BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Wheels | Tires | Spacers
BPM
      10-18-2012, 04:07 PM   #1
ApexWheels
ApexWheels's Avatar
1429
Drives: M3
► APEX | ARC-8 Light Weight Track Wheels
Thanks for your interest in our ARC-8 wheels! This thread will no longer be updated, but the discussion continues on our combined Flow Formed wheel thread at: https://www.m3post.com/forums/showth...3#post25584923
We hope to see you there!
      10-31-2012, 03:53 AM   #2
Tomislav
Panty Schtuffer
Australia
21
Drives: 2008 E92 M3 Coupe
2008 BMW M3  [0.00]
2010 BMW X6M  [0.00]
1997 BMW 323i  [0.00]
1994 BMW M3  [8.00]
Would these ever end up as 19" wheels?
.: 2010 E71 X6M - stock, daily driver, towcar :.
.: 2008 E92 M3 - 6MT, Carbon Roof, Eibach Springs, Megan Axle Back exhaust :.
.: 1997 E36 323i Frankenstein - too much to list, track whore, stripped, caged, MoTeC, S85B50 :.
.: 1994 E36 M3 3.0 - 19" BBS LM Reps, Bilsteins :.
      10-31-2012, 12:22 PM   #3
Expert@ApexWheels
Expert@ApexWheels's Avatar
3530
Drives: M3
We are working on that, hopefully we will have them this coming year
      11-13-2012, 11:47 PM   #4
mot
Drives: e92 AW M3 6MT
Group buy?
      11-14-2012, 01:49 PM   #5
ApexWheels
ApexWheels's Avatar
1429
Drives: M3
I can't give out much information yet but keep an eye out on our Facebook, website, and the forum for an upcoming special very soon
      06-18-2013, 04:34 PM   #6
Sal@AUTOcouture
Sal@AUTOcouture's Avatar
733
Drives: E93 M3, E36 M3
very nice!
      06-18-2013, 04:36 PM   #7
Sal@AUTOcouture
733
Here are some pics from our latest build:
Specs:
Hyper Black 18x9.5 ET22 front
Hyper Black 18x10.5 ET27 rear
      06-19-2013, 11:14 PM   #8
wheatpaste
Drives: 08 E92 M3
How do these wheels hold up as daily driver wheels with occasional track usage?
Just curious if you've seen much issue with bending from potholes and rough roads.
I'm pretty careful with my wheels, but the roads around here seem to keep getting worse and worse.
      06-20-2013, 05:49 PM   #9
Expert@ApexWheels
3530
Drives: M3
Thank you for the photos Sal@AUTOcouture Great looking project!
We've had plenty of customers use our wheels for both street and track use, even those that use them strictly for track or race use. We have not had any issues with them used for either purposes, and many of our customers have been extremely happy with the performance provided by our ARC-8 wheels on the track, while helping them slightly increase gas mileage for daily use. With the proper tire sizes used with our wheels, you should have proper wheel protection from most potholes.
      06-21-2013, 11:51 AM   #10
03///m3
46
Drives: 2013 E92 M3
So the 18 x 10 ET25 will fit an stock ZCP E92 M3 (all 4 corners) without any spacers or modification needed? Also are the wheels hubcentric (do not require hubcentric rings)?
      06-21-2013, 11:59 AM   #11
Expert@ApexWheels
3530
Drives: M3
The e9x M3 with OEM suspension can utilize the 18x10" ET25 ARC-8 with 275/35/18 street tires without the need of any spacers. If you are using an extreme summer tire, such as a Hankook RS3 or Dunlop DZII, you may have slight rubbing on the fender liner at full lock. The wheels are hubcentric so you will not need any hubcentric rings. Let us know if you have any other questions!
      06-21-2013, 12:02 PM   #12
03///m3
46
Drives: 2013 E92 M3
OK. I would most likely using RS3's. So i should opt for the 9.5 width front wheels for absolutely no rubbing?
      06-25-2013, 05:54 PM   #13
ApexWheels
ApexWheels's Avatar
1429
Drives: M3
Yes, the 18x9.5" ET22 ARC-8's shouldn't rub even at full lock with 275/35/18 Hankook R-S3's because the 9.5" wheel will allow for 3mm more clearance on the outer edge of the rim and 9mm more clearance on the inner edge of the rim.
      06-30-2013, 11:14 AM   #14
jc05e46m3
jc05e46m3's Avatar
Drives: '21 F90 M5 Comp
GB
Any group buys?
      07-01-2013, 12:12 PM   #15
Expert@ApexWheels
3530
Drives: M3
Originally Posted by jc05e46m3 View Post
Any group buys?
We are not currently hosting any group buys, and do not have any plans for one in the near future. There may be one at the start of the new year, but we have not decided on what would be included.
      07-06-2013, 12:04 AM   #16
crispy tofu
crispy tofu's Avatar
15
Drives: 2018 M2
I have this setup with the ZII's. no rubbing whatsoever.
      07-08-2013, 04:54 PM   #17
ApexWheels
ApexWheels's Avatar
1429
Drives: M3
Thanks for the input, its great to hear you aren't having any issues with the Dunlops!
      07-23-2013, 04:15 PM   #18
Millie
Millie's Avatar
120
Drives: a bmw.
Originally Posted by ApexRaceParts View Post
Concave 17" ARC-8's are in stock now!
What width do you recommend, the 10" or 10.5? What is the max amount of tire (squared) could I get on the 17" for autocross use only.
Thanks!
2022 Nissan Armada (big couch)
2017 Camaro SS 1LE - Gone
2008 SSII E90 6MT - Gone
2009 SG E92 DCT - Gone
      07-23-2013, 05:46 PM   #19
ApexWheels
ApexWheels's Avatar
1429
Drives: M3
Thanks!
We would recommend the 17x10" ET25 with 275/40/17 tires. This car is running 275/40/17 Toyo R888's which are very meaty. No camber plates are required to run these wheels and tires, and no spacers are needed either.
You could potentially run the 17x10.5" wheels all around but it is a very difficult fit for the front. The 17" wheels sit much closer to the strut tube, so a thick spacer will be required. Additionally, camber plates will likely need to be maxed out to prevent rubbing on the fender. We do not recommend this setup, but it is possible with the correct amount of work put into the setup.
Feel free to ask us anything else you might have questions about!
      07-23-2013, 06:27 PM   #20
Millie
Millie's Avatar
120
Drives: a bmw.
We would recommend the 17x10" ET25 with 275/35/18 tires.
Don't you mean 275/40/17 tires? I don't think 275/35/18 would fit on 17" wheels.
You ship to Canada?
      07-24-2013, 01:00 PM   #21
ApexWheels
ApexWheels's Avatar
1429
Drives: M3
You ship to Canada?
Good catch fixed! Yes we can ship to Canada via UPS Standard International.
      08-27-2013, 06:05 PM   #22
blankstar43
Drives: 2012 e92 M3
when will the next group buy be
2012 JZB/Fox Red M3 DCT -JZB reflectors, CF gills, gloss black grills
m3post
