ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Engine, Exhaust, Drivetrain Modifications
  TireRack
      01-23-2018, 11:49 AM   #67
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
Originally Posted by Beedub View Post
let us know how you get on with it, i know the hubs are stupid money but the stock ones are clearly a weakness, im not sure the re-drilled disk really is a solution as they still seem to break!! Their is simply not enough material on those tabs !
Interesting. I've not heard of tab failure with a Biesan drilled pump.
      01-24-2018, 09:52 AM   #68
mattfwalters
mattfwalters's Avatar
226
Drives: 06 Z4MC (Sepang/Sepang/insane)
The theory with Beisan's oil pump discs is that lowering the clearance provides less opportunity for the cam to move independently of the VANOS oil pump, so there is less force imparted on the drive teeth as a result of independent acceleration. It doesn't make the teeth stronger, but it does reduce the forces they deal with.
Stronger teeth would probably be good too, but based on what I've read, it seems like the general failure rate with both the Beisan pump disc and with cryo-treated tabs are about the same. YMMV, of course.
      01-31-2018, 10:51 PM   #69
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Originally Posted by mattfwalters View Post
I did - VANOS oil pump hub is now a Beisan unit.
That's what I did, too. My car had not been driven hard, was relatively low mileage, and my tabs and holes in the original disk showed no signs of peening or hammering. It's interesting hearing talk about Beisan oil disks failing, because I thought Raj indicated (at least a few years back) that he was surprised there were no failures, because he assumed some people would use his disk with the smaller holes with hub tabs that had already been hammered and weakened substantially prior to the use of his disk, and that those may indeed fail. He felt confident his disk would prevent future damage, but was willing to concede some hub tabs may already be damaged. However, he reported that even given this assumption, he had seen no failures. Maybe a few reports eventually came in. If anyone has a link to those reports, I'd be interested in seeing them.
I feel good about my choice. Without play in the hole, I don't worry about failure.
Salty
2006 BMW Z4M Interlagos Blue/Black
Aux Port|LED Interior|LED Strip Trunk|Underseat First Aid Box|Stubby Antenna|Intravee II|BMW Oil Change Kit|Top Down Side Panels|Vibra Technics Engine Mounts|Rogue Trans Mounts|Engine Mount Bolts Upgrade|RS Windblocker|Euro Front Plate|M5 Illum Shift Knob|Supersprint Powerloop Exhaust|Gruppe-M Intake|RPI Scoop|Black Grills|19x8.5 ET35 F 19x9.5 ET22 R Sportline 8s PSS| Besian Vanos|CDV Delete
      02-02-2018, 12:30 PM   #70
mattfwalters
226
Salty
This.
My hub also appeared undamaged, so I choose to be unworried about it.
      02-17-2018, 08:51 AM   #71
BradZ4MC
B
Drives: Z4 M coupe
2005 BMW 330ci  [0.00]
2007 Z4 M Coupe  [7.00]
Nice build. Going to be doing a similar build after I get my new house built this year with a suspended garage, a lift and lots of room for the project. I own a machine shop and do a lot of HP BMW heads from all over the country so I have been dying to get the head off my Interlagos blue Coupe as I have done almost everything else to the car for track duty. Keep up the post and I will hopefully learn from it and use that knowledge.
I did a pretty awesome S62 Head build for an E46 track monster that is being built right now, complete overkill like yours.
Pictures on Facebook page Nolands Cylinder Head Service.
      03-05-2018, 03:26 PM   #72
mattfwalters
226
Thanks! Looking forward to seeing your build. The pictures on your Facebook page are pretty amazing.
So I've finally come up for air at work and took a bit of time today to inch things along, and started knocking the "surface rust" off of the front crossmember. It's in... much worse shape than I'd thought.
So now I'm calling around to see who can hot-tank it and coat / paint it, which frankly is what I should have done from the beginning. But I'm dumb / stubborn.
wdb4732.00
      03-05-2018, 08:05 PM   #73
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Greetings from the Seattle area;
Looking fwd to seeing this Beast....perhaps at the exotics@.com this year, or perhaps Pacific Raceways
Racerbruce
      03-05-2018, 11:38 PM   #74
mattfwalters
226
Looking forward to that myself.
