BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Official e90post 60-130 Times List!
Closed Thread
      10-07-2012, 08:44 AM   #287
Evil///M
Professional Hitman
Evil///M's Avatar
Drives: R8 V10+ | Colorado Z71
What are you guys using to clock these times, a stopwatch and a GPS..??
      10-07-2012, 05:10 PM   #288
jpsimon
Team Zissou
jpsimon's Avatar
Drives: 2022 AWD M3 Comp - SMB
You need to use a v-box/performance-box:
http://vboxusa.com/performancedrift/performancebox.php
it's GPS based. The times are only accepted if you used this and send the log in
      10-13-2012, 08:25 AM   #289
prelude2perfect
prelude2perfect's Avatar
60
Drives: 2013 M5 and 2015 535i
Borrowed another members performance box and got a few runs in a couple months ago, just now got around to emailing the charts to Mr5. I have no idea how to read them so I don't know what the slope was, but I'm pretty sure it was well under 3% since the road was pretty flat. Here's a screen shot of my best time:
Full weight E90 6mt, racegas, 100% meth
      11-02-2012, 07:32 PM   #290
MasterWang
Drives: F06 M6
Didn't go up to 130
but heres my 60-100
      02-24-2013, 01:02 PM   #291
JZWBMW
Drives: 2008 bmw 135i
Jzw stg 3 a mile high
I will get my gps device out, did a quick test, seems to be around 11 seconds flat for my 91 octane stg 3 run a mile high in Denver.
JZW Stg 3 Ecu Re-flash
ETS Intercooler
HPF Exhaust
      03-03-2013, 05:13 PM   #292
idspeedskater
Idaho Transplant
Drives: 2007 335xi
Email sent with vbox file attached
Finally got back to town and had a chance to get the Xi single turbo out for the first 60-130 runs. 60-130 Time: 9.26s More details below:
1. 2007 e90 335xi
2. Manual
3. Procede
4. Vishnu/FFTEC single turbo
5. Vishnu/FFTEC single turbo, Procede, Vishnu pwm meth, FMIC, HKS legamax premium exhaust
Other items:
  • Stock suspension
  • Full tank 91 CA pump
  • 0.7% upslope
  • 1 shift :: No lift shift NOT ENABLED yet
  • have video, will try to post later
60-130 Time: 9.26s
07 335xi Monaco Blue | FFTEC/Vishnu Single Turbo | Procede Rev 3 | Spec Stage 2+ Clutch | Spec Aluminum Flywheel | ETS FMIC | HKS Legamax Exhaust | Vishnu PWM Meth - 2014 e63s wagon | W3 Weistec tune/turbo upgrade
      03-03-2013, 06:02 PM   #293
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
1. 2007 e90 335xi
2. Manual
3. Procede
Other items:
  • Stock suspension
  • 0.7% upslope
60-130 Time: 9.26s
You spent almost a whole second not accelerating at all around the 6 second mark. What happened? Did you bog the shift or something? There's much more in it. Practice makes perfect!
E90 LCI N54 6AT
      03-03-2013, 06:12 PM   #294
idspeedskater
Idaho Transplant
Drives: 2007 335xi
Yeah, that shift wasn't stellar, if I get the vid up you'll see it. You have to look at this as a first run to set a baseline so i can see the evolution as we progress the platform. A few things to note:
  • It's a conservative tune as we still need to see what transfer cases will take
  • The best road I could get to has a 0.7% UPSLOPE if I was on the typical 1-2% descent it would probably save me a second off the top
  • This was the first run with the car, so there will be driving adaptations needed
  • It had a completely full gas tank and is running crap 91 California gas
  • Not having the no lift shift enabled makes for slower shifting than will be possible
I fully expect to see this number drop significantly across time until this gets dialed in.
      03-03-2013, 06:16 PM   #295
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
First start by starting your 60-130 run before 60 mph that alone will get you into the 8's.
E90 LCI N54 6AT
      03-07-2013, 02:56 AM   #296
OpenFlash
Drives: A Lot
6.881s 60-130
New Single Turbo 6AT results...
Owner: CupertinoSteve
1. 2008 E90 335i
2. Auto (with Alpina flash)
3. Vishnu Procede
4. Vishnu/FFTEC Single Turbo 58mm
5. Full exhaust, FMIC, Vishnu PWM Methanol, ERC race gas, MT drag radials
More info here: http://www.e90post.com/forums/showthread.php?t=812635
Vbox file emailed to Mr.5 and DLSJ5
      03-08-2013, 04:05 PM   #297
OpenFlash
Drives: A Lot
Is Mr.5 still around these woods?
