BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Has anyone contacted BMW regarding 29.2 and lag?
      06-06-2008, 04:00 PM   #23
tek818
Drives: 2020 X3M Competition
2018 M3 ZCP  [9.50]
Just called and spoke with some girl that obviously knew nothing about this issue. She did however recommend reporting the issue to the dealer, and they address the issue with their engineers, who will in turn contact BMW NA/AG. She noted and submitted my complaint...
2020 F97 X3M Competition (current) - 2018 F80 M3 Competition - 2015 F82 M4 - 2012 E82 135i - 2010 E92 335i - 2007 E92 335i
      06-06-2008, 10:51 PM   #24
price9195
Drives: 335i sedan
I had my car (April 07 build) in for service 4 wks ago for brake light coming on indicating brake service due. Car had only 11,000 mi. and brakes were fine but had to be reprogrammed to get light to turn off.
First day, pulling away from mailbox and floor it. Like others have said, the turbo takes a full count to spool up until it hits about 32-3500 rpm. Noticed the car was popping through the exhaust in first gear like it did when I disconnected the exhaust flap. (But then reconnected because of highway drone).
Thought I was imagining things until I checked in here. First few days I stalled the car like 3 times because the torque at clutch slip seemed different. Over the last month I have learned to drive my "new car." You have to give more throttle on starts to prevent bogging. To overcome the lag you have to try to keep the revs above 3500 rpm or keep deep into the throttle to keep the turbo spinning.
It definitely has changed the car. Mentioned it to my SA when in for a tire replacement last week and he said yes I have 29.2 but denied knowing about the issues. He has a similar month build 335 so I asked him to let me know if he hears anything about a fix for this. I hope that in the next few months enough people complain enough to force a fix.
It is a noticeable difference. I feel like they have changed the car into something totally different than what I took delivery of 1 year ago.
I should call customer service but haven't yet.
      06-07-2008, 08:16 AM   #25
tyler9595
tyler9595's Avatar
Drives: Boring
Originally Posted by ezatnova View Post
I absolutely don't disagree that peak power/tq feels fine, as before 29.2. I do disagree that the softer delivery can be negated with a heavier foot. Just take throttle modulation out of the picture and slam it to the floor on a pre 29.2 car and then on a 29.2 car and it's a different ballgame.
I agree 100% - there is A LOT LOT LOT more turbo lag. The car now drives like my old RX7....stomp, wait 2 sec, then the power comes. I notice a huge difference with 29.2. BMW has really screwed the performance
      06-07-2008, 12:44 PM   #26
slubu
Never Go Full Retard
slubu's Avatar
182
Drives: White Lightning
Please everyone call and complain. It will help.
2008 335i
      06-08-2008, 09:04 AM   #27
FunRevn
Drives: 2020 M5
I called and logged my total dislike for the 29.2 progman. Basically they said they havent heard anything negitive about it yet....
Lets keep the flow of calls coming.
      06-08-2008, 05:46 PM   #28
midlife
ocasionally in crisis
midlife's Avatar
52
Drives: '08 335i cabrio
I felt mine re-adapt for proper power once the boost has built, but, it's the time that it takes to go full-boil that is still annoying and hasn't improved. It's a solid 1+ second now from flooring it at, say, 3000 rpm, before I feel full boost built and I start to fly. Before 29.2, it was nearly isntantaneous.
I'm surprised a car could even potentially "adapt" out this lag, since it's caused by a physical change in the programming of the duty cycles of the wastegates. Having them open more of the time equates to longer boost build time.
sorry but i am joining this thread late: hope this is not a repeat...
i just tell my dealer that i DO NOT WANT ANY UPDATES BECAUSE OF ........
but why is bmw doing this ??
are our tubos really that delicate they they have to piss people off with 29.2 ??
my 2 cents
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs /
M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 /
      06-08-2008, 06:43 PM   #29
branabolic
branabolic's Avatar
24
Drives: e92 335i
ya when i test drove a 335 in march it had no turbo lag at all, felt like a na v8. got my car may 12 it has v81 and i definatly feel some lag. even more so than my brothers 01
s4 w/ 110k miles. there is lag in this vehicle when bmw prides themselves on it having so little. if you are going to make it lag on purpose, why not have just given us some bigger turbos that dont kill themselves above 5k rpm??? aholes.
i'm not addicted to boost, but i sure am more fun when i'm on it.
      06-09-2008, 12:28 AM   #30
Quisp
Does not play well with others
Drives: BMW
For those of you that got the update and it has lowered performance below the advertised levels and that advertised level was a major determining factor in your decision to buy. The 2007 yamahas were advertised to have an very high redline, it5 was a major part of the ad campaign. After the model was released and independently tested it turned out the redline was lower than advertised. Yamaha had to do a lot of damage control including buying back the motorcycles of people that had bought the bike with the advertised expectation. I realize it is not the exact situation, but if a car was bought and then the builder made it less of a car.....seems fishy. Does anyone know if maybe progman 29.2 does this downgrade to save BMW from having to replace more HPFPs and turbos?
