90N52, E92N54, E70N55
Deeply interested in this as I think I need to pull the head off the N55 in my Daughters X3 to replace a connecting rod that's hogged out from a spun rod bearing. Please post more details as to the process. I've done this type of work on older cars, just not a BMW with all it's specialties.
      03-22-2024, 09:06 PM   #35
fixingstill
Drives: 2010 335i
Broken135i. good job. You are the only one I found online who pulled head while leaving the block in. I am doing the same but on a 535i F10 chassis. Everything seems obvious except the brass nuts on the exhaust manifold. Top row is accessible from top but how did you remove the bottom row (especially the front ones) ? Did you remove the cat (hence engine mount and its bracket) to get access? Coolant hard pipe too? They are M10 hex or T50 torx. I have all the extensions and swivels but I don't see access unless I remove everything underneath. Please help.
