BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Procede v5 User Maintained Owners Manual
      12-11-2010, 04:27 PM   #1
azwillnj
318
Drives: 2023 M340i xDrive
Procede v5 Owners Manual and CAN DME Code lists - Updated 12/27/10
There is a lot of fragmented information on exactly how the features of the Procede work and how to set the parameters in the desktop software. I created this public Google Document in hope that we can consolidate all this information into one place... Click the link below to view and edit the document.
Vishnu Performance Systems Procede v5 Manual
n54 CAN DME Code List
n55 CAN DME Code List
EDIT 12/27/10: New PDF outputted, added google spreadsheets for n54 and n55 CAN DME Codes. Note, the n55 CAN DME Code list is currently being populated, please check back for updates.
EDIT 12/12/10: I reorganized the document and outputted it as a PDF, there is still some information missing, but I have decided to make it editable by only a few people to keep the information in the document accurate and protect things from being deleted. If you have suggestions or information that should be changed post it in the thread and the people that have access will edit it. Every once in a while I will update the PDF to reflect the most recent revision, however if you want to get the newest PDF you can download it from the file menu of the google doc. (File>Download as>*select format*)
Alex.
File Type: pdf VishnuPerformanceSystemsPROcedev5Manual - 12-27-10.pdf (1.23 MB, 13645 views)
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive
WE ARE!
Last edited by azwillnj; 12-27-2010 at 10:29 PM.. Reason: Updated PDF, Added CAN DME Lists
      12-11-2010, 05:10 PM   #2
OpenFlash
Drives: A Lot
Awesome idea guys
      12-12-2010, 11:23 AM   #3
Transport3r
Transport3r's Avatar
86
Drives: 2011 N55 E90
^ I just fixed that by pulling one of the older versions up. Someone apparently felt it was necessary to delete random info. Sabotage? :shifty
On another note, I might have been a massive clot and accidentally locked the document for everyone except azwillnj and BrianMN...
Can we have the document set to be readable for all, but only editable for people who request access?
Josh-
      12-12-2010, 11:34 AM   #4
stressdoc
Moderator
stressdoc's Avatar
Dominica
618
Drives: BMW i8; Toy 4runner TRD pro
Stickied. Please keep posts informative and to the point.
      12-12-2010, 02:48 PM   #5
BrianMN
Drives: 4 Door Family Sedan
Originally Posted by erensf View Post
Google account is not enough, you still need permission to view the file since it's not a public document. The owner needs to change the sharing settings.
Try this link.
https://docs.google.com/document/d/1...thkey=CPrl4YIM
      12-12-2010, 03:02 PM   #6
BrianMN
Originally Posted by azwillnj View Post
I don't know what happened to it but somehow the permissions changed. Someone must have been playing with them. I just changed it back to completely public and editable by anyone.
Alex- I think it's to the point where most it is filled in, and I'd suggest you take screenshots and post it into your first thread. That way, people never have to worry if random people came into the google doc and screwed things up. For now, until you post it in the first post, keep it locked to avoid changes.
Then when suggestions are made, you can change it and update the manual. If you don't feel up to making changes/updates, I will volunteer to own the thread and keep it updated.
      12-12-2010, 03:11 PM   #7
pits200
Drives: 09 335i X-Drive Black Sapphire
Now what if the format was changed for easy referencing like a regular manual. (i.e, having a chapter 1 and pages, 1.1, 1.2, 1.3 etc.)
Just break it down as follows.
Chapter 1 - Install
Chapter 2 - Uploading Maps/Firmware
Chapter 3 - Using the PDE Reader/Data Logging (Data Logging is not explained much and what each of the categories specify)
Chapter 4 - Changing Procede settings
Chapter 5 - Removal and Code Clearing/Reading
Chapter 6 - Trouble Shooting.
Or something along those lines above.
      12-12-2010, 04:02 PM   #8
stressdoc
Moderator
stressdoc's Avatar
Dominica
618
Looking good guys.
Hardware install DIY and issues might be useful.
Keep up the good work!
      12-12-2010, 06:13 PM   #9
mineo77
mineo77's Avatar
Drives: 2010 135i,1989 PRO3,2001 530i
2010 135i coupe  [7.56]
go to the procede website (not forum) and they have all downloads there
http://www.procedetuning.com/BMW/n54...downloads.html
      12-12-2010, 09:25 PM   #10
pits200
Good job so far man!!
But if someone can breakout some data logging procedure/results and what good and bad graphs look like and what signs would indicate engine issues, that is needed for part of trouble shooting.
It's just that so many people post data logs on here because they dont know exactly what to look for. (Im one of those people but I'd like to learn more about data logging results.)
      12-12-2010, 09:26 PM   #11
Transport3r
86
I will add the list of all the Log readout channels and a list of the channels we should log to have useful data. That should be up by tomorrow, maybe tonight still.