      03-12-2013, 06:54 PM   #298
OpenFlash
Drives: A Lot
Looks like Mr. 5 is no longer around here. If so can someone else maintain/update this database?
      03-30-2013, 02:34 AM   #299
G.I.Joe
G.I.Joe's Avatar
Denmark
30
Drives: E92 335i 2008
A pity the database/frontpage/thread is apparently no longer updated here. Maybe we could use the online validation pages available?
I recently did a 7.55 sec 60-130 time in my full weigth RB turbo'ed E92 6MT 335i. Time was done in 3rd and 4th gear (1 shift). I haven't posted yet since I think I can improve it a bit more with better traction, however the snow seems to just keep coming around here....
The mods of my car are: COBB ProTuning e-Tune E50 custom map from Pro Tuning Freaks, Quaife LSD, DEFIVfab N54 diff lockdown kit, RB turbos, Wagner FMIC, Wagner 3" DP, Milltek catback exhaust, STETT CP, Forge DV, AFE Stage 2 DCI with scoops, HPF Feramic Stage 2 clutch, BMS CDV
I run on 40% Shell V-power (93) and 60% E85 (~E50 mix), NO meth. There are NO weight reductions what so ever done to the car, and I myself am quite heavy (260 lbs.). Test done on winter tyres and stock BMW 188 style 17" rims too, so the car is a real sleeper
Here's a validated screenshot. Will gladly send dbn file to Mr.5 or whoever should choose to take over administration of this database.
E92 335i 2008 Space Grey 6MT | Pure Stage 2 turbos | Motiv PI | Trueform Tech Intake | Quaife LSD | M3 Suspension kit | Öhlins Road & Track Coilover | DEFIVfab N54 diff lockdown kit | COBB PTF E85 Map | Fuel-It Stage 3 LPFP | NGK 5992 plugs | Wagner FMIC | Wagner 3" DP | Milltek exhaust | Tial BOV | SPEC Stage 3+ clutch | SPEC Steel SM Flywheel |
      03-31-2013, 05:39 PM   #300
OpenFlash
Drives: A Lot
Great results. It doesn't look like the list on the first page is getting updated unfortunately.
Shiv
      04-04-2013, 10:36 AM   #301
G.I.Joe
G.I.Joe's Avatar
Denmark
30
Shiv
Thanks. So are yours, but they always were
Btw. I heard a FFTEC/Vishnu ST kit was sent to Denmark, but haven't heard anything for the last few months. I was looking forward to meeting up with the guy. Hope that project is working out ok.
No, it's a shame that the list isn't updated really. Especially now when more results from ST and upgraded TT options, and various E85 mixes etc. are available. Nothing like a 60-130 time to show real world performance
      07-02-2013, 08:21 PM   #302
easy2speed
easy2speed's Avatar
26
Drives: M5/M3/X5 50i
2013 335is coupe 6-speed manual
JB4 ISO
BMS DCI
BMS flash
70% E85
60-130 - 10.44
1.66 % decline
DA of 2125'
86 degrees
Submitted to Mr 5
'14 991 Turbo - ECU flash
'16 M5 - JB4 & BCM
'16 X5 50i
SOLD - '13 GT-R - 800whp/635wtq
SOLD - '07 997 Turbo 6mt - 701whp/640wtq
      08-03-2013, 04:04 AM   #303
OpenFlash
Drives: A Lot
New N54 World Record:
More info: http://www.e90post.com/forums/showthread.php?t=872633
However, i don't think this list is getting updated any longer
      08-03-2013, 12:46 PM   #304
G.I.Joe
G.I.Joe's Avatar
Denmark
30
Awesome time Shiv, looks like a little wheelspin in 3rd gear
      08-03-2013, 06:54 PM   #305
OpenFlash
Drives: A Lot
Thans man.... Yeah, a TON of wheelspin. Check out the video
      02-24-2014, 02:48 PM   #306
Mr. 5
Modder Raider
Mr. 5's Avatar
Scotland
753
Drives: M3
2007 e90 335i  [8.00]
I apologize for not keeping up to date with this list guys.
I'm doing what I should have done a long time ago...I'm pointing you over to the 60-130 list that DLSJ5 has created over at M3post.
He is much quicker with the responces and updates.
http://www.m3post.com/forums/showthread.php?t=630463
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD
Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM
Closed Thread