      06-09-2008, 12:49 AM   #31
mistermojorizin
mistermojorizin's Avatar
40
Drives: 135i
I have a Feb 08 built 135i and I bought it on April 14. My car behaves exactly as described in this 2006 post on roadfly http://forums.roadfly.com/forums/bmw...8028595-1.html :
"Try stepping on the gas in 4th gear at 2000 rpms. The car will make a little "hiccup" and then go. If the car wasn't a turbo, people would be complaining that there is a problem with the throttle. If you're old like me and remember carburetors....the throttle response of carburetors is much like the turbo lag. It's nothing like the old Saab's, but nevertheless it's there. There is no way you can have turbos without some lag."
I don't know if I have 29.2, but i know the car has the abovementioned "hicup" and lag. But as the post demonstrates the 335's had it pre 29.2 anyway. So what's the deal?
      06-09-2008, 02:42 AM   #32
Kyosho
Kyosho's Avatar
Drives: 991.2 GT3 // Panamera Turbo
Originally Posted by Jeff@Eurobahn.us View Post
If you have been re-flashed with 29.2 there is a bit of softer throttle control. This can be defeated with a slightly heavier foot. The power levels are the same and the torque is nearly identical. I know cause we have tested both.
Jeff
Eurobahn
ive always had a REALLY heavy foot.
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you."
      06-09-2008, 08:40 AM   #33
ezatnova
ezatnova's Avatar
Drives: C63 AMG
Please call 'em up man. The # is RIGHT on the OP's first post, in bold. It's super easy and takes 5 minutes. This is the ONLY way we can fix our cars.
Unkie Sam wants YOU to call!
On a related note, how many reps could BMW NA have answering that line? Maybe 50? I have NO idea (are they open 24-7?), but it can't be THAT many. If enough of us call, at least one of those people will say "hmm, yeah, I have gotten another call about this" and maybe elevate it to a manager or something.
      06-09-2008, 09:40 AM   #34
slubu
slubu's Avatar
182
Do you guys specifically refer to "29.2" or do you remain generic as in "a software update was done and now there is lag"...
2008 335i
      06-09-2008, 09:43 AM   #35
RedGT3
RedGT3's Avatar
Drives: .2 GT3/M3cs
Progman 29.2
      06-09-2008, 10:09 AM   #36
spyahoo
Drives: 335
Count me in as having the lag also. I just got 29.2 after my NAV broke. From 0-3000 the car is just slow. Throttle response gone
      06-09-2008, 10:13 AM   #37
scottp999
Drives: 4runner SR5
2007 BMW 335  [9.00]
Would it be better if you consolidated calls to one contact? What's the name and extension of people already contaced at customer support? Atleast this way, they can't keep saying they never heard of it before.
Also, if they say they are documenting it, they should be entering some kind of ticket number or tracking id that we can reference.
I have never taken my car back to the dealer. The last time the dealer saw my car was on delivery day and they had it in their possesion for only 4 hours after it literally got off the truck in May 2007.
I appreciate all the work this group is doing to raise the issue with BMW.
      06-09-2008, 11:09 AM   #38
ezatnova
ezatnova's Avatar
Drives: C63 AMG
I said it all - "My new software program update - progman 29.2"
      06-09-2008, 11:09 AM   #39
ezatnova
ezatnova's Avatar
Drives: C63 AMG
Dial 'em up!
      06-09-2008, 11:26 AM   #40
slubu
slubu's Avatar
182
I have another idea too that will help us, give me maybe until tomorrow to set it up.
2008 335i
      06-09-2008, 01:39 PM   #41
nightops
nightops's Avatar
17
Drives: 335i E92
Is there any way to know or test if you have 29.2 - I went in for an oil change and I don't know if they've upgraded it, but I'd like to know. I don't remember the car feeling any different though, sorry to hear these complaints, makes me not want to bring my car in...
335i Space Grey Coupe/ppk/ssk/pe exhaust/perf susp
      06-09-2008, 02:17 PM   #42
ezatnova
ezatnova's Avatar
Drives: C63 AMG
If you have i-drive, the screen should now be silver rather than brown, according to Jonathan. If you don't have i-drive (like me) then lag is the way you tell.
      06-09-2008, 02:18 PM   #43
ezatnova
ezatnova's Avatar
Drives: C63 AMG
Sticky Please?
MODS - Could you please make this a STICKY? I have a feeling this issue will be a storm hitting the whole community as more and more cars go in for service and get Progman 29.2.
Thanks
      06-09-2008, 02:23 PM   #44
Robertbog
Robertbog's Avatar
69
Drives: 335i
Apparently BMW NA doesnt have contact with the engineering department. I spoke to some very nice lady who explained it, BMW NA will do warranty ect, to filter a complaint through BMW NA onto BMW AG is going to be a hard thing to do and to track.
The dealerships have a clear connection to BMW AG through the internet in which they can file complaints, it is a reasonable way for them to also see that it's the average joe doing this, not some forum.
