BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > F34 Driver window squeal and error code
proTUNING Freaks
      03-17-2024, 07:13 AM   #1
rukp
18
Drives: 3 series GT 320- M sport
Hi All,
Driver window squeals and sometimes stops working, seems to be a rubber squeal from trim, tried cleaning and spraying silicone but didnt help.
Also the noise DOES happen when the door is open (not obvious at the time of this video) so as its a frameless door it would mean the base trim is causing all that noise which doesn't seem likely as the window is quite free as shown at the start of the video.
Want to see if anyone else has had this issue and is it a new regulator needed or trim? I got the error code 030016 - drive deactivated due to excess temp. So guess the motor cuts out as a fail safe so it doesn't get burnt out when restricted?
(The door hasn't been hit or damaged in anyway)
VIDEO is posted here
Thanks
Rukp
      03-17-2024, 08:37 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Can't see the video. Whatever the problem is would likely be diagnosed by pulling the door card. The weatherstrip doesn't put enough pressure on the glass to cause it.
      03-17-2024, 08:55 AM   #3
rukp
18
sorry try this
thanks
      03-17-2024, 09:34 AM   #4
Billfitz
Billfitz's Avatar
You're going to have to pull the door card to find it.
      03-17-2024, 09:52 AM   #5
rukp
18
Thks - any idea what you would expect to see, regulator issue or motor? If you've seen this before? Just so I can get parts before hand..
      03-17-2024, 12:09 PM   #6
Billfitz
Billfitz's Avatar
All I can surmise is that something's not right in there.
      04-02-2024, 10:54 AM   #7
rukp
18
UPDATE pulled the door card out and removed the window regulator was pretty brown and wires looked slightly crossed. Once you take the cover off, it's a PITA to reassemble as it's like a jack in the box!
Ended up replacing the regulator and all good.
If anyone does this on an F34, buy the window removal tool, near impossible to remove the window with pliers!
Rgds
Appreciate 3
      04-03-2024, 08:07 AM   #8
Oksamit78
Oksamit78's Avatar
272
Drives: E39, F30 & F34
Rgds
Have you noticed anything abnormal with window guides and other members of the lifting mechanism? Did any require to be greased up? The regulator being brown could be the result of it overheating while fighting the resistance of the lifting mechanism imho.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      04-03-2024, 10:49 AM   #9
rukp
18
Nothing really, the browing was odd as its a steel cable there were no burn marks or fractures. Also the original motor was swapped and worked 100%. The codes thrown out did say the motor was stopped due to overheating, so before it burnt out.
Guides all OK and not bent