Dropped the crossmember off at Hill Machine today to have it hot tanked. Considering taking it across the street to have it galvanized when I get it back - dealing with the insides of it seems like a pain in the ass, and I think galvanized steel looks pretty cool.
      03-06-2018, 06:22 AM   #75
Michael9218
595
You might want to reinforce those motor mount tabs before you galvanize the subframe.
      03-06-2018, 11:50 AM   #76
mattfwalters
226
Good thought, thanks. Welding in some reinforcement for the engine mounts is a good call - maybe I'll even make the engine mount nuts captive. I'm mostly joking about having it galvanized - I'll probably wax the inside of it though.
      03-06-2018, 11:57 PM   #77
mattfwalters
226
Tonight I spent an hour cutting out a freeze plug to replace it with the Achilles heater core block-off plate, because I had forgotten I had it.
I am so smart... S-M-R-T...
      03-11-2018, 11:47 PM   #78
mattfwalters
226
So today I did FCABs.
Got me a benchtop press:
Found the right tool for the job:
Made some pieces:
Cleaned them up and pushed 'em together with some new bits:
Yes, I am ashamed that one of the GC logos isn't lined up properly. Not ashamed enough to press it back out and fix it, though.
I managed to split one of the inner rings when I was pressing the GC bushings into it - that made a pretty awesome noise. I figure that since they're under a lot of compression force in the lollipops it'll be fine, but if I'm being an idiot, please advise.
wdb4732.00
SaltyNC369.50
      03-12-2018, 10:53 AM   #79
SaltyNC
SaltyNC's Avatar
370
I've seen people use large sockets, but a hole saw is a good idea for pressing new bushings. I've got to do two sets of these in the next week or so.
Salty
      03-12-2018, 03:52 PM   #80
mattfwalters
226
Salty
Bear in mind that you will destroy the hole saw unless you reinforce the center of it with something. Ask me how I know.
PS: 2.5" hole saws are $7 on Amazon, so I think it was still worth it
PPS: bushing / bearing press puck sets are like $25 on Amazon, so
      03-13-2018, 01:36 AM   #81
mattfwalters
226
Ordered a 22-position WeatherPack bulkhead connector for running the gauge wiring through the firewall. Stopped by the machine shop to pick up my crossmember but they were closed early. Sigh.
      03-14-2018, 12:14 AM   #82
mattfwalters
226
Definitely not perfect, but this Eastwood primer is laying down pretty nicely.
Still had to knock a shitload of paint and rust off of the bastard. Machine shop failed to mention that their hot tank isn't actually acidic.
      03-14-2018, 01:18 AM   #83
mattfwalters
226
...and then I decided that the crossmember didn't need to be boring.
      03-14-2018, 10:26 AM   #84
SaltyNC
SaltyNC's Avatar
370
I dream of wires.
That crossmember should match your calipers nicely.
Salty
      03-14-2018, 12:53 PM   #85
mattfwalters
226
I dream of wires.
Salty
Yeah, I may actually do the control arms in this red as well. And I'm also a modular nerd.
Regarding FCABs: I exchanged some emails with Donovan at Ground Control, who is awesome.
These would be fine if the ID of the 66mm and 60mm FCABs were identical - unfortunately the 66mm FCAB has a 22mm ID and the 60mm has a 24mm ID. So he's sending me a correct set and I'm sending these ones back.
      03-14-2018, 07:22 PM   #86
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
Are you getting offset fcabs? That is what our cars are supposed to have. Those GC ones looked symmetrical like for an M3.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
      03-15-2018, 01:41 AM   #87
mattfwalters
226
Yeah, I'm getting the correct FCABs.
      03-18-2018, 12:51 PM   #88
Sliktop
31
Drives: 07 Z4 M Coupe
What are the part numbers on the offset GC FCABS? I want to order them asap if they exist.
Sweet build thread, btw!
zpost