Josh-
      12-12-2010, 09:33 PM   #12
BrianMN
In the v5 software, all of the important logging channels are labeled now, instead of Debug Words/Bytes.
Alex-Can you add a section about the common logging choices.
-RPM
-Boost
-CAN Actual Ign. Advance
-Ignition Correction
-IAT
-PID Duty cycle
Most of the other ones can be used to determine specific problems, such as fuel pressure, boost leaks, etc.
      12-12-2010, 09:37 PM   #13
BrianMN
Originally Posted by chesterfan1230 View Post
Can someone answer this question for me? On startup when it displays the map #. Sometimes the small screen goes dark red, sometimes Dark Orange and sometimes Light Orange. Is there any significance with these colors?
That's normal. It doesn't represent anything, but not sure why it's different each time.
      12-13-2010, 11:06 AM   #14
BrianMN
Originally Posted by Tronner View Post
Under the Power Output section / Maximum Boost, I believe it should say, use the "Start Boost %" to tell autotuning where to start" instead of the "User Torq Map", which I don't believe exists in version 5 correct?
Yep...it was changed in v5.
      12-13-2010, 06:35 PM   #15
MKE_M3
MKE_M3's Avatar
Drives: 2011 e90 M3
It looks really good. It is missing discussion on the traction control however.
      12-13-2010, 09:40 PM   #16
CPWINCH
CPWINCH's Avatar
Drives: Toyota Prius
Awesome!
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
      12-13-2010, 10:27 PM   #17
mineo77
mineo77's Avatar
This is sweet!! THANK YOU!!!!
      12-14-2010, 08:10 AM   #18
Ghines1279
Drives: F30 335i
2007 e92 335i  [0.00]
NICE JOB GUYS! better than some official instruction manuals i have gotten, i think free t-shirts or something is in order.
      12-17-2010, 05:08 PM   #19
canderson
Cogito Ergo Zoom
canderson's Avatar
Drives: 2013 BMW M3, 2016 BMW X1
2008 335xi  [10.00]
traction control
I suggest a separate chapter on traction control. Here is a description based on posts here
Procede traction/launch control (TC) is Spark Retard-based and does not adjust brake force or brake distribution. It drops engine torque through ignition advance adjustments when it detects power-induced wheel spin. The degree of TC intervention is dependent upon the severity/duration of the wheel spin event.
It is not a stability control system. It is just a way to help power get down to the ground when your gas pedal goes into the carpet. It will work with factory traction/stability control (DSC/DTC) on or off. It works independently of DSC/DTC. With TC on, the factory DSC/DTC will need to intervene less during acceleration. TC reacts faster than DSC/DTC and will recover faster when traction is restored.
You can turn it off/on depending on map, you can also dial in the sensitivity of the traction control (0-100%) depending on map. 100% disables TC and 0% is maximum TC. For non-xi/x-drive cars 30-50% is suggested.
For xi/x-drive cars it is suggested to leave this feature off (100%). There is no harm in a lower setting either since TC should rarely intervene.
Don't expect the Procede's TC system to manage wheel spin in snowy/icy conditions. It can only reduce engine output by maybe 150whp. So going from 400hp to ~250hp is still enough to spin the tires on snow/ice. The only way to stop wheel spin in such situations is through brake application (which the standard BMW DSC/DTC system does). So it's best if you leave DSC/DTC on and let the TC work in conjunction with it.
It is suggested to press the DTC button once so that the DME allows some degree of wheel spin before intervening. This works well with the Procede's TC. As does running with the factory system completely off (DTC button pressed and held for a few seconds). Of course, do this at your own discretion and only if you feel comfortable with it.
There will be a manual over-ride to disable the launch control feature for those times you need to do a burn-out (to be confirmed)
      12-17-2010, 06:38 PM   #20
AltecBX
AltecBX's Avatar
Drives: BMW 335xi Sedan; BMW M3 ZCP
2018 BMW M3 ZCP  [0.00]
2007 BMW 335Xi  [0.00]
I set mines to 80% and feel it once in a while pull back on me.
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps)
†Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec
AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS
      12-17-2010, 08:29 PM   #21
IlChengis
once Treppiede
IlChengis's Avatar
Italy
63
Drives: 2012 E92 M3
Absolutely.
This is one of the best user-contributions I've seen on this Forum.
Well done Sir, thank you.
-Walter
2013 E92 M3 | 6MT | AlpWhite | SilverNovillo | CarbonTrim | ZCP | PremiumPkg | Alarm
2009 E92 335i | 6MT | AlpWhite | CoralRed | AlumTrim | M-Sport | Nav | Logic7 | Alarm (sold to a friend - still in the family)
      12-20-2010, 12:54 PM   #22
Centex Hokie
Centex Hokie's Avatar
Drives: BMW E93
Originally Posted by IlChengis View Post
Absolutely.
-Walter
I agree. As a new tuner this was extremely helpful.
Thanks.
http://www.e90post.com/forums/images...s/thumbsup.gif
